CRESCENDO ETUDE 3.12 hi-end subwoofer kondisi muluuuuuuus (sold,thanks modcom...)
Results 1 to 10 of 17
  • Short URL:  http://modifika.si/168554
    Cool CRESCENDO ETUDE 3.12 hi-end subwoofer kondisi muluuuuuuus (sold,thanks modcom...)
    CRESCENDO ETUDE 3.12 hi-end subwoofer kondisi muluuuuuuus........sold
    Etude 3.10
    DVC 4 ohm, 100-450 watt, sealed/vented box/free air
    Rp. 3750000
    Etude 3.12
    DVC 4 ohm, 100-600 watt, sealed/vented box/free air
    Rp. 4850000
    Etude 3.15
    DVC 4 ohm, 100-700 watt, sealed/vented box/free air
    Rp. 5550000
    CRESCENDO (The True Quality) is a new brand with a simple philosophy ... "The Best in Sound Quality".
    (IMG:http://www.mobileelectronics.com.au/pr_images/Crescendo_Logo.jpg)
    Designed and developed from scratch with innovative ideas, Crescendo is not a copy of other brands / designs, or a cosmetic makeover of "off the shelf" designs. The people behind CRESCENDO have backgrounds as car audio installers and sound quality competition champions.
    CRESCENDO products are individually numbers and quality controlled one by one to the highest standard possible. The result is a defect percentage of less than 0.1%. A number other brands can only dream of! Throughout sound quality competition, CRESCENDO is second to none.
    "Music may be ART, and audio, ENGINEERING .... but sometimes, the combination can be MAGIC"
    CRESCENDO loudspeakers are developed with quite a number of design factors and considerations in mind. Loudspeakers for use in vehicles are usually installed at a distance of only 60-100 cms from the listener, a "near-field" speaker. Emphasis has been placed on "off-axis" response, as opposed to "on-axis" response found in HiFi applications. The listening room in a vehicle is small, so subwoofers need to be designed with consideration of "transfer function" or "cabin gain" that boosts low frequencies. Finally, car audio applications require consideration of the elements such as sunlight, humidity and moisture. CRESCENDO designs cater for all the considerations and deliver!
    The Subwoofer Range:
    Crescendo Etude 2.8 ($ 359)
    Crescendo Etude 2.10 ($ 419)
    Crescendo Etude 2.12 ($ 449)
    Crescendo Etude 2.15 ($ 579)
    Crescendo Etude 3.10 ($ 669)
    Crescendo Etude 3.12 ($ 839)
    Crescendo Etude 3.15 ($ 979)
    Etude 2 and Etude 3 are Subwoofers that made for Sound Quality. CRESCENDO tried to compromise all possible boxing solution and hence All Etude 2 and Etude 3 can be installed in sealed, ported or free air enclosure designs. The main difference between Etude 2 and Etude 3 is power handling. Etude 2 has lesser power handling compared to Etude 3 hence less attack. All Etude 2 and Etude 3 are DVC and 4 ohms impedance.
    call
    081388575788
    Up chris..
    klaten
    Bantu sundul bos..
    BB : 51C94DDA
    2 Mths 2 Days 21 Hrs 2 Mins 46 Secs
    bantu up aja deh buat barang yang muntabs kaya gini mah...........
    4 Wks 1 Day 19 Hrs 6 Mins 58 Secs
    bantu uppppppppppp ko christ... mau lepas brapa ne ko?? pm ya.. tq
    thanks yach bos rinal,bos danny,bos razor, n bos irvan....
    pm sent yach van....
    thanks..........
    up..................
    Up...........
    up................
    up.................
Tekiro Venom 300x250
  1. FS: Subwoofer Crescendo Etude 2.12 (12")
    By logiten in forum Speaker - SubWoofer
    Last Post: 5th April 2012, 21:43
  2. Jual subwoofer crescendo etude 2.12"
    By syamsulmrf in forum Speaker - SubWoofer
    Last Post: 3rd March 2012, 17:27
  3. WTS > Subwoofer Crescendo Etude 2.10 v1
    By masih_cupu in forum Speaker - SubWoofer
    Last Post: 21st September 2010, 14:16
  4. WTS> Subwoofer Crescendo Etude 2.10 v1
    Last Post: 18th June 2010, 11:55
  5. Dijual Subwoofer Crescendo etude 2.6 ( 6" ) (SOLD!!!!!!!!)
    By william_bintoro in forum Speaker - SubWoofer
    Last Post: 2nd November 2009, 17:24
