SOLDDDDDDD
Results 1 to 10 of 14
Thread: SOLDDDDDDD
  • Short URL:  http://modifika.si/168541
    www.gd3zone.com
    1 Wk 2 Days 15 Hrs 33 Mins 3 Secs
    SOLDDDDDDD
    misi boz2 gw mo jual power performa ZP-3500..
    neh power 2 ch..
    udah pernah d servis..
    neh speknya:
    * Ultra stable pwm (pulse width modulated) mosfet power supply
    * 2 ohm stable operation with output power increase
    * built-in crossover top control
    ch : variable hi-pass filter (40hz-1khz)
    variable low-pass filter (40hz-250hz)
    * tri-mode cap ability for simultaneous hook-up of two stereo channels and subwoofer
    * super bass control : 0-12db
    * soft-start delay turn-on circuit
    * automatic remote on/off switching
    * power on and protect led indicators
    * bult-in overload protection circuit
    * bult-in over current protection circuit
    * bult-in overheat protection circuit
    * gold plated rca input and transparent terminals
    * line out rca jack
    Technical Specification :
    4 ohms maximum output @0.03% 700Watts
    4ohms bridget mono output @0.02% THD 1 x 700W
    2 ohms WRMS output @0.1 THD 2 x 350W
    Low pass filter 40Hz - 250Hz
    High pass filter 40Hz - 1KHz
    Frequency response 10 - 40000Hz
    Signal to noise ratio 100dB
    Stereo separation >55dB
    Input sensitivity 145mV-2.4V
    Input impedance 10 Kohms
    Operation voltage DC 12V
    Speaker impedance @ stereo driven 4 Ohms
    Fuse rating 25Ax1
    Dimension (WHD) mm 280x50x244
    4 Days 5 Hrs 35 Mins 1 Sec
    yg diservis apanya bro?
    www.gd3zone.com
    ane krg tauw bro yg d servis apanya..
    yg pst kmrn prmasalahannya channelnya mati 1..
    thx...
    servisnya dmana?
    www.gd3zone.com
    gw servisnya d toko langganan gw..
    nmnya crown audio..
    thx...
    www.gd3zone.com
    uppp,upppp..
    mari dibeli....
    www.gd3zone.com
    uppppppppppppppppp..........
    galaxi,bekasi
    1 Day 8 Hrs 50 Mins 28 Secs
    harga net brp bos?....
    www.gd3zone.com
    Quote Originally Posted by dix_auto View Post
    pm sent....
    3 Hrs 59 Mins 5 Secs
    dtnggu kirimanya sob,
  1. solddddddd
    By mgn in forum Ragam Ukuran
    Last Post: 6th July 2010, 12:49
  2. SOLDDDDDDD
    By veyoo in forum Bursa Eksterior Lainnya
    Last Post: 25th February 2010, 19:52
  3. ********SOLDDDDDDD***********
    By dons_chubby in forum Merk Lainnya
    Last Post: 16th September 2009, 15:37
  4. SOLDDDDDDD............!!!!
    By vanz in forum Bursa Eksterior Lainnya
    Last Post: 6th May 2009, 01:19
  5. wts : solddddddd
    By rendra_19 in forum Jual Beli Mesin Lainnya
    Last Post: 16th February 2008, 12:12
