Infinity Kappa Perfect 12dVQ subwoofer kondisi muluus..(sold,thanks modcom..)
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/160459
    Cool Infinity Kappa Perfect 12dVQ subwoofer kondisi muluus..(sold,thanks modcom..)
    Infinity Kappa Perfect 12dVQ Dual 4 ohms subwoofer kondisi muluus............sold
    ini adalah seri tertinggi dari Infinity subwoofer.......
    description :
    # 12" Dual 4 Ohms Kappa Perfect Series Subwoofer
    # Power Handling:
    * Peak: 1600 watts
    * RMS: 400 watts
    # Impedance: Dual 4 ohms
    # Magnesium Metal Matrix (M3D) Woofer cone with curvilinear design
    # Large-roll nitrile-butylene rubber surround
    # Bumped and vented pole pieces allow for 3 different motor strengths and performances
    # Cast-aluminum basket
    # Tinsel leads integrated into the Spider
    # Integrated front gasket
    # Proprietary die-cast aluminum basket
    # Single 3", 4-Ohm Voice coil
    # Frequency response: 23-400 Hz
    # Sensitivity: 92 dB
    Subwoofer Specifications :
    Subwoofer Size 12"
    Subwoofer Design Round / Circle
    Main Cone Color Silver
    Voice Coil(s) Dual (2 voice coils)
    Impedance (per voice coil) 4 ohms
    Peak Power Handling 1600 watts
    RMS Power Handling 400 watts
    Woofer Composition Magnesium Metal Matrix (M3D)
    Woofer Surround Nitrile Butadiene Rubber (NBR)
    Minimum Sealed Box Volume .4 cubic feet
    Maximum Sealed Box Volume 1.25 cubic feet
    Minimum Ported Box Volume 1.75 cubic feet
    Maximum Ported Box Volume 3.0 cubic feet
    Sensitivity 92 dB
    Frequency Response 23 - 400 Hz
    Xmax (millimeters) 16.75 mm
    Top Mount Depth 7"
    Shallow Mount Installation No
    Cutout Diameter 10-7/8"
    Recommended Enclosure Type Ported / Vented
    Sealed
    call
    081388575788
  2. Hokinusa
    Dulu pernah denger di mobil temen, enak banget nih. Bantu up chris..
    thanks yach nal............
    16 Hrs 28 Mins 8 Secs
    up............
    klaten
    Sub mantabh nih...ama JL W7 manteb mana boss...??
    thanks yach bos eddy n bos danny.......
    up................
    PangkaL Paha
    2 Wks 5 Days 2 Hrs 7 Mins 58 Secs
    wuih sub mantab banget nih buat SQ maupun SQL...
    klaten
    Quote Originally Posted by b2okane View Post
    mentang2 pake juga boss...??
    wkwkwkwkwkwkw
    nett nya brp bro??
  1. WTS 4IN INFINITY KAPPA (SOLD THX MODCOM.....)
    By KEKEPOPPY in forum Speaker - SubWoofer
    Last Post: 31st January 2010, 12:41
  2. infinity kappa perfect 6.1
    By setiawanhandoyo in forum Diskusi Speaker
    Last Post: 19th January 2008, 06:13
  3. KAPPA PERFECT 12DVQ
    By gi_ty in forum Diskusi Subwoofer
    Last Post: 10th July 2007, 13:14
