Nakamichi PA-4100 4 Ch 800 Watt SQ Amplifier (SOLD..TX 2 MODCOM)
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/159748
    6 Mins 50 Secs
    Building on Nakamichi's tradition of pure audio sonic excellence, innovative engineering and commitment to advancing the state of automotive audio fidelity, PA-4100 (4-Channel) sets new standards of performance and features to meet the needs of audiophiles. Audiophiles today expect their in-car audio entertainment to match the same level of performance as their home audio system. This is now made possible through the combination of cutting edge technologies and designs such as : High Current MOSFET Devices - An enormous power is available in reserve headroom to reproduce accurately the most demanding of your musical selections. The amplifier's ability to respond to music peaks is enhanced. MOSFET powered amplifiers also ensure minimal sound distortion and maximize sound amplification, even at great outputs. Gold-Plated Power and Speakers Connectors - It provides a softer and more reliable contact with lower impedance as compared to other materials. Most importantly, it ensures durability and a steady flow of current without interference, hence lowers impedance. Aluminum Printed Circuit Board (PCB) for All Transistors - This provides consistent thermal stability so as to achieve optimal audio performance.
    MOSFET Power Supply - Increase The Amplifier's Ability To Respond To Music Peaks Quickly And Efficiently, With Excellent Sound Quality
    Stereo & Bridges Mode Application
    Continuous Phase Control (0 - 180 deg)
    Terminal Layout At Bottom Of Amplifier
    4 Way Protection : Output Short, DC Offset, Thermal & Battery > 18 V
    Dual LED Indicators (Power & Protect)
    Double Power Output When Using A 2 ohms Speaker
    Aluminium PCB For All Transistors - Provide Consistent Thermal Stability
    Gold-Plated Power And Speaker Connectors
    Power Output RMS @ 4 ohms: 100 W x 4
    Power Output RMS @ 2 ohms: 200 W x 4
    Bridged Output RMS @ 4 ohms: 350 W x 2
    Frequency Response: 20 Hz - 20,000 Hz
    Crossover (Butterworth): HP 15 - 400 Hz LP 40 - 400 Hz
    Bass EQ @ 45 Hz: 0 - 12 dB
    S/N Ratio: >90 dB
    Total Harmonic Distortion: <0.05%
    Dimensions: 535 (W) x 63 (H) x 268 (D) mm 21.06 (W) x 2.48 (H) x 10.55 (D) inches # Weight: 6.61 kg / 14.57 lbs
    Kondisi 99% (pemakaian dari baru Akhir November 2009)
    Netto 2750rb
    08121073688
  2. SbcAgent
    [option] Jakarta
    1 Wk 5 Days 16 Hrs 9 Mins 13 Secs
    bantu up...
    jogja coy...
    buset tulisan doang....pic aslinya tampilin, biar sip!!!
    btw,masih asli buatan jepang?
    2 Days 10 Hrs 30 Mins 19 Secs
    barang kaya gini cepet laku deh
    6 Mins 50 Secs
    Tengkyu Bang.. Maklum Newbie.. pengennya BU..
    1 Day 5 Hrs 25 Mins 42 Secs
    maseh lengkap??
    dus , manual , n kartu garansi.....
  1. Nakamichi PA-4100 4 Ch 800 Watt SQ Amplifier --> Booked
    By alphabravo in forum Power Amplifier
    Last Post: 2nd September 2010, 20:03
  2. Replies: 5
    Last Post: 25th January 2010, 15:24
