Hi-end HELIX A4 Competition amplifier kondisi muluuuuus sekali (sold,thanks modcom..)
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/161790
    Cool Hi-end HELIX A4 Competition amplifier kondisi muluuuuus sekali (sold,thanks modcom..)
    Hi-end HELIX A4 Competition amplifier kondisi muluuuuus sekali..............sold
    Helix
    A4 Competition - Helix 4 Ch 4x85/170 Watt High-End Amplifier
    Retail Price $1,210.90
    Amplifiers
    Four Channel
    Features:
    * Cont. power rating RMS/Max. power at 4 Ohms RMS/12 V: 4 x 60/85 Watt
    * Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V: 4 x 85/160 Watt
    * Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V: 4 x 153/300 Watt
    * Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V bridged: 2 x 270/450 Watt
    * Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V bridged: 2 x 395/650 Watt
    * Total harmonic distortion: < 0,009%
    * Signal to noise ratio: > 100 dB
    * Damping factor: > 450
    * Frequeny range: 20 Hz -20 kHz
    * TIM distortion: < 0,016%
    * Input sensitivity: 500 mV - 8 V
    * Fuse: 3 x 25 A
    * Input impedance: 10 kOhm
    * Bassboost adjustable channel C und D: 0 - 9 dB
    * Dimensions (HxWxD) mm: 35 x 240 x 432
    * Weight net: 4,7 kg
    * Driver with class A technology
    * Outputstage with 24 MosFet transistors
    * RMI (realmixed input) for forming an optimised mono-summation signal from the left and right channels
    * NFI (noisefree input) for distortion-free listening
    * Intelligent active crossover
    * Bass Boost Control 0-9 dB, adjustable center frequencies 30-120 Hz
    * Mono/Bridged/ Stereo switch
    * 8.0 volt input for connection to any signal source
    * ADC - Anti Distortion Choke to eliminate distortions
    * Intelligent temperature and power controlled switching power supply
    * Separate speaker protection circuit with current limitation for speaker short-circuiting, cable contact with car chassis, low impedance and wrong connection
    * CPS - Color Protection System
    * SMD - Surface Mounting Devices for constant assembling quality
    * Double-sided, extra strong (2x 110u) and copper plated pc-board for best power and signal transmission and protection against vibrations
    * 24-karat gold-plated solid connectors suitable for 25 mē/ gauge 4 cables
    * Temperature-optimised heatsink for highest efficiency
    * 1% accurate components for perfect audiophile sound quality and maximum power
    * Smoked-grey plexi cover with both side printing
    call
    081388575788
    17 Hrs 26 Mins 3 Secs
    up..............
    klaten
    bos chris, bedanya ama HXA series apa nih? Cuman beda taun pembuatan ato kualitas jg beda? Thx
    thanks yach bos eddy.....
    ini bos seri tertingginya helix bos,hxa itu seri tengah,diatasnya ada seri precision,dan yang terakhir inilah seri competition (seri tertinggi helix bos danny....)
    bodynya memang sama semua bos,tapi ada 3 seri dengan body yang sama bos...
    klaten
    Siappp....thanks buat infonya.........jadi 2 kelas di atas HXA series yah...?
    Bisa ditandingin ama BRAX yang non GE dunk....hehehehehe
    4 Days 22 Hrs 57 Mins 5 Secs
    Mantab bos, laris manis komandan
    klo Helix ma brax si menurut saya, ga usah diragukan lagi... TOP lah.... mereka dari satu tu sodaraan... satu Ibu alias satu perusahaan bos... Laris2....
    tetep beda sich bos danny,helix itu mid end dari audiotecfischer,sedangkan brax adalah line up hi-end nya bos......
    bos jas emang paling bisa nich,he.he..he....
    thanks yach bos klavier...........
    up...................
    sama2 bos gasoline... sesama helix dilarang mendahului.... A4 laris100x...... mudah2an punya saya juga menyusul .....
  1. WTS: Helix A4 Competition Car Amplifier Brand New!
    By danangw in forum Power Amplifier
    Last Post: 24th August 2012, 13:37
  2. W12 Competition - Helix 12" 700 Watt Subwoofer (sold,thanks modcom..)
    Last Post: 22nd January 2010, 05:50
  3. Replies: 8
    Last Post: 17th July 2009, 07:15
