[WTA]E39 530i ABS MODULE
  • Short URL:  http://modifika.si/165129
    3 Hrs 1 Min 6 Secs
    Hi Guys~
    My car, a e39 530i 2001 was fine and never had any problems with the ABS or ASC control lights. Few days ago after washing my car and the engine it stays constantly on. I suspect a wet sensor and shall monitor it.
    Is there any connection with water or rain with ABS control?
    Also I changed ABS sensor few times but after few days ago, lights on again. Ofcourse i scaned n still have fault with rear left sensor.
    I think problem with ABS MODULE. If i change it from ASTRA.....Its Damn expensive!!!!!!!!!
    Guys do u know who can rebuild ABS module in indonesia????
    PLz help me~~!!
    MY HP : 0817 677 9943
    THX!!
    In your dreams...
    4 Hrs 28 Mins 49 Secs
    you can't just blame you module as the main culprit before checking everything else wired to it
    you may say that the module is the problem when your speedometer doesn't correspond your actual speed when the light came on. that is one example...
    i don't know what type of ABS does an E39 use... but if it uses a Bosch 5.7, you can read here for the error codes it might give after the scanning...
    or in global, you can read here
    or you can just go to Bimmerlounge to ask other BMW owners in this forum board
  1. [wts] unichip type Q E4 and Throttle Module // Type A dan Turbo Module
    By nicz in forum ECU, Piggyback, Electronic Parts
    Last Post: 18th September 2013, 17:48
  2. Replies: 104
    Last Post: 9th October 2012, 09:41
  3. WTB: DASTEK THROTTLE MODULE & TURBO MODULE 2nd
    By Schizoprenia in forum ECU, Piggyback, Electronic Parts
    Last Post: 10th May 2012, 09:31
  4. WTS: auto transmission tiptronic E39 530i 2003 + module
    By misel in forum Jual Beli Mesin Lainnya
    Last Post: 8th March 2012, 07:38
  5. [WTA]E39 530i ABS MODULE
    By iforu82 in forum BMW
    Last Post: 11th February 2010, 21:27
