Super Promo Integrated Rega Brio 3, terbatas!!!!
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/169041
    jakarta selatan
    3 Days 2 Hrs 6 Mins 55 Secs
    PEMBELIAN REGA MENDAPATKAN 1 KABEL POWER TARALABS SENILAI 600 RIBU!!!!
    -Tara Labs SA-OF8N Copper conductor
    -Trio Design solid core conductor
    -SVPE primary dielectric
    kepalanya keq gni, HANYA UNTUK 3 UNIT!!!
    http://i235.photobucket.com/albums/ee22/aleksukomeng/oyaide.jpg
    Brio3
    By jlu_mike at 2010-01-21
    The third generation of Brio the Brio 3 now boasts a modified power supply and up-rated power transformer.
    The increased power output (49 watts per channel into 8W) of the Brio 3 greatly improves control and musical performance over its predecessor.
    Rather than having unnecessary gadgets and frills usually found on products in this price range, the Brio 3 utilises the highest quality components to achieve the best sonic performance.
    The output amplifier is built around a pair of Sanken 150w Darlington output transistors and an electronic circuit protects against shorted speakers and reactive loads of 1.7W or less.
    The power supply uses the new generously rated toroidal transformer and 10,000F smoothing capacitors that provide enough current to drive the hardest of loads.
    If excellent sound quality and affordable price is your priority then the Brio 3 may be the ideal amplifier for you.
    Features
    * 49w RMS per channel into 8ohm
    * 5 inputs: Phono, CD, Tuner, Line1 & Tape
    * Rega custom built extruded aluminium case
    * Rega Planar IC phono input
    * Toroidal mains transformer
    * Sanken 150w output transistors
    Review
    http://www.stereophile.com/integrate...3_2717crx.aspx
    http://www.positive-feedback.com/Issue28/rega_brio.htm
    http://www.avguide.com/review/rega-b...ollo-cd-player
    brg brand new suara maknyus deh ga malu maluin dengan harga sgtu, kalo mw audisi juga boleh di tempat saya, percaya kuping sendiri deh dijamin!!
    for fast response plz contact
    Mike 0817 917 3357
    cuma 4.900.000!!!!
  2. Jayapoker
    jakarta selatan
    upppppppppppppppppp
    jakarta selatan
    uppppppppppppppppppppppppppppp
    jakarta selatan
    jakarta selatan
    uppppppppppppppppppppppppppppppppppp
    jakarta selatan
    1 Hr 8 Mins 45 Secs
    Bos ini integrated ampli ama pre amp yah? Pm net nya donk..
    Quote Originally Posted by orang View Post
    Borong terus.....
    jakarta selatan
    cek pmny bos
    pedalaman
    19 Hrs 3 Mins 19 Secs
    Quote Originally Posted by davids88 View Post
    Borong terus.....
    podo wae kro koe...:p:p
  1. Replies: 3
    Last Post: 17th August 2012, 07:12
  2. K&N Super Promo (terbatas) s/d 16 Agustus 2012 ini.....
    By Toeti Lie in forum Jual Beli Mesin Lainnya
    Last Post: 4th August 2012, 12:00
  3. Replies: 1
    Last Post: 27th July 2012, 18:53
  4. Home Audio ( Quad 11L, Audioquest, Rega Brio 3) Bening dahhhh
    By jlu_mike in forum Bursa Audio Lainnya
    Last Post: 14th October 2010, 10:09
  5. Home Integrated Amplifier Rega Brio3
    Last Post: 11th February 2010, 21:20
