WTS >> Eibach (yaris/Vitz) >>>>(SOLD)<<<<
Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
  • Short URL:  http://modifika.si/161317
    1 Hr 51 Mins 3 Secs
    EIBACH ex YARIS/VITZ
    sudah pada taulah peformance nya,,,
    BELUM DIPOTONG!!!
    jual cepet/santai,,,
    1.5 juta,,, nett..
    0818 07 3535 54
    domisili jkt/bdg,,,
    kirim juga bisa klo mau,,
    thanks.,
    1 Hr 51 Mins 3 Secs
    uo uo up/.
    1 Mth 3 Wks 5 Days 15 Hrs 3 Mins 57 Secs
    Sama Tein S-Tech pendekan mana yah bos? Kalo Tein S Tech pake pelek 17 ban 205/45 masih sisa 2 jarian ke spakbor. Kalo ini gimana bos?
    1 Hr 51 Mins 3 Secs
    Features
    The Eibach Springs Pro Kit is custom-made for your specific year, make and model vehicle
    Unique progressive spring design lowers your ride 1" to 1"
    The Eibach Pro Kit drops your center of gravity, which reduces acceleration squat, trims body roll in corners, ends excessive nose-dive when braking, and improves overall handling
    Lowers the wheel well over the tire, eliminating the extra space for hot performance looks
    4 springs included in the Eibach Pro Kit
    Installing Eibach Springs takes 3-5 hours and may require a spring compressor
    Compatible with your stock shocks, though performance of the Pro Kit is accentuated by Eibach Pro Dampers
    Part of the famed Eibach Pro System Plus performance suspension, along with Pro Dampers, the Eibach Anti-Roll Kit and more
    Your Eibach Pro Kit carries a 1,000,000-mile warranty
    Description
    Eibach's legendary spring system, the Pro Kit, dramatically improves the performance, handling and appearance of your vehicle. The secret is Eibach's proprietary progressive spring design, lowering your vehicle 1" to 1" without compromising safety or ride quality. And, the advanced cornering takes your passion for driving to a whole new level.
    Dropping your vehicle with the Eibach Pro Kit makes a world of difference for your vehicle. These Eibach Springs lower your vehicle's center of gravity, reducing acceleration squat, cornering body roll and braking nose dive. Plus, the slight drop eliminates fender-well clearance for first-place racing looks.
    Installing the Eibach Pro Kit takes more than a few hours to complete safely and correctly. You'll need several tools, most likely including a spring compressor. The added performance and looks are well worth the project time. Best yet, your Eibach Pro Kit carries a 1,000,000-mile warranty.
    Notes
    Initial lowering length may be less than 1". Your vehicle will settle shortly into the 1" to 1" lowered range. Exact length depends on the weight of vehicle components.
    *kurang lebih depan sisa 2-3 juga kok,, belakang 2, tp tergantung gede jarinya sih,, hehehe,,,
    gw pake nya ban 205/50 soalnya jd rada beda kyknya,,
    1 Hr 51 Mins 3 Secs
    up up up.,..,.
    BataVia
    1 Wk 2 Days 7 Hrs 40 Mins 29 Secs
    Barang bagus neh.. Bantu up aj deh om... hehehe...
    1 Hr 51 Mins 3 Secs
    thx brother,,, memang barang maknyus,, empuk, bisa hajar ngebut, tp bantingan pas,,, sayang saya mau ganti mobil hahaha,,,
    1 Hr 51 Mins 3 Secs
    up up up up duluaaaah,,,,
    5 Hrs 15 Mins 35 Secs
    pemakaian nya brp lama ya?? nawar sejuta bos..
    1 Hr 51 Mins 3 Secs
    sorri bos sejuta blom dapet,,, pemakaian setahunan kurang lebih,,,
  1. [WTS]Jual emblem vitz netz & vitz rear buat yaris..
    By WinN in forum Bursa Eksterior Lainnya
    Last Post: 26th January 2012, 08:50
  2. Replies: 17
    Last Post: 30th June 2010, 00:02
  3. WTS>Yaris Vitz Tailamp & Vitz logo(Update)
    By B1050HP in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 14th July 2009, 21:34
  4. WTS: Rear Lamp Vitz 4 Yaris (SOLD... Thx Modcom & Mr.Eki)
    By Day_Walker in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 11th December 2008, 07:39
  5. Replies: 10
    Last Post: 5th October 2008, 23:55
