TURBOSMART MAIN DISTRIBUTOR IN INDONESIA
Results 1 to 10 of 101
  • Short URL:  http://modifika.si/167204
    cipondoh-tangerang
    5 Mths 3 Wks 11 Hrs 37 Mins 59 Secs
    [/SIZE]kami selaku main distributor turbosmart menyediakan semua product turbo smart
    http://www.turbosmartonline.com/index.php?id=67
    ALL TURBOSMART PRODUCT READY STOCK
    CONTACT WWW.SPEEDZPERFORMANCE.COM
    Visit Our Workshop At MUARA KARANG RAYA NO:11 . Phone:021-66602331-66602332
    BOV
    EXTERNAL WASTEGATE
    SILICONE HOSE
    our ready stock product:
    45 DEGREE ELBOWS
    DIAMETER PART NUMBER
    0.75" (19mm) TS-HE45075-BE
    1.00" (25mm) TS-HE45100-BE
    1.25" (32mm) TS-HE45125-BE
    1.50" (38mm) TS-HE45150-BE
    1.75" (45mm) TS-HE45175-BE
    2.00" (50mm) TS-HE45200-BE
    2.25" (57mm) TS-HE45225-BE
    2.50" (63mm) TS-HE45250-BE
    2.75" (70mm) TS-HE45275-BE
    3.00" (76mm) TS-HE45300-BE
    3.50" (89mm) TS-HE45350-BE
    4.00" (102mm) TS-HE45400-BE
    45 DEGREE ELBOW REDUCER PART NUMBER
    2.25-2.50” (57-63mm) TS-HRE42225-BE
    90 DEGREE ELBOWS
    1.00" (25mm) TS-HE90100-BE
    1.25" (32mm) TS-HE90125-BE
    1.50" (38mm) TS-HE90150-BE
    1.75" (45mm) TS-HE90175-BE
    2.00" (50mm) TS-HE90200-BE
    2.25" (57mm) TS-HE90225-BE
    2.50" (63mm) TS-HE90250-BE
    2.75" (70mm) TS-HE90275-BE
    3.00" (76mm) TS-HE90300-BE
    3.50" (89mm) TS-HE90350-BE
    4.00" (102mm) TS-HE90400-BE
    90 DEGREE ELBOW REDUCERS PART NUMBER
    2.00-2.50” (50-63mm) TS-HRE92025-BE
    2.55-3.00” (63-76mm) TS-HRE92530-BE
    REINFORCED HUMP HOSES
    2.00" (50mm) TS-HH200-BE
    2.25" (57mm) TS-HH225-BE
    2.50" (63mm) TS-HH250-BE
    2.75" (70mm) TS-HH275-BE
    3.00" (76mm) TS-HH300-BE
    3.50" (89mm) TS-HH350-BE
    4.00" (102mm) TS-HH400-BE
    STRAIGHT HOSES – PRE-CUT (2 ”)
    1.00" x 2 3/8" (25mm x 60mm) TS-HS100060-BE
    1.10" x 2 3/8" (28mm x 60mm) TS-HS110060-BE
    1.25" x 2 3/8" (32mm x 60mm) TS-HS125060-BE
    1.50" x 2 3/8" (38mm x 60mm) TS-HS150060-BE
    1.75" x 2 3/8" (45mm x 60mm) TS-HS175060-BE
    2.00" x 3.00" (50mm x 75mm) TS-HS200075-BE
    2.25" x 3.00" (57mm x 75mm) TS-HS225075-BE
    2.50" x 3.00" (63mm x 75mm) TS-HS250075-BE
    2.75" x 3.00" (70mm x 75mm) TS-HS275075-BE
    3.00" x 3.00" (75mm x 75mm) TS-HS300075-BE
    3.25" x 3.50" (83mm x 90mm) TS-HS325090-BE
    3.50" x 3.50" (89mm x 90mm) TS-HS350090-BE
    3.75" x 3.50" (95mm x 90mm) TS-HS375090-BE
    4.00" x 3.50" (102mm x 90mm) TS-HS400090-BE
    STRAIGHT HOSES - FULL LENGTHS (3 FOOT)
    1.00" x 3.00' (25mm x 915mm) TS-HS100915-BE
    1.10" x 3.00' (28mm x 915mm) TS-HS110915-BE
    1.25" x 3.00' (32mm x 915mm) TS-HS125915-BE
    1.50" x 3.00' (38mm x 915mm) TS-HS150915-BE
    1.75" x 3.00' (45mm x 915mm) TS-HS175915-BE
    2.00" x 3.00' (50mm x 915mm) TS-HS200915-BE
    2.25" x 3.00' (57mm x 915mm) TS-HS225915-BE
    2.50" x 3.00' (63mm x 915mm) TS-HS250915-BE
    2.75" x 3.00' (70mm x 915mm) TS-HS275915-BE
    3.00" x 3.00' (76mm x 915mm) TS-HS300915-BE
    3.25" x 3.00' (83mm x 915mm) TS-HS325915-BE
    3.50" x 3.00' (89mm x 915mm) TS-HS350915-BE
    3.75" x 3.00' (95mm x 915mm) TS-HS375915-BE
    4.00" x 3.00' (102mm x 915mm) TS-HS400915-BE
    REDUCERS
    1.25" - 1.75" TS-HR125175-BE
    1.50" - 1.75" TS-HR150175-BE
    1.50" - 2.00 TS-HR150200-BE
    1.75" - 2.00" TS-HR175200-BE
    1.75" - 2.25" TS-HR175225-BE
    1.75" - 3.00" TS-HR175300-BE
    2.00" - 2.25" TS-HR200225-BE
    2.00" - 2.50" TS-HR200250-BE
    2.00" - 2.75" TS-HR200275-BE
    2.00" - 3.00" TS-HR200300-BE
    2.00" - 3.25" TS-HR200325-BE
    2.25" - 2.50" TS-HR225250-BE
    2.25" - 2.75" TS-HR225275-BE
    2.25" - 3.00" TS-HR225300-BE
    2.50" - 2.75" TS-HR250275-BE
    2.50" - 3.00" TS-HR250300-BE
    2.50" - 3.25" TS-HR250325-BE
    2.75" - 3.00 " TS-HR275300-BE
    2.75" - 3.50" TS-HR275350-BE
    3.00" - 3.25" TS-HR300325-BE
    3.00" - 3.50" TS-HR300350-BE
    3.00" - 4.00" TS-HR300400-BE
    3.25" - 4.00" TS-HR325400-BE
    3.50" - 3.75" TS-HR350375-BE
    3.50" - 4.00" TS-HR350400-BE
    SILICONE TEE
    IMP SIZE/SPOUT SIZE PART NUMBER
    1.00" Outlet. Suits 2.00” (50mm) plumbing TS-HT200100-BE
    1.00" Outlet. Suits 2.50” (63.5mm) plumbing TS-HT250100-BE
    1.50" Outlet. Suits 2.00” (50mm) plumbing TS-HT200150-BE
    1.50" Outlet. Suits 2.25” (57mm) plumbing TS-HT225150-BE
    1.50" Outlet. Suits 2.50” (63.5mm) plumbing TS-HT250150-BE
    1.50" Outlet. Suits 2.75” (70mm) plumbing TS-HT275150-BE
    1.50" Outlet. Suits 3.00” (76mm) plumbing TS-HT300150-BE
    VACUUM HOSES (3M PACKS)
    REGULAR PART NUMBER
    0.12" x 10' (3mm x 3m) BLUE TS-HV0303BE
    0.12" x 10' (3mm x 3m) BLACK TS-HV0303BK
    0.12" x 10' (3mm x 3m) RED TS-HV0303RD
    0.16" x 10' (4mm x 3m) BLUE TS -HV0403BE
    0.16" x 10' (4mm x 3m) BLACK TS -HV0403BK
    0.16" x 10' (4mm x 3m) RED TS -HV0403RD
    0.20" x 10' (5mm x 3m) BLUE TS -HV0503BE
    0.20" x 10' (5mm x 3m) BLACK TS -HV0503BK
    0.20" x 10' (5mm x 3m) RED TS -HV0503RD
    0.24" x 10' (6mm x 3m) BLUE TS -HV0603BE
    0.24" x 10' (6mm x 3m) BLACK TS -HV0603BK
    0.24" x 10' (6mm x 3m) RED TS -HV0603RD
    REINFORCED PART NUMBER
    0.25" x 10' (6.3mm x 3m) BLUE TS-HV06303BE
    0.25" x 10' (6.3mm x 3m) BLACK TS-HV06303BK
    STAINLESS STEEL CONSTANT TENSION CLAMPSPART NUMBER
    1.125-1.500" (28-38mm) TS-HCT-M033
    1.375-1.875" (35-48mm) TS-HCT-M042
    1.625-2.375" (41-60mm) TS-HCT-M050
    1.970-2.875" (50-73mm) TS-HCT-M062
    2.500-3.375" (64-86mm) TS-HCT-M075
    2.750-3.625" (70-92mm) TS-HCT-M081
    3.500-4.375" (89-111mm) TS-HCT-M0100
    BOOST CONTROLER
    e-Boost STREET 40psi
    e-Boost2 – 60psi
    MANUAL BOOST CONTROLLER
    Boost Tee
    In-Cabin
    Single Stage
    Dual Stage
    BOV
    RACE PORT
    DUALPORT
    SUPERSONIC
    PLUMB BACK
    VEE PORT
    WASTEGATES
    POWER-GATE60
    PRO-GATE50
    HYPER-GATE45
    ULTRA-GATE38
    FUEL CUT DEFENDERS
    Malang
    1 Wk 44 Mins 30 Secs
    buat pipa turbo 2" brp harganya
    Cikarang
    15 Hrs 10 Mins 53 Secs
    Boss, minta pm nett price unruk part berikut:
    1. 2.25" (57mm) TS-HE45225-BE
    2. 2.50" (63mm) TS-HE45250-BE
    3. 2.25" - 2.50" TS-HR225250-BE
    4. 1.970-2.875" (50-73mm) TS-HCT-M062
    5. 2.25" (57mm) TS-HE90225-BE
    6. 2.50" (63mm) TS-HE90250-BE
    7. 2.25" x 3.00" (57mm x 75mm) TS-HS225075-BE
    8. 2.50" x 3.00" (63mm x 75mm) TS-HS250075-BE
    Thanx.
    cipondoh-tangerang
    Quote Originally Posted by bsyahbandar View Post
    Thanx.
    dateng ke toko aja bro harga langsung dikasih
    cipondoh-tangerang
    Quote Originally Posted by sandi_speed View Post
    250 ribu bro harganya
    Cikarang
    Quote Originally Posted by [speed'Z] View Post
    jadinya yang ini aja boss,
    2.50" - 3.00" TS-HR250300-BE = 1 pc saja,
    pm nett nya ya..
    cipondoh-tangerang
    pm nett nya ya..
    harga 350 ribu
    cipondoh-tangerang
    SALE TURBOSMART 15% DI BULAN MARET
    SPEED'Z ADAKAN SALE HANYA DI BULAN MARET SEBESAR 15% UTK PEMBELIAN PRODUCT TURBOSMART...JANGAN LEWATKAN KESEMPATAN INI!!!...
    cipondoh-tangerang
    Smile
    all item now in stock....
    cipondoh-tangerang
    Talking
    nikmati diskon 15 % utk pembelian barang2 turbosmart
  1. PIVOT MAIN DISTRIBUTOR IN INDONESIA
    By [speed'Z] in forum Speed'Z Performance
    Last Post: 14th February 2018, 05:12
  2. CP PISTON MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 20th April 2017, 04:35
  3. A'PEX-i MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 6th October 2016, 17:18
  4. BRIAN CROWER MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 5th October 2016, 17:35
  5. T.M. WORKS MAIN DISTRIBUTOR IN INDONESIA
    Last Post: 19th September 2015, 16:35
