WTS : Helix B4 Precision 4 chanel, barang oke ni..banting harga 2,3 NEGO
Results 1 to 10 of 30
  • Short URL:  http://modifika.si/162654
    ]jual barang 99 %... buka harga 2,3 jt...yang berminat, pm and kasih no telpon... saya hubungi.... ato hubungi sms 08562905711
    lokasi jogja
    Spec:
    Cont. power rating RMS / Musik at 4 x 4Ohm RMS at 12 Volt: 4 x 46 Watt
    Cont. power rating 4 x 4 Ohm RMS/Musik at 13,8 Volt: 4 x 60/100 Watt
    Cont. power rating 4 x 2 Ohm RMS/Musik at 13,8 Volt: 1 x 90/150 Watt
    Cont. power rating 2 x 4 Ohm RMS/Musik bridged: 2 x 180/300 Watt
    Adjust Highpass/Lowpass/Bandpass: 30 Hz - 4kHz
    Total harmonic distortion (TDH): < 0,014%
    Signal to noise ratio: > 96 dB
    Damping factor: > 450
    Frequency range: 20 Hz -20 kHz
    TIM Distortion: < 0,02%
    Input sensitivity: 500 mV - 8 V
    Fuse: 2 x 20 A
    Input impedance: 10 kOhm
    Dimensions (H/W/D) in mm: 35 x 240 x 300
    Weight net: 4,7 kg
    Driver with class A technology
    Outputstage with 16 MosFet transistors
    RMI (realmixed input) for forming an optimised mono-summation signal from the left and right channels
    NFI (noisefree input) for distortion-free listening L
    Intelligent active crossover
    Mono/Bridged/ Stereo switch
    8.0 volt input for connection to any signal source
    ADC - Anti Distortion Choke to eliminate distortions
    Intelligent power supply
    Separate speaker protection circuit with current limitation for speaker short-circuiting, cable contact with car chassis, low impedance and wrong connection
    CPS - Color Protection System
    SMD - Surface Mounting Devices for constant assembling quality
    Double-sided, copper plated pc-board for best power and signal transmission and protection against vibrations
    24-karat gold-plated solid connectors
    Temperature-optimised heatsink for highest efficiency
    1% accurate components for perfect audiophile sound quality and maximum power
    Smoked-grey plexi cover with both side printing
    ini picnya :
    http://img205.imageshack.us/i/img0115xt.jpg/
    http://img340.imageshack.us/i/img0114p.jpg/
    http://img211.imageshack.us/i/img0113lq.jpg/
    klaten
    PM nett nya dunx.. Thanks
    3 Hrs 32 Mins 11 Secs
    Pm nett ya.. Barang dimana bos? Thx
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    yg jualan gak jelas
    why ????
    why knapa bos?
    knapa ga jelas? mohon petunjuk....
    up up upu up up up up up up
    2 Wks 20 Hrs 12 Mins 13 Secs
    BOS MINTA PM NET NYA DONK,MINAT NEH,THX
    1 Wk 2 Days 22 Hrs 3 Mins 51 Secs
    bantu UP dech...........
    Quote Originally Posted by vick View Post
    Saya sudah PM tu bos vick... bisa dilanjutkan di email klavier_maschine@yahoo.com ato pm aja...tiap menitnya saya tersedia kok....
MBtech Mega Glodok Kemayoran
  1. POWER HELIX 4 CHANNEL HELIX B4 PRECISION. MURAH AJA GAN....
    By tandy suhendra in forum Power Amplifier
    Last Post: 1st September 2010, 01:11
  2. Replies: 1
    Last Post: 2nd May 2010, 03:34
  3. Replies: 25
    Last Post: 22nd February 2010, 14:10
  4. Replies: 20
    Last Post: 14th April 2008, 09:24
