3-way Vifa + Vifa passive x-over X3....................(sold,thanks modcom...)
Results 1 to 10 of 33
  • Short URL:  http://modifika.si/163883
    Cool 3-way Vifa + Vifa passive x-over X3....................(sold,thanks modcom...)
    3-way Vifa + Vifa passive x-over X3..................sold
    Vifa M18WN-19-04
    6-1/2 autosound woofer
    Long stroke
    Magnesium basket
    Rubber surround
    Moisture resistant rigid paper cone
    Kapton former
    Flange 180mm
    Cut-out 145mm
    Depth 83mm
    Znom 4 ohm
    Re 3.0 ohm
    Le@1kHz 0.6 mH
    fs 63 Hz
    Qms 3.88
    Qes 0.80
    Qts 0.66
    Mms 15.5 g
    Cms - mm/N
    Sd 132 cm2
    BL 4.8 Tm
    Vas 10 ltrs
    Xmax 4 mm peak
    VC 40 mm
    Sensitivity 2.83V / 1m 85 dB
    Nom. Power DIN 110 W
    Magnet weight 415 g
    Vifa MG10MD09-08 3.5" Fiberglass Cone Midrange
    These are the last one, no more will be built. It is also a good replacement for the MD10MD39, which was a paper cone midrange.
    8 ohm impedance
    5.5 ohm DCR
    86 dB Sensitivity
    Frequency range 100Hz to 15kHz
    Fs 81Hz
    VC diameter 20mm
    x-max 0.65mm
    Good for use in a small sealed enclosure of 0.5 to 1 liter. Stuffed with filling too.
    call
    081388575788
    15 Hrs 23 Mins 26 Secs
    up............
    thanks yach bos eddy.........
    Bali
    1 Hr 24 Mins 45 Secs
    bisikin net sampe bali dong bos...
    16 Mins 14 Secs
    Bos tlg PM harga nettnya bos, thanks...
    pm sent bos alon n bos bomber,thanks.......
    Kota Minyak
    sdh trjual blm boz? pm net dong..
    pm sent bos,thanks.........
    2 Wks 3 Days 21 Hrs 7 Mins 29 Secs
    bos ini seri apa ya?
    please PM netnya
    PangkaL Paha
    2 Wks 5 Days 1 Hr 8 Mins 45 Secs
    barang value for money sekali nih,, mangstab
  1. [WTS] vifa DX25TG05-04 + passive & mid A16WG-09-04
    By kdbesi9 in forum Speaker - SubWoofer
    Last Post: 4th July 2012, 12:20
  2. Replies: 8
    Last Post: 8th November 2011, 13:37
  3. [FS]......2WAY SPEAKER...VIFA...RCF...PASSIVE......
    By Acepaden in forum Speaker - SubWoofer
    Last Post: 23rd August 2011, 11:30
  4. Midbass Vifa P17WG-XX dan passive solen
    By Blue-X in forum Speaker - SubWoofer
    Last Post: 14th November 2010, 22:37
