[WTB] Ampere meter & Volt Meter
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/168709
    di transmisi
    bro lg nyari amp meter & volt meter, ,
    mungkin ada yang mw jual / ada referensi toko yang murah utk membelinya??
    tp jgn auto gauge aja,,
  2. Ysbjaya88
    padang - sumatera barat
    1 Wk 4 Days 5 Hrs 49 Mins 42 Secs
    Quote Originally Posted by klutch View Post
    prosport mau bos..??? udah pake stepper motor..atau yang digitalnya..??
    di transmisi
    picnya dong bos, ,
    kalo boleh saya mau lihat, ,
    harganya brp tuuh?
    stepper motor apa yahh?
    maklum msh awam
    motor nya udah pake sistem elektris jadi ga mekanis lagi bos...lebih akurat..
    A stepper motor (or step motor) is a brushless, synchronous electric motor that can divide a full rotation into a large number of steps. The motor's position can be controlled precisely without any feedback mechanism (see Open-loop controller), as long as the motor is carefully sized to the application. Stepper motors are similar to switched reluctance motors (which are very large stepping motors with a reduced pole count, and generally are closed-loop commutated.)
    Stepper motor characteristics
    1. Stepper motors are constant power devices.
    2. As motor speed increases, torque decreases.
    3. The torque curve may be extended by using current limiting drivers and increasing the driving voltage.
    4. Steppers exhibit more vibration than other motor types, as the discrete step tends to snap the rotor from one position to another.
    5. This vibration can become very bad at some speeds and can cause the motor to lose torque.
    6. The effect can be mitigated by accelerating quickly through the problem speeds range, physically damping the system, or using a micro-stepping driver.
    7. Motors with a greater number of phases also exhibit smoother operation than those with fewer phases.
    artiin sendiri ya bos..heheh...
    untuk foto liat aja di facebook aku bos...
    hybrid@telkom.net
    di transmisi
    udh di add, , confirm aja yo, , ga bsa liat foto kalo blm jadi friend, ,
    thx udh bantu, , nice info too
    Kntak aja ke 085263747447 bos..
    di transmisi
    oke thx banget yaaa, ,
    Ok bos..kalau minat kntak aja..
  10. 27th February 2010, 16:55
    Reason
    spam!
  1. [PENGEN JUAL] boost meter,air fuel ratio meter, oil pressr/volt meter -with price
    By elextricy in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 7th November 2011, 10:23
  2. WTS : BOSST METER..WATER TEMP METER...VOLT METER OEM EVO
    By starletitemjogja in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 6th October 2010, 18:41
  3. jual 2nd autogauge blackface boost meter,vacuum meter dan SPW gauge volt meter..MURAH
    By bibongs in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 3rd November 2009, 16:38
  4. [WTB] TACHOMETER,FUEL METER,AMPERE METER,WATERTEMP
    By diekaPletokan in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 7th January 2009, 10:07
