PIVOT MAIN DISTRIBUTOR IN INDONESIA - Page 69
Page 69 of 69 FirstFirst ... 6566676869
Results 681 to 690 of 690
  • Short URL:  http://modifika.si/167248
    3 Days 20 Hrs 31 Mins 26 Secs
    Kalo untuk throttle controller untuk honda mobilio ada kah bos ?? dan untuk shift lamp ada brg nya ??
    kedua barang tersebut harganya brp bos ?
  2. #682
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    **PROMO BIG BRAKE KIT 1-10 NOVEMBER 2016**
    AP RACING MADE IN UNITED KINGDOM
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404,HEL Brake hose,Cnter hub +adaptor.
    *dengan discbrake 285mm(min velg 15 inch) harga 22.5 jt
    *dengan discbrake 295mm(min velg 16 inch) harga 24 jt
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 27 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 28 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min17 inch) harga 34 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 355mm(min velg 18 inch) harga 34jt.
    *dengan discbrake 362mm(min velg 18-19 inch) harga 36 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, HEL brake ,Center hub+adptor.
    *dengan discbrake 355mm (velg min 18 inch) harga 40jt.
    *dengan discbrake 362mm (velg min 18-19 inch)harga 42 jt.
    NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose.
    ** AP discbrake floating Curved Groove 370mm (velg minimal 18 inch) harga 42jt
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 42 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 43 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 44 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 50 jt.
    -CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 39 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 42 jt.
    BREMBO Made in ITALY
    Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan discbrake floating drilled 330mm harga 34 Jt. (velg minimal 17 inch)
    *Dengan floating drilled discbrake 345mm harga 36 Jt.
    *Dengan floating drilled discbrake 380mm harga 40 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan discbrake floating drilled 355mm(buat velg minimal 18 inch) harga 46 Jt.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 20 Inch) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot.brembo brake pad .duralium center bell and adaptor plug and play of specific car
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 50 Jt.
    FOR ORDER CALL/WHATSAPP
    081382077777 - 082312077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    CENTRAL DISTRIBUTOR PERFORMANCE PARTS
    GREEN LAKE CITY RUKO CBD BLOK L NO 7
    CIPONDOH-TANGERANG 11750
    www.speedzperformance.com
  3. #683
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    instagram:speedz77777
    Twitter: speedz77777
  4. #684
    cipondoh-tangerang
    (NEW!!)-----RACE CALIPER PRO5000+ R-----(NEW !!)
    -CP9444 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 280mm(min velg 15 inch) harga 32 jt.
    ** dengan discbrake 295mm(min velg 16 inch) harga 34 jt.
    -CP9440 race caliper 4 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 330mm(min velg 17 inch) harga 38 jt.
    -CP9660 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 355mm (velg min 18 inch) harga 47 jt .
    **dengan discbrake 362mm (velg min 19 inch) harga 48 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 49 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 50 jt.
    -CP9665 race caliper 6 pot pro5000+ R, AP discbrake floating slotted/J-Hook ,AP brake pad APF 402, Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 362mm (velg min 19 inch) harga 49 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 50 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 51 jt.
    **dengan discbrake 390mm (velg min 20 inch) harga 52 jt.
    UPDATE BIG BRAKE KIT AP RACING APRIL 2017
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    **dengan discbrake 285mm(min velg 15 inch) harga 24 jt .
    **dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 28 jt.
    -CP 9200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min velg 17 inch) harga 36 jt.
    -CP9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 36 jt.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 37.5 jt.
    -CP5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 45 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 46.5 jt.
    -CP 8520 Radi-Cal caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose,Center hub and bolt+adaptor.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 42 jt.
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 42 jt .
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 43 jt.
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 45 jt.
    **dengan discbrake floating J-Hook 410mm (velg min 21 inch)
    harga 47 jt.
    -CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose ,Center Hub and bolt+adaptor.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 37 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 38 jt.
    **dengan discbrake floating J-Hook 400mm(velg minimal 20 inch)
    harga 40 jt.
    SPEEDZ PERFORMANCE
  5. #685
    cipondoh-tangerang
    harga 47 jt.
    harga 40 jt.
    SPEEDZ PERFORMANCE
  6. #686
    cipondoh-tangerang
    SPEED'Z PERFORMANCE Authroized for supply AP RACING world leader stock in huge quantity for stockiest so make the Stock in very good price.
    We always develop for the update AP Racing stock start from 15 inch wheels to 22 inch using World-Radical and for Brembo Grand Turismo start from wheels 17inch to 21 inch.
    We supply for INDONESIA Exclusive market, and many installation in customer car & dealer wanted for area not in Jakarta.
    Please come and see Stock and many application before buy and all is in stock.
    UPDATE PRICE BIG BRAKE KIT AP RACING JUNE 2017
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 45 jt.
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 45 jt .
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 46 jt.
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 47 jt.
    harga 49 jt.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 38 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 40 jt.
    **dengan discbrake floating J-Hook 400mm(velg minimal 20 inch) harga 42 jt.
    Brembo Grand Turismo Made In ITALY
    -Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug n play alumunium and adaptor.
    *Dengan floating drilled discbrake 355mm harga 40 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad ,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    -BREMBO GT 8 pot,brembo brake pad ,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    Dapetkan potongan setiap pembelian Big Brake Kit depan + belakang extra 3 jt (extra pemotongan for customer)
    SPEED'Z PERFORMANCE
    Green Lake City Ruko CBD Blok L No: 7
    Cipondoh-Tangerang 11750
    Mobile no/Whatsapp : 081382077777 (Hanz SpeedZ)
    Instagram : speedz77777
  7. #687
    cipondoh-tangerang
    AP RACING BIG BRAKE KIT PRICE LIST DESEMBER 2017
    WE KEEP STOCK READY !!
    --(NEW!!)-----RACE CALIPER PRO5000+ R---(NEW !!)--
    -CP9444 race caliper 4 pot pro5000+ R, AP/CZV discbrake floating slotted/J-Hook ,AP/FERODO brake pad , Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 286mm(min velg 15 inch) harga 33 jt.
    ** dengan discbrake 295mm(min velg 16 inch) harga 33.5 jt
    -CP9440 race caliper 4 pot pro5000+ R, AP/CZV discbrake floating slotted/J-Hook ,AP/FERODO brake pad , Brake hose,Center hub and bolt+adaptor
    **dengan discbrake 300mm(min velg 16 inch) harga 37 jt.
    -CP9660 race caliper 6 pot pro5000+ R, AP/CZV discbrake floating slotted/J-Hook ,AP/FERODO brake pad , Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 332mm (velg min 17 inch) harga 43.5 jt
    **dengan discbrake 355mm (velg min 18 inch) harga 44.5 jt .
    **dengan discbrake 362mm (velg min 19 inch) harga 45.5 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 46.5 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 47.5 jt.
    -CP9665 race caliper 6 pot pro5000+ R, AP/CZV discbrake floating slotted/J-Hook ,AP/FERODO brake pad , Brake hose ,Center hub and bolt +adaptor
    **dengan discbrake 362mm (velg min 19 inch) harga 47.5 jt .
    **dengan dicsbrake 370mm (velg min 19 inch) harga 48.5 jt.
    **dengan discbrake 380mm (velg min 19-20 inch) harga 49.5 jt.
    **dengan discbrake 390mm (velg min 20 inch) harga 50.5 jt.
    UPDATE PRICE PERFORMANCE BIG BRAKE KIT AP RACING
    -CP7600 caliper 4 pot ,AP/CZV disbrake floating slotted ,AP/FERODO brake pad , Brake hose,Center hub and bolt+adaptor.
    **dengan discbrake 280mm Curved (min velg 15 inch) harga 27.5 jt
    **dengan discbrake 286mm J-Hook (min velg 15 inch) harga 27.5 jt
    **dengan discbrake 295mm Curved (min velg 16 inch) harga 28.5 jt.
    **dengan discbrake 296mm J-Hook (min velg 16 inch) harga 28.5 jt.
    -CP 9200 caliper 4 pot , AP/CZV discbrake floating slotted, AP/FERODO brake pad , Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min 17 inch) harga 32 jt.
    -CP5040 race caliper 4 pot pro5000+, AP/CZV discbrake floating slotted, AP/FERODO brake pad , Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 330mm(min velg 17 inch) harga 36.5 jt.
    -CP9040 caliper 6 pot , AP/CZV disbrake floating slotted , AP/FERODO brake pad , Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm(min velg 18 inch) harga 39 jt.
    **dengan discbrake 362mm(min velg 18-19 inch) harga 40 jt.
    -CP5060 race caliper 6 pot pro5000+, AP/CZV disbrake floating slotted , AP/FERODO brake pad , Brake hose ,Center hub and bolt+adaptor.
    **dengan discbrake 355mm (velg min 18 inch) harga 42.5 jt.
    **dengan discbrake 362mm (velg min 18-19 inch)harga 43.5. jt.
    ** AP discbrake floating Curved Groove 370mm (velg min 18 inch) harga 50 jt.
    **dengan discbrake floating J-hook 370mm (velg min 18 inch) harga 50 jt .
    **dengan discbrake floating J-hook 380mm (velg min 19 inch) harga 51 jt.
    **dengan discbrake floating J-hook 390mm (velg min 20 inch) harga 52 jt.
    **dengan discbrake floating J-Hook 410mm (velg min 21 inch) harga 54 jt.
    **dengan discbrake Floating J-hook 360 mm(velg minimal 18 inch)harga 44 jt.
    **dengan discbrake floating J-hook 380 mm(velg minimal 19 inch) harga 46 jt.
    **dengan discbrake floating J-Hook 400mm(velg minimal 20 inch) harga 48 jt.
    SPEED'Z PERFORMANCE
  8. #688
    cipondoh-tangerang
    SPEED'Z PERFORMANCE
  9. #689
    cipondoh-tangerang
    AP RACING BIG BRAKE KIT PRICE LIST FEBRUARY 2018
    **dengan discbrake 332mm(min velg 17 inch) harga 38 jt
    NEW WORLD RADI-CAL 2
    -CP9560 Radi-Cal II caliper 6 pot,AP discbrake floaing slotted,AP/Ferodo Racing Brake pad,Brake hose,Centre Hub and Bolt+Adaptor.
    **dengan discbrake 356mm(velg min 18 inch) harga 50 jt
    **dengan discbrake 370mm (velg min 19 inch) harga 52 jt
    **dengan discbrake 380mm (velg min 19 inch) harga 53 jt
    ** dengan discbrake 390mm (velg min 20 inch) harga 54 jt
    -CP9540 Radi-Cal II caliper 4 pot,AP discbrake Floating Slotted ,AP/Ferodo Racing Brake Pad,Center Hub and Bolt+Adaptor.
    **dengan discbrake 362mm (velg min 18-19 inch) harga 46 jt
    **dengan discbrake 380mm (velg min 19 inch) harga 48 jt
    SPEED'Z PERFORMANCE
  10. #690
    cipondoh-tangerang
    —BRIAN CROWER PRICELIST FEBRUARY 2018—
    HONDA
    -CUSTOM HIGH PROFILE CAMSHAFT NEW JAZZ HARGA 12.5 JT
    -BC0080 R18 VALVE SPRING KIT HARGA 5.750 JT
    -BC0089 L15 VALVE SPRING KIT HARGA 5.5 JT
-BC3014/15 B16A/B18C VALVEKIT O/S 1MM HARGA 5.5 JT
    -BC2940 B16A/B18C VALVE KEEPERS/LOCK HARGA 1.5 JT
-BC3074/75 D16Y8/D16Z6 VALVE KIT O/S 1MM HARGA 5.5 JT
- BC6005 L15 CONNECTING ROD H-BEAM HARGA 7.5 JT
- BC6064 F22C CONNECTING RODH-BEAM HARGA 7.5 JT
-BC6008 R18 CONNECTING ROD H-BEAM HARGA 7.5 JT
-BC0070 D16Y8/D16Z6 VALVE SPRING WITH RETAINER TITANIUM HARGA 5.5 JT
    MAZDA
    -BC6999 MAZDA 2 CUSTOM CONNECTING ROD HARGA 7.5 JT
    NISSAN
    -BC0206 SR20DET S14 STAGE 3 CAMSHAFT HARGA 6.5 JT
    -BC6239 RB26TT CONNECTING ROD H-BEAM HARGA 11.250 JT
    -BC0230 RB26DETT VALVE SPRING WITH RETAINER TITANIUM HARGA 8.250 JT
    TOYOTA
    -BC2950 2JZGTE VALVE KEEPERS HARGA 2.250 JT
    -BC0300 2JZGTE VALVE SPRING WITH RETAINER TITANIUM HARGA 8.250 JT
    -BC0330 YARIS VALVE SPRING WITH RETAINER TITANIUM HARGA 5.5 JT
    -BC0330 1ZZ VALVE SPRING WITH RETAINER TITANIUM HARGA 5.5 JT
    SUBARU
    -BC3604/05 EJ207/257 VALVE KIT O/S 1 MM HARGA 5 JT
    -BC6609 EJ207/257 CONNECTING ROD H-BEAM HARGA 7.5 JT
    -BC2960 EJ207/257 VALVE KEEPERS HARGA 1.5 JT
    -BC0600 EJ207/257 VALVE SPRING WITH RETAINER TITANIUM HARGA 5.5 JT
    -BC8860 EJ205/257 ADJUSTABLE CAM GEAR SET/4 HARGA 9.5 JT
    MITSUBISHI
    -BC3104/05 4G63 EVO VALVE KIT O/S 1MM HARGA 5 JT
    -BC6109 4G63 EVO CONNECTING ROD H-BEAM HARGA 7.5 JT
    SPEED'Z PERFORMANCE
Venom 300x250 GT Radial
  1. CP PISTON MAIN DISTRIBUTOR IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 20th April 2017, 03:35
  2. TURBOSMART MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 31st October 2016, 02:33
  3. A'PEX-i MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 6th October 2016, 16:18
  4. BRIAN CROWER MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 5th October 2016, 16:35
  5. T.M. WORKS MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 19th September 2015, 15:35
