WTS pioneer in-dash tv P7950DVD w\pict
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/160283
    2 Days 5 Hrs 36 Mins 45 Secs
    bos,mao jual headunit nih pioneer P7950DVD n hide-away unitnya.. harga barunya 18jtan,,saya bru pke bntar ni,,saya jual karena nutupin ac,,jad mao ganti yg biasa aja,, kondisi muluss bgt,,mao d jual 12jt aja negoo,,
    spek:
    Pioneer AVH-P7950DVD
    In-dash motorised 18cm High-Resolution screen with integrated DVD player, 6.1 audio, AM/FM tuner and high power output
    Detachable Face Panel with theft-deterrent LED
    Hard Carry Case for Detach Face
    Motorised Display Panel for DVD access
    Dual Zone Facility (Front=Tuner/MCD, Rear=DVD)
    Hideaway Module (6.0m cable) : 204 x 36.7 x 171mm
    Player Features
    Compatible with CD, CD-R/RW, VCD, DVD, DVD-R/RW
    Dolby Digital, Dolby EX, DTS-ES, DTS-NE06 processing
    DVD-Audio Playback
    Suitable for double-sided and dual-layer discs
    Direct Search by Title, Chapter, Time
    Pause and Repeat (Chapter, Title, Disc)
    Frame Play and Slow Play
    Auto Play on disc insertion
    Bookmark Play and Bookmark Eject
    Subtitle, Angle and Language selection
    Built-in MPEG 2/1 Decoder
    MP3, WMA and AAC playback with ID tag
    Supports DivX (v.6), MP3, WMA and AAC from CD and DVD
    Supports JPEG files from CD-
    Disc Title Memory and CD Text support
    Disc Eject Lock selectable
    LCD Monitor
    Touch Screen operation
    WVGA High-Resolution Image
    1,152,000 pixels
    DVD-Video Disc Menu Direct Touch Control
    Anti-Reflective and Fingerprint resistant screen coating
    Auto switching to Rear View when reverse gear selected
    5 Viewing Modes (WideScreen, 3:4, etc.)
    Adjustable screen position with memory
    “Half Close” (10 secs) to allow access behind screen
    “Set Back” screen, 2-position selectable
    TFT (Thin Film Transistor) Display
    PAL and NTSC compatible
    GDC (Graphic Display Control) for touch controls
    Intelligent Dimmer Control
    Audio Features
    MOSFET 50 Watts x 8 high power
    Built-in multi-function DSP
    3-Band parametric EQ and 13-Band Graphic EQ (L/R Indep.)
    Dolby ProLogic and ProLogic II built-in
    Digital Direct selectable
    Rotary Volume Control with “Soft Step” intervals
    Auto EQ and Auto Time Alignment with supplied mic.
    Test Tone function (selectable or within Auto TA)
    Down-Mix function for multi-channel sources
    Speaker Setting Menu
    2-Way Crossover (HPF/LPF) within Audio menu
    Subwoofer Crossover : 50/ 63/ 80/ 100/ 125/ 160/ 200Hz
    Direct Sub Drive and Loudness not supported
    Digital Listening Position Selector (LPS)
    SLA (Source Level Adjuster)
    Spectrum Analyzers (4) and Level Indicators (2)
    Connectivity
    Rear View Camera RCA Video Input (camera not included)
    PCM Linear stereo audio output
    RCA Input (L+R+Video)
    RCA Output for rear screen (L+R+Video)
    9 channels x 5.0Volt Gold-plated RCA Audio Preout
    RCA Front 2-Way Network selectable
    AV Bus Input for GEX-P5750TVP TV Tuner
    Optical Digital Input
    Pioneer P-Bus Input, Multiplay CD Control, other
    iPod Video direct connect not supported
    iPod Adapter Ready (optional CD-IB100-2)
    P-Bus Bluetooth adapter ready (via EXT)
    USB Adapter and iPod Video Direct not supported
    AUX Input via CD-RB10 or CD-RB20
    ini gambarnya:
    sms/call/PM
    0819.321.20002 (hau2)
    pupupupupupupupupupupupupu
    17 Hrs 26 Mins 3 Secs
    up..........
    Jakarta Timur
    1 Mth 1 Day 6 Hrs 45 Secs
    Center speakernya aja boleh?
    up...............
    upuppupupupuupupuppuup
  1. Hu pioneer avh-p7950dvd
    By Ferrlim in forum Head Unit & Processor
    Last Post: 5th September 2012, 17:21
  2. Pioneer AVH-P7950DVD/indash tv/dvd Pioneer
    Last Post: 14th June 2012, 14:05
  3. WTS > PIONEER TV MOBIL IN DASH avh p5750dvd
    By babutz in forum Head Unit & Processor
    Last Post: 22nd May 2012, 19:43
  4. JUAL TV+DVD (IN DASH) + TUNER MERK PIONEER
    By tomydwar in forum Head Unit & Processor
    Last Post: 26th March 2011, 10:50
