closed....thx modcom
Results 1 to 10 of 21
  • Short URL:  http://modifika.si/161718
    1 Day 20 Hrs 14 Mins 22 Secs
    sundul dl d sebelum tidur
    1 Mth 2 Wks 5 Days 4 Hrs 25 Mins 22 Secs
    spec nya ada bos?thx
    1 Wk 4 Days 1 Hr 29 Mins 43 Secs
    Upgrade trus nh...
    Quote Originally Posted by Aliongz View Post
    All QX Series amps feature:
    Superbrit blue power-on LED
    Built-in variable electronic crossover
    Adjustable 0 to +15 dB Twin-T 45 Hz bass boost
    Remote Monitoring Display output
    Advanced overload and thermal protection circuitry
    PWM MOSFET power supply
    TAIM Muting circuitry for soft turn-on and turn-off
    Unique thermal black anodized heatsink finish with fly cut fins
    ini bro yang gw dapetin dari internet :
    QX300.4 Features
    Tri-linear capability allows simultaneous stereo and bridged mono operation
    Variable high pass crossover: 40-800 Hz, 12 dB/octave
    Variable low pass crossover: 40-800 Hz (12 dB or 24 dB/octave) .
    QX300.4 Specifications:
    Power output:
    60 watts RMS x 4 (4 ohm load, 1% THD)
    75 watts RMS x 4 (2 ohm load, 1% THD)
    150 watts RMS x 2 (bridged into 4 ohms, 1 % THD)
    Frequency response: 20-20,000 Hz ( 1 dB)
    Signal to noise ratio: > 100 dB
    THD: < 0.02%
    Input sensitivity: 200mV-4V
    Minimum load stability for all channels: 2 ohms
    Dimensions: 15" L x 9.5" W x 2.1" H.
    berhubung sudah di upgrade spec nya pasti berbeda n lebih bagus dari spec yang saya tampilkan diatas...thx
    minat???
    Quote Originally Posted by jul-id View Post
    Upgrade trus nh...
    ga lah bro....ini kan ada barang lemparan aja jadi mau mencoba jual....
    uppppppppppppppppppppppp
    klaten
    bantu up aja boss
    thx bro
    Sundul d
    upppppppppp
Datsun 300x250 GT Radial
  1. closed-thx modcom
    By samo in forum Ragam Ukuran
    Last Post: 21st November 2009, 04:25
  2. CLOSED .... Red Emblem (ORI) ..... CLOSED, SDH DAPAT ... TQ MODCOM ...
    By daffarell in forum Bursa Eksterior Lainnya
    Last Post: 10th November 2009, 13:45
  3. [CLOSED] thx to modcom
    By jackdanol in forum Jual Beli Mesin Lainnya
    Last Post: 2nd July 2009, 18:18
  4. closed thx modcom
    By kiesaster in forum Ragam Ukuran
    Last Post: 7th June 2009, 23:08
  5. CLOSED THX 2 MODCOM !!!!!!!
    By Scal3 in forum Bursa Kaki Lainnya
    Last Post: 27th September 2008, 22:41
