Pengganti NSX ??? HSV 010 GT
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/168672
    Tangsel
    1 Wk 34 Mins 21 Secs
    CorporateJanuary 18, 2010
    Honda introduces HSV-010 GT for competing in GT500 class of SUPER GT Series
    January 18, 2010 - Honda Motor Co., Ltd. introduced the HSV-010 GT, which will compete in the GT500 class of the 2010 Super GT Series (managed and run by GTA Co., Ltd.).
    * The letters “HSV” stand for Honda Sports Velocity.
    HSV-010 GT
    HSV-010 GT
    Honda HSV-010 GT: Specifications and performance characteristics
    Dimensions, weight Length × Width × Height (m) 4.675 × 2.000 × (not disclosed)
    Wheelbase (m) 2.700
    Vehicle weight (kg) 1,100 or more
    Engine Engine name HR10EG
    Configuration Liquid-cooled, naturally aspirated, longitudinal V8
    V angle (°) 90
    Valve train Gear-driven DOHC: 2 intake and 2 exhaust valves per cylinder
    Displacement (cm3) 3,397
    Bore × stroke (mm) 93.0 × 62.5
    Compression ratio (Not disclosed)
    Maximum output (kW[PS]) 370 (500) or more
    Maximum torque(N·m[kg·m]) 392 (40.0) or more
    Throttle control system Mechanical
    Fuel supply system Programmed fuel injection system (Honda PGM-FI)
    Fuel Lead-free premium gasoline
    Lubrication Dry sump
    Powertrain, running system Transmission mechanism Constant mesh
    Transmission shifting method Steering paddle shifter
    Steering system mechanism Rack and pinion system with electric power steering (EPS)
    Tires(Front·Rear) 330/40R18 ·330/45R17
    Brake type and mechanism Hydraulic ventilated disc system
    Suspension system Double wishbone
    Stabilizer Torsion bar
    http://www.youtube.com/watch?v=lCqY-vAX4EA
    Tangsel
    pertamax..............
    Unknown
    5 Days 4 Hrs 39 Mins 17 Secs
    wah sangar nih
    Tangsel
    Quote Originally Posted by RraditzZ View Post
    wah sangar nih
    kira2 sangaran HSV apa NSX ??
    kalo menurut gw depannya bagusan NSX tapi blakangnya HSV...
    jakarta yg penuh polusi
    3 Wks 11 Hrs 29 Mins 34 Secs
    wowww....manteppp..
    20 Hrs 50 Mins 30 Secs
    Miniature Pix
    8 Hrs 36 Mins 54 Secs
    wagu!
  1. HU 2 din pengganti eclipse 7100
    By tzalie in forum Diskusi Head Unit & Processor
    Last Post: 4th May 2011, 03:17
  2. WTA : pengganti tweeter crescendo 8.9
    By tukangbius in forum Diskusi Speaker
    Last Post: 21st April 2011, 00:42
  3. pengganti jvc kd dv 7206
    By wild in forum Diskusi Head Unit & Processor
    Last Post: 21st August 2008, 10:20
  4. pengganti w7
    By plow in forum Diskusi Subwoofer
    Last Post: 29th April 2007, 16:45
