ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, Silver Cone
Results 1 to 10 of 31
  • Short URL:  http://modifika.si/166720
    BAndunG
    1 Mth 1 Wk 3 Days 2 Hrs 2 Mins 38 Secs
    The Scan-speak 23W/4557T is a very high end subwoofer, designed to be used with a passive radiator in a small enclosure. This sub has a very rigid aluminum cone, low loss rubber surround and cast frame. The passive radiator is similar, but with a weight attached to the bass of the cone. The 23W/4557T is using the SD-1 motor system. There are gold plated binding posts and the woofer is covered by a decorative rubber cap.
    Frequency response with the passive is down to 25Hz. One cubic foot sealed has an F3 of 33Hz.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 82 dB
    Free air resonance Fs 20.5 Hz
    DC resistance 3.45 ohm
    V.C. inductance 0.45 mH
    Power 225 W
    Effective cone area 232 cm2
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Lin. & max. excursion 13 / 20 mm
    Air gap flux density -
    Force factor BL Product 9.3 Tm
    Moving mass incl. air 101 g
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Outside diameter: 255mm
    Cut out: 225mm
    Depth: 135mm
    25.4mm = 1" = 2.54cm
    Mint Conditions
    Lengkap Dus
    Price 2,8jt ( nego )
    Call / sms only 0855 21888 18
    WhatsApp *0855 21888 18*
  2. 36Goal.com
    1 Wk 2 Days 5 Hrs 37 Mins 20 Secs
    Hmmmmm SUb bgs nih....
    15 Hrs 23 Mins 26 Secs
    up............
    bandunk
    20 Hrs 16 Mins 30 Secs
    angkad ke atassssss
    Honoured Member
    Thumbs up
    One of the best sounding subwoofer.....bantu up dech
    BAndunG
    thanks buat bos bos di atasss............
    BAndunG
    up..............
    4 Hrs 24 Mins 53 Secs
    bro...itu 23w harganya pair ato pcs?
    bandunk
    wah masa pair harga segitu,1pcs kalee yah
    BAndunG
    Huehehehehehe......
    Itu harga 1 pcs boss.........
Venom 300x250 MBtech
  1. DLS Ultimate UR12 Magnesium Cone Subwoofer kondisi muluus...........
    Last Post: 3rd November 2011, 12:25
  2. Replies: 13
    Last Post: 16th January 2010, 09:15
  3. Replies: 51
    Last Post: 14th November 2009, 06:29
