FS: Kenwood DDX 7025, Ipod Interface KCA IP500 (turun harga)
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/159523
    Bogor
    14 Hrs 16 Mins 27 Secs
    Thumbs up FS: Kenwood DDX 7025, Ipod Interface KCA IP500 (turun harga)
    Kondisi DDX 7025 95% udah dipake 6 bulanan, KCA IP 500 99% baru beli 3 bulanan.
    Semua unit belum pernah diservis. Semua sistem berjalan dengan baik.
    Alasan dijual, upgrade ke sistem baru.
    Spek DDX 7025
    Monitor section
    Picture size.............................................. ..6.4 inches wide
    143.6(W)77.1(H)mm
    Display system ........................Transparent TN LCD panel
    Drive system ..............................TFT active matrix system
    Number of pixels....................336,960 (480H234VRGB)
    Effective pixels .................................................. ....99.99%
    Pixel arrangement......................RGB striped arrangement
    Back lighting ....................Cold Cathode Fluorescent Tube
    DVD section
    D/A Converter .................................................. ..........24Bit
    Decoder ............Linear PCM/Dolby digital/dts/MP3/WMA
    Wow & Flutter ............................Below Measurable Limit
    Frequency response
    (Sampling frequency;96k) ........................20~44,000Hz
    (Sampling frequency;48k) ........................20~22,000Hz
    (Sampling frequency;44.1k) ......................20~20,000Hz
    Total harmonic distortion (1k) ................................0.010%
    Signal to Noise ratio................................100dB (DVD 96k)
    Dynamic range........................................100dB (DVD 96k)
    DISC Format........................DVD-Video/VIDEO-CD/CD-DA
    Sampling frequency........................44.1kHz/48kHz, 96kHz
    Quantifying bit number ....................................16/20/24bit
    FM Tuner section
    Frequency range (50kHz)..........................87.5~108.0MHz
    Usable sensitivity (S/N=26dB) ..........................0.7μV/75Ω
    Quieting sensitivity (S/N=46dB) ........................1.6μV/75Ω
    Frequency response (3.0dB) ......................30Hz~15kHz
    S/N (dB) (MONO) .................................................. ....66dB
    Selectivity (400kHz) ..............................................≥ 80dB
    Stereo separation........................................ ....39dB (1kHz)
    LW Tuner section
    Frequency range (9kHz) ..........................153kHz~281kHz
    Usable sensitivity .................................................. ..28dBμ
    MW Tuner section
    Frequency range (9kHz) ........................531kHz~1611kHz
    Video section
    Color system of external video input ................NTSC/PAL
    External video input level (RCA jacks) ..............1Vp-p/75Ω
    External audio max input level (RCA jacks) ..........1V/22kΩ
    Analog RGB input ..........................................0.7Vp-p/75Ω
    Audio section
    Maximum Power (Front&Rear) ..............................50W4
    Output power (Front&Rear)
    (DIN 45324, +B=14.4V) ......................................30W4
    Preout level (V) .................................................. ..2V/10kΩ
    Preout impedance .................................................. ≤ 600Ω
    Tone action
    Bass.............................................. ..........100 Hz 10 dB
    Middle .................................................. ....1 kHz 10 dB
    Treble............................................ ..........10 kHz 10 dB
    General
    Operating voltage ....................................14.4V (11V~16V)
    Current consumption .................................................. 15A
    Dimensions (WHD) ..............182mm112mm163mm
    Operational temperature range ......................-10C~60C
    Storage temperature range ............................-20C~85C
    Weight .................................................. ....................2.8kg
    TV Ready (KTCV 300N/P)
    Rear camera Ready (automatic NTSC/PAL)
    Navigation Ready (KNA G510)
    Spek KCA IP500
    http://www.kenwood.com/i/kca-ip500/index
    Classic Video all
    Touch above v.2
    Nano up to v.4
    Iphone all
    Dijual paket, gak bisa dipisah (maaf).
    Tanpa instalasi.
    Barang di Sidoarjo
    Harga 7 juta nego > 6,5 jt(ongkir dibicarakan lagi)
    PM SMS or call 03181935227
    Free Image Hosting by ImageBam.com
    Sale.. Sale...
    Cam Ralli Art buat 4G63 lawas plus sproket modifikasi dari sproket aslinya, adjustable.
    10 Mins 15 Secs
    Barang bagus neh .. sayang duitnya kurang ...
    Bogor
    Quote Originally Posted by ambalat View Post
    Makasih udah mampir ke lapak gue bos...
    Sale.. Sale...
    16 Hrs 28 Mins 8 Secs
    up....................
    DKI Jakarta, Indonesia
    1 Mth 2 Wks 5 Days 2 Hrs 48 Mins
    dibantu UP dulu...
    Bogor
    Quote Originally Posted by rin_dix View Post
    Makasih gan...
    Sale.. Sale...
    Bogor
    Quote Originally Posted by dinch View Post
    dibantu UP dulu...
    Makasih dah mampir gan..
    Sale.. Sale...
    Bogor
    up
    up up up
    up up up up up
    up up up up up up up
    up up up
    up up up
    up up up
    Sale.. Sale...
    jln,jombang raya no 47,bintaro,pdk aren tangsel
    1 Day 7 Hrs 8 Mins 46 Secs
    bantu up aja bos
    Bogor
    Quote Originally Posted by panekeer View Post
    bantu up aja bos
    Makasih udah mampir gan..
    Sale.. Sale...
  1. Eclipse ipc-106 Interface Adapter for Ipod cuman stengah harga!!!
    By jlu_mike in forum Head Unit & Processor
    Last Post: 13th July 2010, 19:47
  2. Replies: 7
    Last Post: 12th July 2010, 07:02
  3. Replies: 66
    Last Post: 2nd June 2010, 16:38
  4. Replies: 37
    Last Post: 6th December 2009, 19:29
