ACL RACE BEARING MAIN DISTRIBUTOR INDONESIA - Page 16
Page 16 of 16 FirstFirst ... 1213141516
Results 151 to 152 of 152
  • Short URL:  http://modifika.si/167287
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    SPECIAL PRICE FOR AP RACING BIG BRAKE KIT
    (25 november-15 desember)
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub +adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 22.5 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 24 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub +adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 26.5 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, brake hose ,Center hub +adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 27.5 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub +adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 34 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub +adaptor.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 36 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub+adptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 40 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 42 jt.
    NEW and ready stock AP RACING World RADI-CAL Caliper new
    design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 44 jt.
    **dengan discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 47 jt.
    -CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 39.5 jt.
    **dengan discbrake floating jJ-hook 400 mm(velg minimal 21 inch) harga 41.5 jt.
    FOR ORDER CALL/WHATSAPP
    081382077777 -082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    CENTRAL DISTRIBUTOR PERFORMANCE PARTS
    GREEN LAKE CITY RUKO CBD BLOK L NO 7
    CIPONDOH-TANGERANG 11750
    www.speedzperformance.com
  2. #152
    cipondoh-tangerang
    (NEW!!)-----RACE CALIPER PRO5000+ R-----(NEW !!)
    -CP9444 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 280mm(min velg 15 inch) harga 32 jt.
    ** dengan discbrake 295mm(min velg 16 inch) harga 34 jt.
    -CP9440 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 330mm(min velg 17 inch) harga 38 jt.
    -CP9660 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 355mm (velg min 18 inch) harga 47 jt .
    **dengan discbrake 362mm (velg min 19 inch) harga 48 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 49 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 50 jt.
    -CP9665 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 362mm (velg min 19 inch) harga 49 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 50 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 51 jt.
    **dengan discbrake 390mm (velg min 20 inch) harga 52 jt.
    UPDATE BIG BRAKE KIT AP RACING APRIL 2017
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 24 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 28 jt.
    -CP 9200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min velg 17 inch) harga 36 jt.
    -CP9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 36 jt.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 37.5 jt.
    -CP5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 45 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 46.5 jt.
    -CP 8520 Radi-Cal caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt.
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt .
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt.
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 45 jt.
    **dengan discbrake floating J-Hook 410mm (velg min 21 inch)
    harga 47 jt.
    -CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub and bolt+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 38 jt.
    **dengan discbrake floating J-Hook 400mm(velg minimal 20 inch)
    harga 40 jt.
    081382077777 - 082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    instagram:speedz77777
    Twitter: speedz77777
  1. PIVOT MAIN DISTRIBUTOR IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 25th February 2018, 03:40
  2. CP PISTON MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 20th April 2017, 03:35
  3. TURBOSMART MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 31st October 2016, 02:33
  4. A'PEX-i MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 6th October 2016, 16:18
  5. T.M. WORKS MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 19th September 2015, 15:35
