Home Integrated Amplifier Rega Brio3
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/163383
    jakarta selatan
    3 Days 2 Hrs 6 Mins 55 Secs
    Brio3
    By jlu_mike at 2010-01-21
    The third generation of Brio the Brio 3 now boasts a modified power supply and up-rated power transformer.
    The increased power output (49 watts per channel into 8W) of the Brio 3 greatly improves control and musical performance over its predecessor.
    Rather than having unnecessary gadgets and frills usually found on products in this price range, the Brio 3 utilises the highest quality components to achieve the best sonic performance.
    The output amplifier is built around a pair of Sanken 150w Darlington output transistors and an electronic circuit protects against shorted speakers and reactive loads of 1.7W or less.
    The power supply uses the new generously rated toroidal transformer and 10,000F smoothing capacitors that provide enough current to drive the hardest of loads.
    If excellent sound quality and affordable price is your priority then the Brio 3 may be the ideal amplifier for you.
    Features
    * 49w RMS per channel into 8ohm
    * 5 inputs: Phono, CD, Tuner, Line1 & Tape
    * Rega custom built extruded aluminium case
    * Rega Planar IC phono input
    * Toroidal mains transformer
    * Sanken 150w output transistors
    Review
    http://www.stereophile.com/integrate...3_2717crx.aspx
    http://www.positive-feedback.com/Issue28/rega_brio.htm
    http://www.avguide.com/review/rega-b...ollo-cd-player
    brg 99% suara maknyus deh ga malu maluin dengan harga sgtu, kalo mw audisi juga boleh di tempat saya, percaya kuping sendiri deh dijamin!!
    for fast response plz contact
    Mike 0817 917 3357
    jakarta selatan
    uppppppppppppppppppppppppp
    16 Hrs 28 Mins 8 Secs
    up................
    jakarta selatan
    uppppppppppppppppppppppppppppp
    jakarta selatan
  1. Rega BRIO3 Amp (Made In UK)
    By jlu_mike in forum Bursa Audio Lainnya
    Last Post: 17th November 2010, 05:30
  2. Home Audio ( Quad 11L, Audioquest, Rega Brio 3) Bening dahhhh
    Last Post: 14th October 2010, 10:09
  3. Super Promo Integrated Rega Brio 3, terbatas!!!!
    Last Post: 8th March 2010, 17:56
  4. wts: integrated amplifier arcam ll
    By leon9 in forum Bursa Audio Lainnya
    Last Post: 9th February 2010, 12:27
  5. Replies: 14
    Last Post: 3rd October 2009, 19:49
