CLARION WXZ466MP 2-DIN 6-DISC CD/MP3 (sold,thanks modcom...)
Results 1 to 10 of 12
  • Short URL:  http://modifika.si/162718
    Cool CLARION WXZ466MP 2-DIN 6-DISC CD/MP3 (sold,thanks modcom...)
    CLARION WXZ466MP 2-DIN 6-DISC CD/MP3/WMA RECEIVER/CeNET CONTROL kondisi muluuuus...sold
    The essence of audio is alive in its design
    With brushed metal finish, the boldly noticeable faceplate is divided into five sections, with control knobs that offer superior usability laid out on its surface. Clarionís WXZ466MP offers unprecedented presence as a high quality audio component. The graphical image offered by the 23-band spectrum analyser puts a finishing touch on this powerful 6 CD unit. Design is made to satisfy sense expectation. Enjoy double sized design with this original product. More and more cars offer large installation space in their dashboard. The perfect product to achieve your car interior is born.
    * 18FM, 6AM station presets
    * 4-channel ◊ 50 watts of MOS-FET amplification
    * MP3 and WMA compatible with ID3-TAG display
    * CD-R/RW ready
    * VF display with Spectrum analyser and Screensaver
    * CATS: Theft prevention system with personal code
    * CeNET Control of: DVD changer (easy), TV tuner, 6-disc CD changer
    * 4-channel RCA output
    * 2-channel AUX input with level control
    * CeNET iPod interface compatible
    Built-in 6-disc CD changer & MP3/WMA file playback
    You can load up to 6 discs in the unitís internal CD changer so youíll probably never run out of music on your drives. In addition to music CDs and MP3 files, the changer also supports WMA files which offer superior compression while maintaining high quality, making it possible to fit the equivalent of full CD library on a single CD-R at comparable quality. ID3/WMA tags are supported to display a wide range of informations on the tunes being played.
    Listening Position Optimiser (LPO)
    The WXZ466MPís Listening Position Optimiser uses digital processing to virtually adjust the speaker distance, enabling sound stage settings to accommodate a wide variety of different types of vehicles. So no matter what type of car you drive, you can count on Clarion to drive your sound with high precision and realistic presence.
    Setting Right Left
    Distance Sample Distance Sample
    Seat position
    LPO 1 for compact car R 10 cm 13 40 cm 52
    L 40 cm 52 10 cm 13
    LPO 2 for sedan R 10 cm 13 80 cm 104
    L 80 cm 104 10 cm 13
    LPO 3 for 1 BOX car R 10 cm 13 160 cm 208
    L 160 cm 208 10 cm 13
    Digital Z-Enhancer
    Clarionís Digital-Z Enhan controls P-EQ, HPF, and LPF through the DSP, allowing you to select from three equalising patterns that emphasise the range of tones in the upper/base regions respectively while maintaining perfect acoustic balance. Furthermore, by adding gain adjustment (HI, MID, LOW) to the 3 equalising patterns, it is now possible to choose from 9 different equalising patterns to customise the sound quality pattern so that it matches your speaker system or music source perfectly.
    TUNER SECTION
    Frequency bands
    FM: (MHz) 0.05MHz steps 87.5 to 108
    MW: (kHz) 9 kHz steps 531 to 1629
    LW: (kHz) 3 kHz steps 153 to 279
    FM usable sensitivity (dBf) 9
    FM 50 dB quieting sensitivity (dBf) 15
    FM alternate channel selectivity (dBf) 70
    FM stereo separation @1 kHz (dB) 35
    FM stereo freq. resp. @ Ī3 dB (Hz) 30 to 15,000
    CD SECTION
    Wow/Flutter (WRMS) Below measurable limits
    S/N ratio (dB) 90
    Frequency response (Hz) 10 to 20,000
    Dynamic range (dB) 90
    Harmonic distortion (%) 0.01
    AUDIO SECTION
    Power output (+B = 14.4 V) 4 ◊ 27 W
    GENERAL
    Dimensions (W ◊ H ◊ D), mm 178 ◊ 100 ◊ 160
    Remote control (W ◊ H ◊ D), mm 44 ◊ 113 ◊ 13
    Weight (kg) 2.2
    Power consumption: less than 15 A
    Speaker impedance 4Ω(4Ω to 8Ω allowable)
    call
    081388575788
    up..................
    16 Hrs 28 Mins 8 Secs
    up..............
    thanks yach bos eddy......
    up...........
    up...............
    up.......................
    up........................
    up...........
    pm harga bro..
Mega Glodok Kemayoran
  1. WTS: Clarion WXZ466MP Double Dyn 2nd
    By p_modif in forum Head Unit & Processor
    Last Post: 10th February 2010, 07:24
  2. Replies: 3
    Last Post: 9th September 2009, 10:15
  3. need help: clarion wxz466mp buat sq?
    By seigaku in forum Diskusi Head Unit & Processor
    Last Post: 29th April 2007, 15:15
  4. pioneer 6850 Vs clarion double din WXZ466MP
    By dimas_86 in forum Diskusi Head Unit & Processor
    Last Post: 27th January 2007, 08:27
