How to upgrade your 4age to 7age
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/16638
    Pacific
    Dapet artikel bagus ni di internet buat 4age lovers...mudah2xan berguna deh...cheers
    Things you need :
    - 4AGE engine (you should have one of these!)
    - late 7AFE engine with metal head gasket
    - Brown injectors from 1985 Celica GT(3SGE engine)
    - Adjustable cam pulleys (piper cams)
    - Timing belt (Porsche 944 1986) there are two belts listed the one required is the timing belt not the countershaft belt
    - 212mm clutch AE92 corolla GTI 1992
    - 3/4inch water hose about 5cm
    It is good to have a manual with you for torque settings and detailed information on the individual jobs you will undertake.
    Stage one - remove 4age
    Work methodically around the engine removing bolts and wires, label anything you don't know or may confuse you if you forget.
    Return removed bolts to their holes (this is because some bolts are made to be tightened up harder than others which just snap! I learnt the hard way so you don't have to! More on this later)
    Remove radiator for space
    It is the lower 17mm nut on the engine mount, which needs to be removed (the hidden one which is awkward to access) this needs to be undone not the top one!
    I removed the sandwich plate behind the oil filter because it is easier to access than the oil line (to the oil cooler) and is the same as the one on 7AFE wrap in a plastic bag and check the seal has not fallen off the back.
    Cable tie the wiring looms and oil cooler pipes out of the way in the engine bay
    Lift out engine using the hooks on the top and an engine crane
    Stage 2 - building 7AGE
    Again work methodically around the engine finishing each area properly so you don't forget anything
    Strip down 4age engine you need everything apart from the block
    Leave intake manifold connected to the head, camshafts must be removed to access head bolts, take care to note the loosening pattern and orientation of camshaft bearing caps - see manual
    When removing the head remember to loosen the bolts in the correct pattern - see manual
    When removing parts especially the engine mounts take care to return the nuts and bolts to their holes so you know which are used for what and what holes on the block are utilised (more on this later)
    Use two nuts locked against each other to remove studs then return them finger tight to their original holes.
    Strip down 7AFE engine only, the bottom end is required so remove all other mounts, timing gear etc
    When removing the head remember to loosen the bolts in the correct pattern and leave them in the head in their original positions so you can make sure the same ones go back in the same holes later on
    Take care with the head gasket it should be a nice 2 layer metal one (if it isn't order this from Toyota)
    Clean head and block mating surfaces I used some emery paper and a Hoover to Hoover out all the dust created!! Clean the head gasket
    Bolt 4AGE head on to 7AFE block using the original 7AFE head bolts, each back to their original positions. use correct tightening pattern first all to 29nm then each through a further 90 degrees then all again through a further 90dgrees, see manual
    Return camshafts and tighten camshaft bearing caps in the correct order facing the correct way (they are each labelled on the top with an arrow and number like E1 which stands for exhaust side first bearing cap (the closest to the cam pulley) E2, E3, I1, I2, I for inlet side etc)
    You may need to clean them to see the markings add some engine oil to all the bearing surfaces before tightening the bearing caps. Return cam covers, bearing caps and cam covers to 13nm
    Transfer the water pump and all its pipe work it should all come off 4AGE as one piece with three 12mm (15nm) bolts on the front of the block, use the seal from the 7AFE pump as it is probably a bit newer, clean the mating faces. The pipe support bracket on the side of the engine block cannot be used I just left it as it seemed secure enough you could make a simple bracket to hold it.
    The water pump to head pipe needs to be extended, just cut it in half put the 3/4inch hose over, you only need about 5cm and clamp with two jubilee clips.
    Fit adjustable timing pulleys, firstly mark them against the original pullys for the original timing marks. make marks on the new pulleys by drilling a shallow 3mm hole where the timing mark should be (the same place and fashion as on the original 4AGE ones (the small indent on the rim) check the right one is on the right side as they are different see manual for orientation
    Fit the lower timing belt pulley from the 4AGE engine to the crankshaft
    Line all the timing marks up then fit Porsche 944 timing belt, re adjust the tensioner to take up the slack
    The lower timing belt cover from 4AGE needs to be modified to fit, look at it from the back there will be a second outer circle around the hole for the crankshaft just file it out to this outer hole and it will fit nicely
    You will notice the camshaft pulley timing marks do no line up correctly when the lower pulley mark is lined up. Use the adjustment on the cam pulleys to retard each camshaft by approximately 3-4 degrees to so it all lines up nicely
    The middle timing belt cover will no longer fit
    On to the back of the engine
    Remove 4AGE flywheel and bell housing backing plate, clean the backing plate and transfer it to the 7A block (9nm)
    Bolt on the 7AFE flywheel using the correct bolt pattern (74nm)
    Bolt on your new 212mm clutch (a nice little upgrade) (19nm)
    On to the left hand side
    Check which holes are used by looking at the 4AGE block:
    Run through these with a thread tap!!! If you don't what will happen tome will happen to you! I used a different bolt, which just sheared off in my block because it was not intended for that much torque and the thread was too stiff!! Long!
    Transfer all the studs and fit the engine mount and alternator bracket, the lower gearbox mounts can no longer be used as they don't line up chuck them away.
    The intake manifold support needs to be extended I did this by making a simple extension bracket at the top
    You might as well fit alternator and belt
    The right-hand side
    Run through these with a thread tap!!! If you don't what will happen to me will happen to you! I used a different bolt, which just sheared off in my block because it was not intended for that much torque and the thread was too stiff!! Long!
    Transfer all the studs and fit the engine mount, the lower gearbox mounts can no longer be used as they don't line up chuck them away. Fit the block earth lead and starter motor loom clip which should have come off with the engine mount from 4AGE
    Remove the oil filter sandwich plate
    You might as well fit the starter motor
    Top
    Change injectors take care not to damage the fragile seals, in fact you should replace upper and lower seals as they are probably very worn out! When I replaced my injector lower seals I thought the guy gave me the wrong part it looked so different to the deformed old thing I took out!
    A tab must be cut off the Celica injectors try one on a injector plug and you will see which tab needs cutting use a sharp knife then the plug will fit like normal
    Stage 3 - return engine
    Drop it back in you will have to wiggle it around to get it on the lay shaft from the gearbox jack the gearbox up this helps
    Refit all bolt and wires work methodically around the engine and make sure everything is done before moving to the next area
    Fit the oil cooler sandwich plate which you wrapped in plastic and a new oil filter
    Check the oil line up the distributor (see manual)
    Fire it up! Set the ignition timing I found the original marks on the lower timing cover not to line up it shows about 3 degrees too much advance so take this into account when you set the timing (again i learnt the hard way experiencing detonation after 7000RPM !)
    Experience a 4age with a killer torque band, the rear tyres have no chance!!! I was a very happy bunny indeed
    ps it doesnt like being reved over 7k and power drops off at about 6700 so this is where i have set my shift light, it pulls hard untill then.
    If anyone has any questions or queries post them and I will try and edit this post to incorporate the answers!
    after 300+ miles now the engine hasnt blown up so im pretty chuffed, and after much testing against a close friend last night i can safley say the engine has lost no pace despite the reduced redline and changing gear early, (this was a fear of mine because there is normally always a trade off) the new torque band just pulls it through the gears, i never thought id say this but torque really is very exciting too on the street adding a whole new dimension to the corolla!
    calculations for compression ratio:
    compression ratio = swept volume + clearance volume / clearance volume
    clearance volume = head gasket thickness + piston to block deck clearance + combution chamber volume + dish in piston
    swept volume = cross sectional area of bore x stroke - dish in piston
    values for 7AGE
    head gasket thickness 0.266mm (when compressed) (based on when a 0.8 3 layer TRD metal headgasket is compressed it becomes 0.4mm (taken from club4ag.com) so 2/3 of this value is taken (because this was a two layer metal head gasket)
    piston to clyinder deck clearance on 7AFE block 0.3mm (taken from club4ag.com)
    combustion chamber volume for 4AGE head 39cc (taken from club4ag.com)
    dish in piston 73mm diameter with 3mm depth (aproximate value i would apreciate a more acurate measurment)
    bore and stroke = 81 and 85.5mm
    so clearance volume = (values changed to cm for continuity)
    = [ pi 8.1 ^2 / 4 x 0.0266 ] + [ pi 8.1 ^2 / 4 x 0.03 ] + [ 39 ] +[ pi 7.3 ^2 / 4 x 0.3 ]
    = 1.3707 + 1.5459 + 39 + 12.5562
    = 54.4728
    = pi 8.1 ^2 /4 x 8.55 - 12.5562
    = 428.025
    so
    = 428.025 + 54.4728 / 54.4728
    = 8.86
    inter_island lovesong
    bintaro
    4 Days 8 Hrs 18 Mins 52 Secs
    tau gini gw belajar matematik yg bener pas sma deh...
    Banten
    nice info boss...
    tp ribet juga yah.....
    mending 4age16 di maksimal aja deh......
    ya mending ag 20 kemana2 lah
    torsinya jg beda lumayan jauh
    Peak power sells cars. High average power wins races.
    http://img99.imageshack.us/img99/1110/signnb1.jpg
    BJAmodified Bandung
    6 Days 18 Hrs 39 Mins 17 Secs
    Quote Originally Posted by ndud
    Black top :smt007
    RETROtuning ft BJAmodified
    Drag..Drift..4WD
    Daily tuning,N/A or Turbo tuning,Rollcage/tubular chassis,Retuning ECU,Standalone engine management system,Repainting,Reinforce chassis,Etc
    jakarta timur
    9 Hrs 9 Mins 19 Secs
    gw ada 7afe 4biji neeh ada yg maw??....
    S.O.E.R.A.B.A.I.A
    2 Wks 1 Hr 6 Mins 40 Secs
    Quote Originally Posted by -oWizz-
    pokoknya semua tersedia di " tokonya " Owizz,,hehhe :smt003 :smt003 :smt003
    TSVC
    2 Wks 1 Day 17 Hrs 2 Mins 55 Secs
    puyeng gw bacanya
    Instagram: @rizkybas
    4 Days 8 Hrs 20 Mins 52 Secs
    iki boso opo yo..??
    aku ora ngerti...
    huahuahua..
    makasih...
    Pacific
    waduh...sorry dong kalo jadi bingung...gw juga gak ngerti sebenernya...gw post disini, biar kalo ada yg ngerti bisa bantuin jelasin...hehehe
Venom 300x250 Wuling
  1. ASK 7AGE atau 4AGE black top atau 3S
    By devildriver_mgarage in forum Diskusi Mesin
    Last Post: 22nd December 2010, 20:00
  2. QUICK SALEE>7AGZE SUPERCHARGE OR 7AGE+4barell
    By tiger 86 in forum Jual Beli Mesin Lainnya
    Last Post: 4th September 2010, 19:45
  3. [HELP] mau upgrade HU Pioneer 9450 upgrade ke ..... ???
    By tse in forum Diskusi Head Unit & Processor
    Last Post: 25th May 2008, 02:29
