-H.P- TIAL Blowoff type Q - SOLD OUT
  • Short URL:  http://modifika.si/165539
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    TIAL BLOWOFF
    Considered as the best Blowoff in the market
    Type Q
    Q is the first revision of the nine year old original TiAL BOV. The Q bolts right up to any standard TiAL flange, no re-welding needed.
    For use on turbo-charged and super-charged applications (Paxton, Vortec, etc.). The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve.
    The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance.
    The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance.
    The Blow Off Valve also comes with our own machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life.
    An aluminum or mild steel weld base mounting flange is furnished with each unit. Stainless Steel is available at an additional cost. The use of 6061 aluminum allows the housing to be anodized with a selection of colors.
    Through countless hours of R&D we were able to make the same size valve flow a staggering 60% more than the original design - that means 60% more air is blown off per cycle! This is the highest flowing BOV on the market
    Included with Every Q BOV:
    Q BOV Assembly
    TiAL V-Band Clamp
    V-Band Weld Flange
    High Pressure O-Ring
    TiAL Air Fitting
    Sorry fotonya kurang jelas pake HP soalnya (kamera-nya lagi rusak)
    Tertarik??
    Silakan hubungi saya pada nomor esia yang ada di bawah signature saya atau ke 08179845168..
    Atau kirim PM juga boleh kok...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
  2. Hokinusa
    Uuuuuuuupppp dulu biar keliatan yaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Uuuuuuuuuuppppppp....
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
Venom 300x250 MBtech
  1. - H.P - Original TIAL Blowoff Valve Type Q
    By Hydra Performance in forum Jual Beli Mesin Lainnya
    Last Post: 5th December 2011, 13:11
  2. - H.P - TIAL Wastegate Type MVR - All Springs
    Last Post: 23rd November 2011, 13:10
  3. HKS RACING BLOWOFF VALVE TYPE II
    By yellowbusa in forum Jual Beli Mesin Lainnya
    Last Post: 22nd September 2011, 12:10
  4. RR // : TiAL Sports - Type Q Blow off Valve
    By RacingRepublic in forum Jual Beli Mesin Lainnya
    Last Post: 19th January 2011, 23:57
  5. fs blowoff greddy type rs 1.000.000
    By yungs in forum Jual Beli Mesin Lainnya
    Last Post: 24th February 2010, 22:54
