CP PISTON MAIN DISTRIBUTOR IN INDONESIA - Page 21
Page 21 of 21 FirstFirst ... 1718192021
Results 201 to 207 of 207
  • Short URL:  http://modifika.si/167326
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    PEED'Z PERFORMANCE by STZ ,It has over 17 years’ experience and specialized in distribution high end performance engine racing parts, bring high end brake system to providing the best brake system to consumers.It is for supply With the effort of SPEED’Z strong team, excellent sales , SPEED:Z has been successfully make pre-sales and after-sales value-added services to our business partners.for call/whatsapp 081382077777-082312077777(Hans SPEED'Z PERFORMANCE)
  2. #202
    cipondoh-tangerang
    Update price BBK oktober
    AP RACING MADE IN UNITED KINGDOM
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404,HEL Brake hose,Cnter hub +adaptor.
    *dengan discbrake 285mm(min velg 15 inch) harga 24 jt
    *dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 29 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min17 inch) harga 36 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 355mm(min velg 18 inch) harga 36jt.
    *dengan discbrake 362mm(min velg 18-19 inch) harga 38 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, HEL brake ,Center hub+adptor.
    *dengan discbrake 355mm (velg min 18 inch) harga 43jt.
    *dengan discbrake 362mm (velg min 18-19 inch)harga 45 jt.
    NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose.
    ** AP discbrake floating Curved Groove 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 48 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 49 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 52 jt.
    CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 42 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 43,5 jt.
    BREMBO Made in ITALY
    Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot.brembo brake pad .duralium center bell and adaptor plug and play of specific car
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    dapetkan potongan setiap pembelianbig brake kit depan + belakang dapetkan potongan harga 3 jt (extra pemotongan for customer).
    For Order Call/Whatsapp:
    081382077777-082312077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang 11750
  3. #203
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    www.speedzperformance.com
  4. #204
    cipondoh-tangerang
    **PROMO BIG BRAKE KIT 1-10 NOVEMBER 2016**
    *dengan discbrake 285mm(min velg 15 inch) harga 22.5 jt
    *dengan discbrake 295mm(min velg 16 inch) harga 24 jt
    *dengan discbrake 330mm(min 17 inch) harga 27 jt.
    *dengan discbrake 330mm(min 17 inch) harga 28 jt.
    *dengan discbrake 330mm(min17 inch) harga 34 jt.
    *dengan discbrake 355mm(min velg 18 inch) harga 34jt.
    *dengan discbrake 362mm(min velg 18-19 inch) harga 36 jt.
    *dengan discbrake 355mm (velg min 18 inch) harga 40jt.
    *dengan discbrake 362mm (velg min 18-19 inch)harga 42 jt.
    ** AP discbrake floating Curved Groove 370mm (velg minimal 18 inch) harga 42jt
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 42 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 43 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 44 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 50 jt.
    -CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 39 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 42 jt.
    *Dengan discbrake floating drilled 330mm harga 34 Jt. (velg minimal 17 inch)
    *Dengan floating drilled discbrake 345mm harga 36 Jt.
    *Dengan floating drilled discbrake 380mm harga 40 Jt.(velg minimal 19 inch).
    **Dengan discbrake floating drilled 355mm(buat velg minimal 18 inch) harga 46 Jt.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 20 Inch) Harga 50 Jt.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 50 Jt.
    FOR ORDER CALL/WHATSAPP
    081382077777 - 082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    CENTRAL DISTRIBUTOR PERFORMANCE PARTS
    GREEN LAKE CITY RUKO CBD BLOK L NO 7
    CIPONDOH-TANGERANG 11750
  5. #205
    cipondoh-tangerang
    SPECIAL PRICE FOR AP RACING BIG BRAKE KIT
    (25 november-15 desember)
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub +adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 22.5 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 24 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub +adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 26.5 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, brake hose ,Center hub +adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 27.5 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub +adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 34 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub +adaptor.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 36 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub+adptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 40 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 42 jt.
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 44 jt.
    **dengan discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 47 jt.
    -CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 39.5 jt.
    **dengan discbrake floating jJ-hook 400 mm(velg minimal 21 inch) harga 41.5 jt.
    081382077777 -082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
  6. #206
    cipondoh-tangerang
    (NEW!!)-----RACE CALIPER PRO5000+ R-----(NEW !!)
    -CP9444 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 280mm(min velg 15 inch) harga 32 jt.
    ** dengan discbrake 295mm(min velg 16 inch) harga 34 jt.
    -CP9440 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 330mm(min velg 17 inch) harga 38 jt.
    -CP9660 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 355mm (velg min 18 inch) harga 47 jt .
    **dengan discbrake 362mm (velg min 19 inch) harga 48 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 49 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 50 jt.
    -CP9665 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 362mm (velg min 19 inch) harga 49 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 50 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 51 jt.
    **dengan discbrake 390mm (velg min 20 inch) harga 52 jt.
    UPDATE BIG BRAKE KIT AP RACING APRIL 2017
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 24 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 28 jt.
    -CP 9200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min velg 17 inch) harga 36 jt.
    -CP9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 36 jt.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 37.5 jt.
    -CP5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 45 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 46.5 jt.
    -CP 8520 Radi-Cal caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt.
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt .
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt.
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 45 jt.
    **dengan discbrake floating J-Hook 410mm (velg min 21 inch)
    harga 47 jt.
    -CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub and bolt+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 38 jt.
    **dengan discbrake floating J-Hook 400mm(velg minimal 20 inch)
    harga 40 jt.
    SPEEDZ PERFORMANCE
    instagram:speedz77777
    Twitter: speedz77777
  7. #207
    cipondoh-tangerang
    harga 47 jt.
    harga 40 jt.
    SPEEDZ PERFORMANCE
  1. PIVOT MAIN DISTRIBUTOR IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 25th February 2018, 03:40
  2. TURBOSMART MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 31st October 2016, 02:33
  3. A'PEX-i MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 6th October 2016, 16:18
  4. BRIAN CROWER MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 5th October 2016, 16:35
  5. T.M. WORKS MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 19th September 2015, 15:35
