[WTS-SQ AMP] ARC AUDIO KAR 400.4 Black (Masih Garansi) dan Upgraded Version
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/163195
    Medan
    9 Hrs 57 Mins 52 Secs
    Ampli SQ yg Powerful.... design baru seperti ARC Foose Design.. bisa buat kontes Audio SQ.
    Kondisi Komplit Dus, Manual, Kartu Garansi Segel... Masih Garansi 9 bulan..
    1. Standard Version Belinya 2.4 juta.. Open Price 1.95jt.. nego tipis... (bekas tarik Midbass + Subwoofer)
    2. Upgraded Version Beli + Biaya Upgrade 4.8jt.. Open Price 3.9jt... Nego tipis.. (bekas Tarik MidRange+Tweeter).. suara lebih open, transparan , detail & high lebih smooth....
    Beli Keduanya 4.8 jt !!
    "The ARC Audio KAR 400.4 is a Class AB, 4-channel amplifier housed in a sleek, clear anodized aluminum chassis. The understated style looks classy and refined. The front two channels include a 12 dB-per-octave, fully-variable crossover from 55 Hz to 550 Hz. The front channels also include a 45 Hz bass boost that allows up to 18 dB of maximum boost. The rear channels include a 12 dB-per-octave, fully-variable crossover from 55 Hz to 5500 Hz via a “x10” frequency multiplier. The RCA connections and signal adjustments are located on one side of the ARC Audio KAR 400.4, while the power and speaker connections, along with the 40 amp fuse, are located on the other side. The gold-plated power and speaker screw terminal connections can easily accept either bare wire or fork terminals.
    This amplifier performs as well as it looks. On the test bench, the ARC Audio KAR 400.4 delivered 70.2 watts x 4 into 4-ohms with less than 1% distortion. Into 2-ohms, the KAR 400.4 delivered 107.5 watts per channel into four channels. This KAR 400.4 exceeded is rated power around 40 percent — very impressive. Into 4-ohms bridged, the KAR 400.4 delivered a respectable 248.5 watts per channel into two channels for a total amplifier power of 497 watts. At peak power, the ARC Audio KAR 400.4 average slightly above 70 percent, efficiency drawing 27.8 amps at 4 ohms stereo and 47.7amps at 4 ohms bridged.
    The ARC Audio KAR 400.4 is a solid performer. This amplifier has enough power and is flexible enough to drive your complete system. Or, you could use it as the beginning to a high-power, high end system of sonic goodness. If you’re looking for a great sounding amplifier with the ability to grow, the ARC Audio 400.4 would be an excellent choice."
    Specification:
    * Rated Output power: 50 watts x 4 @ 4 ohms, 100 watts x 4 @ 2 ohms, and 190 watts x 2 @ 4 ohms bridged
    * Transient distortion: less than 0.1% @ 4 ohms
    * Frequency response: 20 Hz-20 KHz
    * S/N ratio(A wtg): greater than 95 dB
    * Bass boost: + 18 dB @45 Hz
    * Input sensitivity: 250 mV - 2.5 V
    * Crossover: 55 Hz-5.5 KHz variable 12 dB
    * Fuse: 40A x1
    * Dimensions: 12 inches x 8 1/4 inches x 2 1/8 inches
    All Price is NEGO !!
    BARANG JAMIN MULUS MIRIP BARU SEMUA DEH !!
    bagi yg minat langsung di tawar aja tapi yg wajar yah.. soalnya bagi yg serius only.. di kasih hrg mantep mantep...
    MUST GO!! lagi BU !!
    CALL / SMS 08126446888
    dagangan saya :
    [WTS] SS R7000 Ring Radiator, sub Scanspeak 23W, Midbass Cello W18, Phass AT 28 evo
    [WTS] SEAS Excel W18E001 6.5" & Lotus RM120, RW220, PW165
    [WTS-Best Buy HU] Alpine 9887, 7998R, F1 DVI-9990E + ECLIPSE 7200 MKII
    [ARC Signature Edition] ARC SE 4200 & 4100 (HOT Item for SQ Lover)
    [RARE Item !! ] Newl PXA-H701 (Made in Korea for Japan Market) 5.99jt (Nego)
    [WTS] Monoblok Zapco Reference 500.1 (Class A/B) & MILBERT BAM-235
    [wts] Subwoofer JL Audio 12W3V3
    Medan
    uppppppppppppppppppppppppp
    3 Wks 11 Hrs 46 Mins 6 Secs
    Mau ganti smua ya bg...?
    Medan
    iya broo... lagi BU juga sih.. makanya buruan di lepas aja...
    nggak berminat bungkus-in barang ane 1 biji aja?
    Medan
    Uppppppppppppppppppppp
    Medan
    uppppppp lagi...
    Medan
    Uppppppppppppppppp... buruan sebelum disabettt org lain!!
    Power SQ terbaru dari ARC Audio.. sama dengan ARC Foose Design yg sejatinya berharga 3,8 Juta !!!
    kalau Versi Upgrade jangan ditanya lagii... pasti diatasnya...
    borong semua murah banget !!!!
    Medan
    Upppppppppppppppp
    Bogor
    23 Hrs 16 Mins 32 Secs
    kalo yg masih std bekas narik mid+sub, ada pengaruhnya nggak kalo ntar dibuat narik tweeter+mid bass
    sorry msh new bie..jd banyak nanya
    trims
    Medan
    Hahahah.. Ada2 aja bro.. Masa newbie
    Itu.. Gpp, buat sq application aja.. Bukan spl.. Lagian msh garansi.. Minat bro??
MBtech
