WTS : STEG Q.MOS 105.4(SOLD)
Results 1 to 10 of 30
  • Short URL:  http://modifika.si/161981
    5 Days 8 Hrs 47 Mins 5 Secs
    Di HOLD SAMPE G BALIK JAK LAGI YAH, THX (SOLD)
    As title mo jual power steg seri QM 105.4
    dijual karena dah kebanyakan power yang ga dipake di gudang...baru di turunin kemaren powerna
    kondisi 90% soalnya terminal speaker agak bengkok keinjek (dulu taro dibawah jok) fungsi 100% normal en no ex service!
    karakter suara tenang bertenaga...yang udah pernah pake steq pasti tau...
    (tenaga sangat bagus... sub JLw3v2 2 biji gampang2 ngangkatnya )
    eh ya ini power SQ yah bukan spl...kebetulan gede aja wattnya
    tampak atas...
    tampak samping
    tampak belakang
    ini terminalnya yang miring...bisa dilurusin lagi sih cuma g males buka2nya...
    fungsi ga ganggu kok
    kalo mo liat2 spec sama harganya di luar
    http://www.shoppingsecure.com.au/index.php?_a=viewProd&productId=21
    All Steg QM range amplifiers are designed to give uncompromising sound quality. The QM range features regulated power supplies, meaning they will produce the same power whether your car is on or off. They are built to exacting standards with great quality internals. If you want unparalleled performance without sacrificing on sound quality, the QM range from Steg should be first on your list.
    RMS Power @ 4 Ohm 4 x 105RMS
    RMS Power @ 2 Ohm 4 x 180RMS
    RMS Power @ 4 Ohm Bridged 2 x 360RMS
    High Pass Filter 22Hz - 8500Hz
    Low Pass Filter 22Hz - 8500Hz
    Filter Slope 12dB/oct
    Bandpass Capable
    Bass Boost Gain
    Bass Boost Frequency
    Phase Control 0-180
    High Level Input
    RCA Input 150mV - 3.5V
    Total Harmonic Distortion Less than 0.05%
    Signal to Noise Ratio Greater than 95dB
    Average Efficiency Greater than 60%
    Dimensions (W x H x L) 207mm x 52mm x 394mm
    Fuse Rating 40 Amp External
    Power Connection 4 Guage
    Price:
    $765.00
    mo di lepas di 1,9jt nego
    fast response 08117177887, han, jakbar
    ps: lupa kasi tau g bakal dinas keluar jak besok pagi...jadi cod-an sampe malem ini aja (balik jak tar pas mo imlek)
  2. SbcAgent
    15 Hrs 23 Mins 26 Secs
    up............
    thx bos rindix...itu panasonicnya mantep keknya
    pic added
    2 Days 10 Hrs 30 Mins 19 Secs
    bantu up untuk power bagus .....
    Quote Originally Posted by ntoeng View Post
    om gun sy telp ga masuk2...tadinya mo maen kesana
    klaten
    bantu sondol bozz..brg bagus niy
    thx bos dan ^^
    Quote Originally Posted by frostbitez View Post
    ok om han,... ntar aja deh sehabis thn baru cap go meh hehehe
    blom sempet ke green garden om?
    apa tunggu saya pulang?
    4 Days 5 Hrs 35 Mins 1 Sec
    bro ini monoblok yaa? apa 4ch tenaga badak? netnya brapa y bro?
  1. Replies: 2
    Last Post: 21st October 2010, 11:32
  2. WTS: Steg Qmos 310.2 (SOLD)
    By ace911 in forum Power Amplifier
    Last Post: 15th February 2010, 08:40
  3. Replies: 10
    Last Post: 28th July 2009, 08:54
  4. (SOLD) STEG QMOSII Ampli QM45x2X (SOLD)
    By rdianto in forum Power Amplifier
    Last Post: 4th June 2009, 07:30
