Highlights
# Power Output: 50W x 4
# MOS-FET Power Amp
# GIGA MP3
# Digital 7-Band iEQ
# DVD-R/-RW/VCD Compatible
# MP3/WMA Compatible with ID3/WMA Tag
# CD/CD-R/CD-RW Compatible
# DTS/Dolby Digital/MPEG Audio
# 10-bit/54MHz Video DAC
# 24-bit Resolution 1-bit DAC
# Adjustable Line Input Terminals
# Line Output Terminals
# Video Output Terminals
# Optical Digital Output
# Flip-down Face
# Rotary Encoder Multi-Control
# Multi-Function Wireless Remote Control
DVD/VCD Section
# Video Format: NTSC/PAL
# Zoom (for DVD)*
# Chapter Access (for DVD)
# Pause/Step/Slow*
# VCD Playback Control
# Direct Track Access (for VCD)
*Remote control only
CD Section
# CD Text
# Disc Name Registration
# Random/Repeat Play
# +/- 10 Skip Function
Changer Control Section
# MP3 Control*
# CD Text*
# Direct Disc Select (1-12)
# Skip/Search
# +/- 10 Skip Function*
* In conjunction with CH-X1500.
Tuner Section
# HS-II Tuner
# 18 FM and 6 AM Presets
# Station Name Registration
# SSM (for FM)
# Seek (Up/Down)
# AFNS/PNC
# Stereo/Mono Switch (for FM)
# Auto Antenna
Amplifier Section
# Source-Specific Volume Control
# Balance/Fader Control
# Volume Attenuator
# Max. Amp Gain Switcher
Display Section
# Switchable Dimmer
# Level Meter
# General Section
# Detachable Control Panel with Carrying Case
# COMPU PLAY
# Tel. Muting
# Power-Off Mode Eject
# Preferred Setting Mode
gmn ? kira2 worth ga ya arga 2,65 jt ? ...
