SEAS EXCEL MILLENIUM 4" midrange w12cy-001 (sold,thanks modcom....)
  • Short URL:  http://modifika.si/168550
    Cool SEAS EXCEL MILLENIUM 4" midrange w12cy-001 (sold,thanks modcom....)
    SEAS EXCEL MILLENIUM 4" midrange w12cy-001 kondisi muluuuuuus..............sold
    The W12CY001 is a 12cm (4,5) cone driver developed for use as a high fidelity woofer/midrange unit. The extremely stiff, yet light cone gives tremendous bass precision and midrange detail.
    Precision cast and surface treated magnesium cone coupled to a natural rubber surround showing no sign of midrange (edge) resonances.
    Heavy copper rings mounted above and below the T-shaped pole piece reduce non linear and modulation distortion and increase overload margin.
    An extra large magnet system for good sensitivity and transient response. Copper plating of the top and bottom plates and a solid copper phase plug, which enhance the performance of the copper rings and improve heat conduction away from the pole piece.
    Extremely stiff and stable injection moulded metal basket keeps the critical components in perfect alignment.
    Large windows in the basket both above and below the spider reduce sound reflexion, air flow noise and cavity resonance to a minimum.
    Outside diameter 120.4mm
    Cut out 95.8mm
    Depth 58.5mm
    call
    081388575788
    klaten
    Tendang ke atas boss
    thanks yach bos danny........
  1. FS Midrange Seas Excel W12CY
    By 123evil123 in forum Speaker - SubWoofer
    Last Post: 26th October 2011, 07:00
  2. Replies: 2
    Last Post: 7th December 2009, 05:37
  3. seas excel millenium midbass w18ex-001 (sold,thanks modcom....)
    Last Post: 19th October 2009, 03:07
  4. Seas Lotus RM 110 and Seas Excel W12CY 4,5"
    By julsjazz in forum Diskusi Speaker
    Last Post: 4th April 2007, 00:36
