Mohon Petunjuk membaca spek Ampli
  • Short URL:  http://modifika.si/160456
    34 Mins 28 Secs
    mohon informasi dari para master,
    bagaimana caranya membaca spek dari power ?
    soalnya yang biasa awam saya liat cuma output saja.
    ▪ Transient distortion
    ▪ Frequency response
    ▪ Input sensitivity
    ▪ Crossover
    etc itu bagaimana ?
    Jakarta, Bandung
    4 Days 9 Hrs 1 Min 12 Secs
    Kalau ampli serius sih biasanya spek nya dicantumin koq, bisa lsg dibaca aja kan?
    Contoh nih, ampli soundstream 4 channel harga 2jt:
    TRX4.420
    Channels Class A/B 4 ch.
    RMS Power @ 4 Ohm, 14.4V 70 x 4
    RMS Power @ 2 Ohm, 14.4V 105 x 4
    RMS Power @ 4 Ohm Bridged, 14.4V 210 x 2
    Total Harmonic Distortion (4 Ohm power) 0.05%
    Frequency Response 10 - 35kHz
    Signal-to-Noise Ratio (4 Ohm power) 105dB
    Damping Factor(100Hz,4 Ohm) >300
    Signal Voltage 200mV - 8V
    Fusing (2) 30
    Channels 1&2 HPF (12dB/octave) 50 - 500Hz
    Channels 1&2 LPF (12dB/octave) 50 - 500Hz
    Channels 3&4 HPF (12dB/octave) 50 - 500Hz
    Channels 3&4 LPF (12dB/octave) 50 - 500Hz
    Bass Boost 0-18dB, 60 Hz
    Phase Control 0-180
    The Altair - HiFi Speaker
  1. mohon petunjuk
    By vr2y in forum Diskusi Speaker
    Last Post: 25th August 2008, 23:45
  2. mohon petunjuk...
    By bonzai in forum Diskusi Speaker
    Last Post: 10th October 2005, 15:44
