ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, ......(sold,thanks modcom...)
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/159262
    Cool ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, ......(sold,thanks modcom...)
    ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, Silver Cone kondisi muluus,lengkap dus........sold
    The Scan-speak 23W/4557T is a very high end subwoofer, designed to be used with a passive radiator in a small enclosure. This sub has a very rigid aluminum cone, low loss rubber surround and cast frame. The passive radiator is similar, but with a weight attached to the bass of the cone. The 23W/4557T is using the SD-1 motor system. There are gold plated binding posts and the woofer is covered by a decorative rubber cap.
    Frequency response with the passive is down to 25Hz. One cubic foot sealed has an F3 of 33Hz.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 82 dB
    Free air resonance Fs 20.5 Hz
    DC resistance 3.45 ohm
    V.C. inductance 0.45 mH
    Power 225 W
    Effective cone area 232 cm2
    V.C. diameter 50 mm
    VC height -
    Air gap -
    Lin. & max. excursion 13 / 20 mm
    Air gap flux density -
    Force factor BL Product 9.3 Tm
    Moving mass incl. air 101 g
    Net weight 4.6 kg
    Vas 45.6 ltrs
    Qms 4.8
    Qes 0.52
    Qts 0.47
    Outside diameter: 255mm
    Cut out: 225mm
    Depth: 135mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    up..............................
    17 Hrs 26 Mins 3 Secs
    UP..................
    thanks yach bos eddy..........
    up............
    20 Hrs 46 Mins 2 Secs
    barang maut ni broo.. kebetulan temen kmarin ini nanyain.. brpaan boss mintanya? tlg di PM thx..
    pm sent yach bos....
    thanks............
    up................
    up...............
  1. ScanSpeak 23W/4557T 9" Aluminum Cone Subwoofer, Silver Cone
    By bang-t in forum Speaker - SubWoofer
    Last Post: 27th January 2011, 22:56
  2. Replies: 51
    Last Post: 14th November 2009, 05:29
  3. hi-end scanspeak 23w revelator subwoofer.....(sold,thanks modcom....)
    Last Post: 17th September 2009, 06:05
