KENWOOD DDX-6019 2-din (sold,thanks modcom........)
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/168078
    Cool KENWOOD DDX-6019 2-din (sold,thanks modcom........)
    KENWOOD DDX-6019 2-din 7 inch DVD player kondisi muluuuuus n segel...........sold
    General Features
    - Number of Pixel : 336,960 pixels - Screen Size : W 156.2 mm x H 82.4mm
    - Fully Motorized Slide-Down Mechanism - Multifunction Key Operation
    - DVD Disc Menu Direct Touch Operation - Audio Easy Control Mode
    - Blue Key illumination - Advanced B.M.S.[Bass Management System] with '02 eXcelon Amplifiers
    - Digital Clock (24H)
    AV Features
    - Video1 Input Signal Automatic Detection Mode [ Normal / AUTO ] - RGB Input for Navigation System
    - Attenuator [ -20db] with Smooth Volume Return - Installer Memory / Backup Memory for Keeping the Customized Setting [ even after Reset or Detach from Car Battery ]
    Single DISC Features
    - Direct Access with Remote - Random / Repeat / Scan Play
    External Media Control Features
    - DNPS [ Disc Name Presets ] with Compatible CD Changers - DNPP [ Disc Name Preset Play ] by Remote
    - CD Text Ready with Compatible CD Changers - Direct Access with Remote
    - Random / Repeat / Scan Play [ Disc / Track ]
    Tuner Features
    - FM / MW / LW 24 Station Presets [ 18FM, 6MW & LW] with Radio Text - AME [ Automatic Memory Entry]
    - Up/Down Seek Tuning
    Reverse tilt mechanism
    Depending on the vehicle,in-car monitors are installed in a variety of heights and angles,and this sometimes results in reduced visibility due to reflected glare from sunlight.In particular,vehicles such as RVs with high mounting positions suffer from this problem.Kenwood's solution is the newly developed reverse tilt mechanism : in addition to the traditional tilt mechanism that allows the bottom of the monitor to be tilted forward over 5 positions,the reverse tilt also allows the top of the monitor to tilt forward to eliminate reflected glare.
    High speed iPod Connection
    Dual Zone Settings is now at your fingertips thanks to the new interface combined with the wide touch panel display.Icons representing each zone are displayed on GUI/OSD for easy see-touch-change control of the source and volume of Zone-1 or Zone-2.
    Skin change / Wall paper Customize
    Selecting menu's from DVD video disc menu couldn't be easier than direct touch operation.With conventional systems,you have to move the cursors several times to reach the menu you want.With a touch of your finger,you can directly select menu and quickly operate.
    iPod Album Art
    Enjoy custom video on your in-car entertainment system.Video recorded on DVD±R/±RW discs in MPEG2 format the same format used for commercial DVDs - can be played back for yet another dimension in entertainment.
    Improve sound quality / Independent Midpoint Circuit
    The professional who installs your Kenwood car entertainment system sets the optimum soundfield for your vehicle and stores it in the Installer memory for instant recall at any time.In addition,Backup memory automatically stores customized settings at regular intervals.Data held in these memories are maintained even after the battery is changed or the reset button is pressed.
    Media Compatibility including DivX[Certified]
    Enjoy in-car entertainment from your iPod music collection.An interface cable and Black box allow connection of an Apple Computers iPod to the changer control terminal of the head unit for playback over the vehicle sound system.What's more,you also get display of the Playlist,Genre,Artist,and Album Names on the head unit for greater convenience.
    Kenwood Quality
    By adding rear view camera to your system,a dedicated RCA video input is available on new Kenwood's in-dash monitor systems.When selecting reverse gear,the system detects the signal from reverse line and automatically switches to the view from camera.It even features a horizontal image flip function to provide a mirror view and give the driver a correctly oriented image of the rear camera view.
    Monitor Section Picture Size [ W x H ] 6.95 inches [ diagonal ] wide 156.2 x 82.4 mm
    Display system Transparent TN LCD panel
    Drive System TFT active matrix system
    Number od Pixels 336,960
    Effective Pixels 99.99%
    Pixel Arrangement RGB striped arrangement
    Back Lighting Cold Cathode Fluorescent Tube
    DVD Section D/A Converter 24 Bit
    Decoder Linear PCM
    Dolby Digital dts
    MP3 / WMA Wow & Flutter Below Measurable Limit
    192k Sampling -
    172.4k Sampling -
    96k Sampling 20 - 44,000Hz
    88.2k Sampling -
    48k Sampling 20 - 22,000Hz
    44.1k Sampling 20 - 20,000Hz
    Total Harmonic Distortion 1kHz 0.010%
    Signal to Noise Ratio 98db [DVD-Video 96k]
    Dynamic Range 98db [DVD-Video 96k]
    DISC Format DVD-Video / VIDEO-CD / CD-DA
    Sampling Frequancy 44.1kHz / 48kHz / 96kHz
    Quantifying Bit Number 16 / 20 / 24bit
    FM Frequency Range
    [Frequency Step] 87.5MHz - 108.0MHz [50kHz]
    Usable Sensitivity S/N : 26dB 9.3dBf [0.7μV/75Ω]
    Quieting Sensitivity S/N : 46dB 15.2dBf [1.6μV/75Ω]
    Frequency Response [±3.0dB] 30Hz - 15kHz
    S/N [dB] 70dB[MONO]
    Selectivity Over 80dB [ ±400kHz]
    Stereo Separation 40dB [1kHz]
    AM Frequency Range
    [Frequency Step] LW:153-281kHz MW:531-1611kHz[9kHz]
    530kHz - 1700kHz[10kHz]
    Usable Sensitivity MW...25μV / LW...45μV
    Video Color System of External Video Input NTSC/PAL
    External Video Input Level [RCA Jacks] 1Vp-p/75Ω
    External Audio Max Input Level [RCA Jacks] 2V/25kΩ
    Analog RGB Input 0.7Vp-p/75Ω
    Audio Maximum Power [Front&Rear] 50W x 4
    Full Bandwidth Power[Front&Rear] 22W x 4[at Less than 1% THD]
    Preout Level [V] 2V/10kΩ
    Preout Impedance[Ω] 600Ω
    General Operation Voltage 14.4V[11V - 16V]
    Current Consumption 15A
    Dimensions W x H x D [mm]
    Main Unit Installation Size 182 x 112 x 163
    call
    081388575788
    2 Days 19 Hrs 33 Mins 12 Secs
    harganya brp boss?
    harganya 4,9jt bos............
    up.............
    up................
    2 Hrs 25 Mins 2 Secs
    masih garansi bos?
    ini lokasi d jkt ya
    garansi 1 bulan bos,lokasi di jakarta bos....
    Up.........
    Bandung Euy
    3 Days 2 Hrs 21 Mins 40 Secs
    Bantu up bro.....,
    thanks yach bos aming.........
  1. KENWOOD K-CD01 (sold,thanks modcom..)
    Last Post: 22nd March 2010, 02:16
  2. jual dbldin kenwood ddx 6019 ,mulus udah dvd
    By panekeer in forum Head Unit & Processor
    Last Post: 28th February 2010, 17:34
  3. KENWOOD KDV-MP735 DVD Player kondisi muluuuus (sold,thanks modcom...)
    Last Post: 25th January 2010, 13:56
