FS monoblock Fusion
Results 1 to 10 of 12
  • Short URL:  http://modifika.si/160974
    JKT-BDG-TSM-YK
    FS monoblock Fusion
    WTS monoblok intersys ISP 1200, 2pc woofer speaker merk lightning audio, 2pc speaker kecil lupa merk, amplifier fusion Fe-505
    foto:
    FE-505
    FE-505
    5 Channel Amplifier
    CEA 2006 Rated
    2 Ohm Stable MOSFET Amplifier Design
    CEA 2006 Amplifier Power Standard Compliant
    FUSION Regulated Amplifier Technology (F.R.A.T)
    FUSION Intercooled Semi-conductor Technology (F.I.S.T)
    FUTRANZ Efficient Heat Sink Transfer Technology
    Gold Plated 4 gauge Power and Ground Connections
    Gold Plated Audio Input and Output Connections
    Gold Plated RCA Output for Multi-purpose installations
    Product Specifications
    Bandwidth 10Hz 40kHz
    Signal to Noise >95dB
    Fuse Rating 3 x 30A
    Separation >60dB
    Input Sensitivity 300mV-8V
    LP Variable Crossover 40 Hz 160Hz @ 12 dB / octave
    HP Variable Crossover 40 Hz 600Hz @ 12 dB / octave
    Input Impedance 20KΩ
    Damping Factor >200
    T.H.D 0.05%
    Dimensions D 57.5mm L 390mm H 220mm
    CEA 2006 Compliant Amplifier Ratings
    12.6 Volt Power Output Specifications
    55 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
    70 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
    130 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
    14.4 Volt Power Output Specifications
    70 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
    90 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
    160 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
    Price: 500.00
    Product Code: FE-505
    woofer
    P3.12.4
    12" 4-Ohm Single Voice Coil Subwoofer
    The P3.12.4 is our best selling 12" woofer. Why? It has deep thunderous bass and handles up to 750 watts maximum power (150 watts RMS). Plus it's designed to work in a small enclosure instead of refrigerator sized box!
    MSRP $69.99
    P3.12.4 Specifications
    Features
    Polypropylene Cone and Dustcap
    Kapton Former
    40oz. Magnet
    Chrome Plated Basket
    Warranty
    Standard Warranty - 1 Year
    Specifications
    Description Value
    Size 12"
    Impedance 4-Ohms
    Power Handling 150 Watts RMS
    750 Watts Max.
    Motor Size 40 oz. magnet
    Voice Coil 2"
    Speaker Connector Spade connector
    Mounting Depth 4-15/16"
    Recommended Sealed Enclosure 1.50 cu. ft.
    (42.47 liters)
    Recommended Vented Enclosure N/A
    Tuning Frequency (vented) N/A
    Shipping Weight N/A
    Specifications subject to change without notice
    dijual juga:
    woofer
    P3.12.4
    MSRP $69.99
    Features
    Kapton Former
    40oz. Magnet
    Warranty
    Specifications
    Description Value
    Size 12"
    Impedance 4-Ohms
    750 Watts Max.
    Voice Coil 2"
    (42.47 liters)
    Shipping Weight N/A
    penawaran via pm aja...jam kerja selalu onlen....
    yogyakarta ngadiningrat
    14 Hrs 1 Min 50 Secs
    klo bukan gara2 mo buat beli B18 gak bakal dijual ya gan ni barang?...:maho:maho
    moga cpt laku wes gan ....
    krobokan semarang barat
    Anggit kopi paste aja nih
    Mana ada di modcom :maho
    Hahahaha..
    Btw bantu up ya TS
    14 Hrs 16 Mins 56 Secs
    bantu up bro rully, barangnya mantap2 nih
    BJAmodified Bandung
    6 Days 18 Hrs 39 Mins 17 Secs
    Bantu up lg deh ferdy
    Bekasi
    12 Hrs 50 Mins 40 Secs
    bantu up bro..klo bisa pake no hp nya juga donk...:p
    JKT-BDG-TSM-YK
    up for today
    JKT-BDG-TSM-YK
    up up up for today
    1 Wk 5 Hrs 56 Mins 17 Secs
    bos.. minta di pmin netnya monoblocknya ya.. sekalian sama speknya kalo bisa bos.. thx before
    JKT-BDG-TSM-YK
    up for today
  1. WTS monoblock LM 2200 & power Fusion 4ch
    By wayangbagong in forum Power Amplifier
    Last Post: 4th April 2012, 09:06
  2. (WTS) MONOBLOCK FUSION EN-AM 800.1
    By wanda_kartika in forum Power Amplifier
    Last Post: 14th February 2010, 13:11
  3. (WTS) MONOBLOCK FUSION EN-AM 800.1
    By wanda_kartika in forum Speaker - SubWoofer
    Last Post: 22nd June 2009, 15:16
  4. Fusion FPC-65
    By McFluffy in forum Diskusi Speaker
    Last Post: 28th June 2007, 16:17
  5. [ASK] power fusion buat sub fusion
    By symbion in forum Diskusi Power Amplifier
    Last Post: 21st February 2007, 18:53
