BUB ( Butuh Uang Banget )
Results 1 to 10 of 99
  • Short URL:  http://modifika.si/165248
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    SEMUA HARGA NEGO
    LEBIH CEPAT NAWAR = LEBIH MURAH
    Telp / SMS only: 08112509829
    Butuh Uang Banget
    DD S4a 4chanel Class A/B
    Kondisi 99,999%: CALL/SMS
    $820 --> 4.900.000
    100Wrms x 2 + 200Wrms x 2 @ 4 ohm 12V: The new S4a is a non-symmetrical output, 4 channel power amplifier.
    300Wrms x 1 + 600Wrms x 1 @ 4 ohm bridged
    The S4a can be configured to run a variety of systems.
    * High level inputs can be fed into RCA's
    * Murdered-Out power & speaker terminal blocks
    * Clipping indicator
    * 5-way protection circuits
    * 200 x 2 to power midrange door speakers with variable band pass, 2 x 100 to tweeters with variable high pass.
    * 200 x 2 to power front component set or coax speakers, 2 x 100 to power rear fill.
    * 100 x 2 to power front speakers, up to 700 mono to drive rear sub(s).
    * 3 channel amp, 200 x 3 for surround sound use.
    * 2 x 150 + 2 x 300 in 2 Ohm stereo use, to power double sets of coax/components.
    * 2 x 175 + 2 x 350 in 1 ohm stereo use, to power more sets of coax/components.
    With 3-way variable crossovers and two sets of bridgeable, staggered output channels, you can do anything a system design needs. $820
    Midbass DD W65 6inch
    Kondisi 99,999%
    $350 --> 2.400.000
    6,5" (16cm) Midbass/Midrange Driver
    * Rubber surround
    * Sandwiched synthetic spider suspension
    * Free Flow Cooling System
    * Kevlar/Carbon Fiber Non-Pressed Cone
    * Hand Made
    Magnet Weight: 28 oz
    McIntosh 772
    Kondisi: no X service, volt meter kanan mati ( suara masih sempurna )
    Harga: 1.900.000 - NEGO
    The most powerfull sub and monoblock on EARTH !
    Sub DDZ
    Kondisi: masih terpasang di mbl
    Harga 2nd: CALL/SMS
    Harga barunya $5000
    On August 31st the bar was set just a bit higher in dB Drag competition. Alan Dante set the new record at 180.5dB with a single subwoofer. Let me say that again... WITH A SINGLE SUBWOOFER.
    Alan Dante's concrete filled Volvo is louder than dynamite, jet engines, gunfire, NASA rockets and pretty much any sound you can imagine for that matter aside from nuclear bombs and natural disasters.
    The 180.5 score was done with a Digital Designs 9918Z 18" subwoofer receiving 26,000 watts of power from four Stetsom 7KD amplifiers. Fifteen Powermaster 16 volt batteries were used as well. Rumor has it that the setup is good for at least another decibel, so expect to possibly see an even higher number in the near future.
    ''The first brazilian to compete in SPL outside brazilian borders.''
    172.3 with ONE SUB on 2002 DB Drag World Finals
    169 on Extreme 2 2003 DB Drag World Finals
    ...2006 world recorde extreme 1 -177,8 db and deathmath champion
    ...179.3db extreme 1 sub wr holder
    ...179.7db extreme 1 sub wr holder
    ...180.5db extreme 1 FIRST DB DRAG 180SSS
    ...2007 world CUP HOLDER 179.7DBS 1 SUB WOOFER and deathmath champion
    ...2008 180.9db ex 2 world champion and deathmath 173db
    ...2009 181.7db ex3+ WR
    ...life beging at 180db
    Monoblock DDZ1a
    Kondisi: masih terpasang di mobil, dus ori ada
    Harga 2nd: CALL/SMS
    Dulu harga barunya $3700
    Harga barunya DD http://shop.soundpressure.com/vpasp/...IGITAL+DESIGNS
  2. SbcAgent
    15 Hrs 23 Mins 26 Secs
    up................
    Quote Originally Posted by rin_dix View Post
    up................
    thx allot pak
    u p
    u p
    u p
    u p
    North JKT
    1 Wk 4 Days 4 Hrs 38 Mins 48 Secs
    Cepet laku nih......... Bantu up bos Vian...
    Quote Originally Posted by Birdsongs View Post
    thx allot om
    u p
MBtech Venom 300x250
  1. TURUN HARGA LAGI, BUTUH UANG BANGET - W124 300E 86 M/T
    By andriyuli in forum Mercedes-Benz
    Last Post: 19th September 2010, 06:13
  2. BUB ( Butuh Uang Banget )
    By vian11 in forum Bursa Audio Lainnya
    Last Post: 20th April 2010, 14:18
  3. BUB ( Butuh Uang Banget )
    By vian11 in forum Power Amplifier
    Last Post: 20th April 2010, 14:01
  4. BUB ( Butuh Uang Banget )
    By vian11 in forum Head Unit & Processor
    Last Post: 12th April 2010, 14:45
  5. WTS TOYOTA RUSH Type S 2007 SILVER butuh uang banget
    By butterscotch in forum Merk Lainnya
    Last Post: 15th March 2010, 09:44
