A'PEX-i MAIN DISTRIBUTOR IN INDONESIA - Page 34
Page 34 of 34 FirstFirst ... 3031323334
Results 331 to 340 of 340
  • Short URL:  http://modifika.si/169061
    6 Days 10 Mins 4 Secs
    Bos minat sama iriway IX utk yaris 2012. PM ya bos. Thanks.
    -- Toyota Yaris 1NZ-FE TRD (ver3.0) M/T 2012 Super White --
    http://www.modifikasi.com/showthread.php/515997-Toyota-Yaris-1NZ-FE-TRD-(ver3-0)-M-T-2012-Super-White?p=2058810912#post2058810912
  2. #332
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    pm sent bro …...
  3. #333
    cipondoh-tangerang
    PROMO AP RACING CP 5200 BLACK CALIPER 4 POT ,AP BRAKE PAD,BRAKE HOSE,AP BRAKE HOSE SAMA PEMASANGAN DENGAN HARGA 27 JT DAN 28,5 JT APABILA CALIPER RED CALIPER.
    FOR ORDER
    SPEEDZ PERFORMANCE
    JALAN BIAK NO 48-48A
    JAKARTA PUSAT 10150
    081382077777(HANZ SPEEDZ)
  4. #334
    cipondoh-tangerang
    ---------DAPETKAN PROMO AP RACING -------------
    -CP 5200 BLACK CALIPER 4 POT ,AP BRAKE PAD,BRAKE HOSE,AP BRAKE HOSE SAMA PEMASANGAN DENGAN HARGA 27 JT DAN 28,5 JT APABILA CALIPER RED CALIPER.
    - CP 9040 BLACK CALIPER 6 POT ,AP BRAKE PAD,BRAKE HOSE,AP BRAKE HOSE SAMA PEMASANGAN DENGAN HARGA 34 JT DAN 35,5 JT APABILA CALIPER RED CALIPER.
    FOR ORDER
    SPEEDZ PERFORMANCE
    JAKARTA PUSAT 10150
  5. #335
    cipondoh-tangerang
    Auto Update Harga di bulan April 2016 for Big Brake Kit AP RACING and BREMBO.
    We bring genuine big brake kit BREMBO and AP RACING ,we supply for INDONESIA and MALAYSIA market, and many installation in customer car & dealer wanted.
    *****AP Racing made in UNITED KINGDOM*********
    -CP7600 caliper 4 pot ,AP disbrake 295mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 24 jt(black caliper) dan harga 25,5 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 29 jt (black caliper) dan 30,5 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 36 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 36 jt (black caliper) dan 37,5 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 39 jt.(applikasi utk velg 19 inch).
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake 355mm floating slotted , AP brake pad APF 402, HEL brake hose harga 42 jt. (applikasi utk velg 18inch)
    *dengan discbrake floating slotted 362mm harga 45 jt.(applikasi utk velg 19 inch).
    **** BREMBO Made in ITALY ********
    -Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 39 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch)
    ---extra 4 jt apabila dipasang ke caliper belakang karena pembuatan center bell besar --------
    -BREMBO 17Z caliper 6 pot,BREMBO brake pad,with center bell plug & play alumunium and adaptor dengan discbrake floating drilled 355mm & brake hose harga 38 jt.(velg minimal 18 inch).
    -BREMBO 19Z 6 pot ,BREMBO brake pad with center bell plug & play alumunium , and adaptor dengan discbrake 380mm floating drilled harga 44 jt.(velg minimal 19inch)
    **dengan floating drilled disbrake 405mm harga 46 jt. (velg minimal 20 inch).
    -BREMBO GT 6 pot.BREMBO brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO REAR PORSCHE New CAYENNE Caliper (For Rear Use Only),Brembo Brake Pad With Discbrake 345MM Floating Drilled Harga 35 JT.(velg minimal 18 inch)
    **Discbrake 380Mm Floating Drilled HARGA 38 JT.(velg minimal 19 inch).
    -BREMBO 4POT Model 7L6 (For Rear use only ),BREMBO Brake Pad With Discbrake 345MM Floating Discbrake Harga 33 JT.(velg minimal 18 inch)
    **Discbrake 380MM Floating Drilled Harga 36 JT.(velg minimal 19 inch).
    $$$$$---untuk pembelian big brake kit depan+belakang dapetkan potongan harga 3 jt-----$$$$$
    For Order Call/Whatsapp:
    081382077777-085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Tangerang 11750
  6. #336
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    Green Lake City Ruko CBD Blok L no 7
    Cipondoh-Tangerang.
  7. #337
    cipondoh-tangerang
    SPEED'Z PERFORMANCE ,GREEN LAKE CITY RUKO CBD BLOK L NO 7,CIPONDOH-TANGERANG contact 081382077777-082312077777(HANZ SPEEDZ)
  8. #338
    cipondoh-tangerang
    SPEEDZ PERFORMANCE Authroized for supply AP RACING world leader stock in huge quantity for stockiest so make the Stock in very good price.
    we always develop for the update AP Racing stock start from 15 inch wheels to 22 inch using World-Radical
    and for Brembo Grand tourismo start from wheels 17inch to 21 inch.
    we supply for INDONESIA Exclusive market, and many installation in customer car & dealer wanted for area not in Jakarta.
    Please come and see Stock and many application before buy and all is in stock.
    AP RACING MADE IN UNITED KINGDOM
    -CP7600 caliper 4 pot ,AP disbrake 285mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 22.5 jt (black caliper) dan harga 24 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 27 jt (black caliper) dan 29 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 34 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 34 jt (black caliper) dan 35 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 37 jt.(applikasi utk velg 19 inch).
    *dengan discbrake floating slotted 362mm harga 44 jt.(applikasi utk velg 19 inch).
    NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose.
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 45 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 47 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 49 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 52 jt.
    CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 42 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 43,5 jt.
    *Dengan discbrake floating drilled 330mm harga 34 Jt. (velg minimal 17 inch)
    *Dengan floating drilled discbrake 345mm harga 36 Jt.
    *Dengan floating drilled discbrake 355mm harga 37 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 39 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan discbrake floating drilled 355mm(buat velg minimal 18 inch) harga 46 Jt.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 20 Inch) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot.brembo brake pad .duralium center bell and adaptor plug and play of specific car
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    dapetkan potongan setiap pembelianbig brake kit depan + belakang dapetkan potongan harga 3 jt (extra pemotongan for customer).
    081382077777-082312077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang 11750
  9. #339
    cipondoh-tangerang
    PEED'Z PERFORMANCE by STZ ,It has over 17 years’ experience and specialized in distribution high end performance engine racing parts, bring high end brake system to providing the best brake system to consumers.It is for supply With the effort of SPEED’Z strong team, excellent sales , SPEED:Z has been successfully make pre-sales and after-sales value-added services to our business partners.for call/whatsapp 081382077777-082312077777(Hans SPEED'Z PERFORMANCE)
  10. #340
    cipondoh-tangerang
    Update price BBK oktober
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404,HEL Brake hose,Cnter hub +adaptor.
    *dengan discbrake 285mm(min velg 15 inch) harga 24 jt
    *dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 29 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min17 inch) harga 36 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 355mm(min velg 18 inch) harga 36jt.
    *dengan discbrake 362mm(min velg 18-19 inch) harga 38 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, HEL brake ,Center hub+adptor.
    *dengan discbrake 355mm (velg min 18 inch) harga 43jt.
    *dengan discbrake 362mm (velg min 18-19 inch)harga 45 jt.
    ** AP discbrake floating Curved Groove 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 48 jt
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    SPEEDZ PERFORMANCE
  1. PIVOT MAIN DISTRIBUTOR IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 25th February 2018, 03:40
  2. CP PISTON MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 20th April 2017, 03:35
  3. TURBOSMART MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 31st October 2016, 02:33
  4. BRIAN CROWER MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 5th October 2016, 16:35
  5. T.M. WORKS MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 19th September 2015, 15:35
