"CRAZY PRICE" ALPINE F1 Status 100% BARU (sold,thanks modcom..)
Results 1 to 10 of 29
  • Short URL:  http://modifika.si/168082
    Cool "CRAZY PRICE" ALPINE F1 Status 100% BARU (sold,thanks modcom..)
    CRAZY PRICE
    "ALPINE F1 Status DVI-9990 + PXI-H990" 1000% BARU Garansi Full ALPINE INDO 1 thn......sold
    CUMA ADA 1 UNIT,DIJUAL RUGI KARENA ADA YANG SUDAH BELI N GA JADI PAKAI KARENA BU MENDADAK SEBELUM DIINSTALL....
    ALPINE F1 STATUS DVI-9990
    Exceptional Sound Quality: All-digital signal transmission provides superior sound quality, realizing the full potential of CD audio.
    DVD Audio/CD Tuner DVI-9990
    US Model: DVI-9990
    European Model: DVI-9990R
    Asia & Oceania Model: DVI-9990E
    Technology
    Click on the desired product technology for more information.
    Real Metal Face
    BioLite Display
    Three-Color Illumination
    IONBUS Interface
    DVD-Audio Link
    Black Finish Mechanism & Copper-Plated Chassis
    Four-Layer PCB with S.T.A.R. Circuit
    Series Regulator
    S-Video Output
    Specifications
    Tuner section
    Tuning range US Model:
    AM: 530 - 1.710kHz ; FM: 87.7 - 107.9MHz
    European Model / Asia & Oceania Model:
    LW: 153 - 281kHz ; MW: 531 - 1.602kHz ; FM: 87.5 - 108.0MHz
    Usable sensitivity US Model:
    AM: 22.5V/27dB ; FM: 9.3dBf (0.8V/75Ω)
    LW: 31.6V/30dB ; MW: 25.1V/28dB ; FM: 9.3dBf (0.8V/75Ω)
    Stereo separation FM: 45dB or greater
    S/N ratio FM: 80dB or greater
    CD/DVD section
    System optical (compact disc)
    Number of quantum bits 1 bit
    Number of channels 2 channels (stereo)
    Dynamic range 95dB (1kHz) or greater
    High frequency distortion ratio 0.008 % (1kHz) or less
    Channel separation 90dB (1kHz) or greater
    Wow & flutter below measurable limits
    Signal system US Model: NTSC
    European Model / Asia & Oceania Model: NTSC / PAL
    Horizontal resolution 500 or greater
    Image output level 1Vp-p (75Ω)
    Image S/N ratio DVD: 75dB
    Audio S/N ratio 115dB or greater
    Frequency characteristics CD/DVD video: 5Hz 20 kHz; DVD audio: 5Hz 40kHz
    Remote control
    Power source DC 1.5V x 2 (UM-4)
    Size (W x H x D) 56 x 142.5 x 37 mm
    Weight 72 g (excluding batteries)
    Main unit
    Power source DC 14.4V (operational range: 11 16V)
    Size (W x H x D) 178 x 50 x 155 mm
    Weight 1.6 kg
    Power supply unit
    Size (W x H x D) 160 x 40 x 120 mm
    Weight 0.65 kg
    ALPINE F1 STATUS PXI-990
    Advanced Acoustic Technology: Playback is fully optimized with ultra-precise sound corrections and sound processing in real time delivering the best performance possible.
    Multimedia Manager(TM) PXI-H990
    Technology
    Compatible with DTS-ES, Dolby Digital EX, Dolby Pro Logic II, DTS Neo:6
    Burr-Brown K-Grade Sine-Magnitude 96kHz/24-bit DACs
    24-bit/8fs Digital Filter
    GIC Low-Pass Filter
    32/64-Bit Floating Point Aureus DSP
    31-Band Graphic EQ (Subwoofer: 10-band) / 10-Band Parametric EQ (Subwoofer : 2-band) / 8-Channel Variable Digital Crossover / Digital Time Correction / Road EQ / MediaXpander
    175-Band 1/3-Oct. Digital EQ
    Road EQ
    Maximum 16-Channel System
    DVD-Audio Link
    IONBUS Interface
    Specifications
    Graphic EQ bands
    BAND Front (L/R): 31 bands; Rear (L/R): 31 bands; Center: 31 bands; Subwoofer: 10 bands
    Parametric EQ bands 9dB
    Parametric EQ bands Front/Rear Center: 10 bands; Subwoofer: 2 bands
    Parametric EQ frequencies Front/Rear/Center/
    Band 1 20/22/25/28/31.5/36/40/45/50/56/63/71/80/90/
    100/110/125/140/160/180/200/220/250/280/315 (Hz)
    Band 2 31.5/36/40/45/50/56/63/71/80/90/100/110/125/140/160/180/
    200/220/250/280/315/350/400/450/500 (Hz)
    Band 3 50/58/63/71/80/90/100/110/125/140/160/180/
    200/220/250/280/315/360/400/450/500/560/630/710/800 (Hz)
    Band 4 80/90/100/110/125/140/160/180/200/220/250/280/315/360/
    400/450/500/560/630/710/800/900/1k/1.1k/1.2k (Hz)
    Band 5 125/140/160/180/200/220/250/280/315/360/400/450/
    500/560/630/710/800/900/1k/1.1k/1.2k/1.4k/1.6k/1.8k/2k (Hz)
    Band 6 200/220/250/280/315/360/400/450/500/560/630/710/
    800/900/1k/1.1k/1.2k/1.4k/1.6k/1.8k/2k/2.2k/2.5k/2.8k/3.2k (Hz)
    Band 7 315/360/400/450/500/560/630/710/800/900/
    1k/1.1k/1.2k/1.4k/1.6k/1.8k/2k/2.2k/2.5k/2.8k/3.2k/3.6k/4k/4.5k/5k (Hz)
    Band 8 500/560/630/710/800/900/1k/1.1k/1.2k/1.4k/1.6k/1.8k/
    2k/2.2k/2.5k/2.8k/3.2k/3.6k/4k/4.5k/5k/5.6k/6.3k/7.1k/8k (Hz)
    Band 9 800/900/1k/1.1k/1.2k/1.4k/1.6k/1.8k/2k/2.2k/2.5k/2.8k/
    3.2k/3.6k/4k/4.5k/5k/5.6k/6.3k/7.1k/8k/9k/10k/11k/12.5k (Hz)
    Band 10 1.2k/1.4k/1.6k/1.8k/2k/2.2k/2.5k/2.8k/3.2k/3.6k/
    4k/4.5k/5k/5.6k/6.3k/7.1k/8k/9k/10k/11k/12.5k/14k/16k/18k/20k (Hz)
    Parametric EQ frequencies Subwoofer
    Band 1 20/22/25/28/31.5/36/40/45/50/56/63/71/80/90/100/110/125 (Hz)
    Band 2 31.5/36/40/45/50/56/63/71/80/90/100/110/125/140/160/180/200 (Hz)
    Parametric EQ boost/cut range 9dB
    Time adjustment control range 0 20ms (0.05ms steps)
    Frequency characteristics 20Hz 20kHz; 20Hz 40kHz (for DVD audio playback)
    S/N ratio 110dB (IHF-A)
    Input sensitivity 1.2V (analog)
    Subwoofer crossover 20 180Hz (1/6 oct/step)
    Pre output 4V (load 10kΩ at IONBUS and DVD audio link); 2V (load 10kΩ,AUX input)
    Distortion ratio 0.01 %
    Input impedance 10kΩor greater
    Output impedance 10kΩor less
    Sound output level preout: 4V/10kΩ (maximum; front/rear); preout 4V/10kΩ (maximum; subwoofer/center; AUX IN: 1.2V/10kΩ
    Size (W x H x D) 260 x 68 x 161 mm
    Weight 2.3 kg
    call
    081388575788
    2 Days 13 Hrs 1 Min 59 Secs
    ckckckckck importir asia pasific buka lapak lg.
    tobatt bosss. duit kaga ada serinya.
    Wah2 bos satu ini..bikin org ngiler aje sama barangnya...ampun dj..kagak mampu..
    Bisa bantu heading aja..
    europe
    8 Hrs 41 Mins 14 Secs
    Up.............
    26 Mins 32 Secs
    buuseettttttt...darimana lagi nih yang fantastis kayak gini.???????ga da serinya...fulllyyyy hi end terus...
    Honoured Member
    Thumbs up Ngga ada matinye
    Mr Gasoline Spesialis Barang JDM memang TOP.....!
    Honoured Member
    Smile
    By the way penasaran juga berapa harga Nett-nya Bro Chris...?!
    wah,importirnya asia pasifik itu kan boss nelson sendiri,dari nama nick-nya aja udah ketahuan boss,alpine gitu loh.....,he..he..he...
    thanks yach bos nelson,bos david,bos hadi,bos wilcat n bos wendo....
    pm sent bos wendo,thanks........
    26 Mins 32 Secs
    pm nett dong bos..teman gw ada yang mau nih..kalo gw sih ga tahannnnnnnnn...wkwkwkwwkkwk
    BANDUNG kota surga
    1 Hr 31 Mins 23 Secs
    aduh, pemain kelas atas
    saya memantau saja sebagai orang kecil
  1. Replies: 9
    Last Post: 19th January 2012, 17:47
  2. ALPINE F1 STATUS CDA-7990R (sold,thanks modcom....)
    Last Post: 20th February 2010, 09:39
  3. SOLD....THX MODCOM WTS: ROOFRACK "THULLE" MODEL BARU 95% SEPERTI BARU
    By donnypasaribu in forum Bursa Eksterior Lainnya
    Last Post: 8th March 2009, 15:15
