High End,Super rare item, very sick audiophilia ears, marantz 750a limited edition
Results 1 to 10 of 59
  • Short URL:  http://modifika.si/163867
    1 Min 31 Secs
    Test harga marantz 750a audiophilia xtreme sound. Gambar nyusul. Googling aja dulu tp biasa di google punya cuma 2.1, punya gw 4.1 sangat langka sekali cocok buat mereka yg gila suara alus.
    note aj, power ini ga bs disetting,
    atau yang kita sebut direct.
    Jadi kalau anda punya head unit di bawah imprint
    baby odr, nakamichi or eclipse, jangan buang2 waktu anda
    Tapi crossover bagus mayan sih.
    LINKNYA
    Diharapkan serious buyer only.
    ini picnya
    baretan di tulisN MARANZ SELAIN ITU BODY BAGUS SEKALI
    sekalian pamer solo baric wkwkwk
    Punya gw yang 4.1 jadi ada 4 buah mosfet dan satu buat power supply bank
    Tawar lgsg ke hp, no pm, dan sms tanya harga ga akan dibalas
    Marantz Model750 Specification
    Power supply input voltage (DC):10.6V~14.8V
    Power supply output voltage(DC):34.5V
    Output:90W+90W(4Ω12V)、125W+125W(4Ω13.8V)
    THD:<0.01%
    Input sensitive:100mV~3V
    Input impedence:10KΩ
    Frequence response:5Hz~120KHz
    S/N ratio:>105dB
    Damping factor:>250
    pernah diadu dengan Audison HV venti
    hasilnya
    In “De La Main Gauche ”, monster grade amplifier HV Venti could reproduce every detail, such as the breath of singer, the vivid mouth movement and powerful music strength. And for Livingston Taylor’s “Grandma’s Hands”, it sounds so real the you can tell every movement of the singer. There are lots of musical emotion expressed through the audio system. The “Four Season Concerto” shows the outstanding control power over the speaker. The sound stage is wide and clean, and the positioning of each instrument is vivid and accurate. The detail of violin show good blending of detail and harmony. Not to mention the powerful bass. But for Marantz Model 750, the sound quality is so close to the excellent HV Venti. The detail within singing, the vivid strings on violin, the powerful drum with good punch, Marantz Model 750 are so close to the “big guy” and bring about ever softer feeling. It sounds so sweet. The restrain should be only the limited output power. Marantz Model 750 sounds smaller in terms of sound stage. The lower end bass also reveal the little weakness in comparison.
    There is the listening consensus and conclusion. It is unfair to say Marantz Model 750 and Audison HV Venti are matched equal. For HV Venti is still a reference Hi-End amplifier. Through careful installation and adjustment, HV Venti can hardly find any competitor, but the price of HV Venti is not in “average affordable level”.
    On the other hand, Marantz Model 750 has much “friendly” price. It also inherited with the clean and warm sound quality from home audio design. Compare with HV Venti, Marantz Model 750 wins high C/P in terms of sound quality. In this contest we only applied with one set of Marantz Model 750. One may try with the ultimate way to apply multi power supply on Marantz Model 750. If you pair each power amplifier of Marantz Model 750 with exclusive power supply, it may provide higher current and strength for amplifier. Or you may use 2 power supply for 4 amplifiers, working in bi-amp mode to gain higher power for speaker. These can both enhace the performance of Marantz Model 750. You can say that it is possible to make Marantz Model 750’ s performance much closer to the HV Venti.
    Fast deal 0818.0847.0248-luvaga
    16 Hrs 28 Mins 8 Secs
    up...........
    1 Min 31 Secs
    up selamat siang pic nyusul, soalnya hp gw kameranya kmrn garansi tolol.
    cover camera blom dilepas jadi hasil foto kuning semua.
    1 Min 31 Secs
    edited sementara
    1 Min 31 Secs
    Upp ayo barang gila nih=]
    1 Mth 2 Wks 5 Days 4 Hrs 25 Mins 22 Secs
    penasaran gw kyk apa barangnya.... heheheee
    hxd2 bs ga yah bos??>hehehhe
    1 Min 31 Secs
    utamain seh h.u yang uda bisa time alignment,
    jgn hu low end kalo ngga si power jadi ga maksimal.
    Sekelas2 imprin,t clarion 768, p80
    1 Min 31 Secs
    upp lagi ho3...
    1 Min 31 Secs
    naek lg huaaa...
    1 Wk 4 Days 4 Hrs 42 Mins 26 Secs
    kalo pake 7998 bs gak om?
    makasih
  1. WTS : RARE - Marantz system 750A (NOS)
    By SchizoFrenic in forum Power Amplifier
    Last Post: 5th July 2013, 22:45
  2. WTS MARANTZ MODEL 750A
    By albert_ndoxxx in forum Power Amplifier
    Last Post: 17th August 2011, 18:00
  3. WTS: marantz 750a best offer...
    By timmy23387 in forum Power Amplifier
    Last Post: 20th August 2010, 23:57
  4. [wtA] MARANTZ 750A
    By vickyz in forum Diskusi Power Amplifier
    Last Post: 22nd May 2010, 14:38
  5. Wts Rare item Nakamichi TP 1200 NSS Limited Edition +cd chgr 100mb
    By ric_signature in forum Head Unit & Processor
    Last Post: 11th December 2009, 14:35
