AUDISON BTX-2 Balanced Line Transmitter (sold,thanks modcom...)
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/163514
    Cool AUDISON BTX-2 Balanced Line Transmitter (sold,thanks modcom...)
    AUDISON BTX-2 Balanced Line Transmitter + AUDISON Linear Phantom cable........sold
    The Audison ABS system is really clever.
    The female rca's are backward-compatible with non-balanced connectors. The male ABS connectors are in an rca form factor, with an additional concentric ring inside what is normally the signal ground. Audison makes abalanced transmitter which can be used to link an unbalanced signal to any Audison amp equipped with ABS capability. The ABS transmitter obtains +/- 15 volts from the amplifier, and allows unity gain, +3db, or +6db gain. I've also adapted the PG TBAT to run to the Audison'sbalanced input. Nice sounding kit, and quiet as you could want.
    Price : $170.00
    call
    081388575788
    15 Hrs 23 Mins 26 Secs
    up...............
    thanks again bos.....
    up............
    up..................
    up.................
    up....................
    up.....................
  1. Jual : 1 Balanced Line transmitter AUDISON BTX 2
    By d3cibel in forum Bursa Audio Lainnya
    Last Post: 19th June 2013, 14:29
  2. Jual : 1 Zapco Symbilink SLB-TP4 Four Ch Line Transmitter
    Last Post: 4th June 2012, 16:55
  3. Replies: 47
    Last Post: 24th December 2009, 04:20
  4. Jual : Power Soundstream Rubicon 502 + Balanced Line
    By d3cibel in forum Power Amplifier
    Last Post: 26th August 2009, 10:14
