Honda B16 / B18 / B20 Racing Parts
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/167686
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    Honda B series Racing Parts - B16 / B18 / B20
    Engine Internal Parts
    Eagle Connecting Rod – H Beam
    Certified 4340 Steel ; Ready to run, installation instruction and bolt lubricant included
    C-C Length: 5.290
    Weight: 500gram
    Applications: B16A/A2/A3 DOHC Vtec – 5/16” Bolts – 1.771 Crank Pin/ .826 Piston Pin/ .935 c.e.width
    New Arrival -> Eagle Connecting Rod - H Beam for Honda B20
    Wiseco Forged Piston
    Oversize .50 Piston – High Compression 11.5:1
    Bore: 81.50 (Oversize .50) Stroke: 77.4
    Rod Length: 134.4 Comp Ht: 30
    Head cc’s: 42.7 Dome Dish: 8.25
    Gasket Thickness: 0.75 Deck Clearance: 0
    Block Ht: 203.2 Comp Ratio: 11.5:1
    Pin Dia: 21
    Juga akan masuk Wiseco Forge Piston untuk B20 Bore size 84.50 Comp 13.2
    Crower Camgear
    Crower's cam sprockets are made from premium 6061-T6 billet aluminum with a hard anodized outer gear for maximum durability, cut with an RMA standard specification cutter to insure proper tooth profile.
    The lightweight design reduces unwanted harmonics which could cause valve train failure.
    The easy to read timing scale allows for quick, accurate adjusments while the fully engraved timing marks won't fade like the cheaper laser etched or silk screened versions.
    Application: Honda B16
    Racing Camshaft
    TODA CAMSHAFT (VTEC KILLER)
    The primary and secondary lobes are designed to be the same size.
    The diameter of the main shaft has been made more uniform in size along with a hollowed out inside. This gives you a cam shaft that has increased rigidity and weight savings for improved reliability and more accurate valve timing.
    Optimized surface treatment designed to prevent wear, sticking as well as helping in the early stages of running in.
    BRIAN CROWER CAMSHAFT (STAGE 2 – N/A)
    Hot street/ strip or road race spec. Use with CAI, H, E, ECU, A/F mods.
    Excellent street manners and idle quality.
    Requires Springs and Retainers Upgrades.
    Application: Honda B16A / B18C / B17A
    Valve Spring (Dual Spring)
    BRIAN CROWER DUAL SPRING
    Designed for high RPM, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures.
    Titanium Spring Retainer
    BRIAN CROWER TITANIUM RETAINERS
    CNC machined from 6AL4V round bar titanium for longevity
    Cometic Head Gasket
    Cometic Gasket has been committed to producing superior quality gaskets for the hi-performance motorsports market.
    Bore Size 81.50
    Thickness: .030”
    ARP Head Stud
    Specially Undercut Studs
    More equalizes the “stretch” of both studs -> More consistent clamping force
    Prevent blown head gasket and assures optimum sealing!
    ACL Race Bearing
    ACL Race Series Engine Bearing design to withstand higher RPM condition
    New arrival ACL Race Bearing For B20
    Supertech Blockguard
    Supertech offers a product that will provide support to highly stressed cylinder walls with optimal engine cooling by allowing enough water flow in critical areas to avoid destructive cylinder hot spots.
    6061 aluminium alloy, designed and CNC machined for easy installation
    FUEL SYSTEM
    AEM Fuel Rail
    AEM High Volume fuel rails feature a 1/2-inch fuel bore to support fuel flow for applications up to 1,000 horsepower. This large bore also dampens backpressure pulses created by larger injectors and works perfectly with stock injector sizes. An additional 1/8th NPT port is included to accommodate a nitrous set up or fuel pressure gauge. A custom fuel line fitting is included for the factory fuel line, and the ends of each rail are pre tapped to accept -6 AN or 9/16”x18 fittings for users who want to use custom fuel lines.
    RC Injectors
    RC Engineering is the world's leading supplier of made-to-order, high-performance, electronic fuel injectors. RC injectors are available for a wide range of automotive, motorcycle and marine engines used in high-performance or racing applications.
    Size: 310cc, 370cc, 440cc
    Walbro Fuel Pump
    The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure.
    SARD Fuel Pressure Regulator
    Maintains stable fuel pressure at high-horsepower levels.
    Sensitive adjustment allows setting of optimum fuel pressure.
    Service hole in regulator perfect for pressure gauge installation or as a feed for nitrous systems or additional injector setups.
    IGNITION
    NGK Iriway Spark Plug
    NGK Iriway 7 dan Iriway 8 both are cold sparkplug and original Made in JAPAN
    Silakan contact 021-94549590 atau ke 08179845168
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Update dengan foto barang asli-nya...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Semarang-Bima-NewAnugerah-IdaCatering
    1 Day 3 Hrs 30 Mins 42 Secs
    mas sy tlng dpm aem fuel rail nd sard fuel pressurenya
    Quote Originally Posted by asbi View Post
    PM sent yaaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Pekanbaru - Riau
    1 Mth 2 Wks 19 Hrs 9 Mins 5 Secs
    Quote Originally Posted by Hydra Performance View Post
    C-C Length: 5.290
    Weight: 500gram
    Pin Dia: 21
    Crower Camgear
    Racing Camshaft
    Cometic Head Gasket
    Bore Size 81.50
    Thickness: .030”
    ARP Head Stud
    ACL Race Bearing
    FUEL SYSTEM
    AEM Fuel Rail
    RC Injectors
    Walbro Fuel Pump
    IGNITION
    Thanks,
    kira2 yg paling cocok buat performance B18DC II type R masukin apa aza yg di gbr tuh boz??
    kena brpaan total??
    thx before.........
    kena brpaan total??
    thx before.........
    Untuk B18 DC2 type R ada:
    Wiseco Piston, Crower camgear, Camshaft, Valve Springs, Retainers, RC Injectors, Walbro Fuel Pump, SARD Fuel Press, NGK Iriway Spark Plug
    Harga dikirim via PM yaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Update with some new arrival B20 Parts...
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Bintaro City
    1 Mth 3 Wks 6 Days 3 Hrs 6 Mins 6 Secs
    Asiik.. Mana niih barang" ku? Hahaha...
    Quote Originally Posted by BomZky View Post
    Hahahahahahaha...
    Sabar... sabar... kemungkinan besar di minggu ini ada barang masuk sih, dan kemungkinan besar ada di situ tuuhhh... hehehehehehehe
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Jakarta Barat
    5 Days 17 Hrs 51 Mins 27 Secs
    C-C Length: 5.290
    Weight: 500gram
    Pin Dia: 21
    Crower Camgear
    Racing Camshaft
    Cometic Head Gasket
    Bore Size 81.50
    Thickness: .030”
    ARP Head Stud
    ACL Race Bearing
    FUEL SYSTEM
    AEM Fuel Rail
    RC Injectors
    Walbro Fuel Pump
    IGNITION
    Thanks,
    bro, hrg con rod eagle & cam brian crower u/ b18c brp duit ya?..thx
  1. Replies: 1
    Last Post: 8th October 2012, 16:54
