NAKAMICHI EC-302 kondisi muluus.........sold,thanks modcom......
Results 1 to 10 of 16
  • Short URL:  http://modifika.si/158601
    Cool NAKAMICHI EC-302 kondisi muluus.........sold,thanks modcom......
    NAKAMICHI EC-302 kondisi muluus........sold
    Electronic Crossovers With Unsurpassed Sonic Performance And Flexibility
    The EC-204 and EC-302 are extremely versatile electronic crossovers that ensure the highest level of performance in a wide variety of multi-amp system configurations. Both feature state-of-the-art circuitry and are constructed of the finest materials and components. Examples of Nakamichi's attention to detail include fully balanced internal circuit configurations that permit phase inversion without additional stages. All level controls precede the active filters so that output impedance is unaffected by their settings. Bypass outputs provide unaltered throughput of the input signals, ensuring the simplest, highest quality signal path when the EC-204 and EC-302 are combined in more sophisticated multi-way systems. The bypass provision also makes it possible to adjust one part of the system without affecting subsequent parts of the chain.
    Both units incorporate DC-DC converter bipolar power supplies, which make it possible to use the most advanced, low-distortion, wide-dynamic-range circuitry. Both also feature floating ground and Nakamichi's Isolated Ground topology to maintain high signal purity and virtually eliminate the effects of external interference. 18dB/octave filters are used to minimize multi-source interference across driver ranges. And low-impedance outputs increase resistance to inductive noise pickup.
    The EC-204 is a 2-way, 4-channel network designed specifically for multi-amp systems using the SP-1010 or SP-80 subwoofer. It provides front and rear left/right inputs; front and rear left/right outputs; plus constant bass outputs. The front and rear bass-to-mid/high crossover frequencies can be independently adjusted in 10Hz increments from 10Hz to 310Hz.
    The EC-302 is a 3-way, 2-channel design that can be used in two types of multi-amp systems: woofer/midrange/tweeter or subwoofer/bass-midrange/tweeter. In the latter case two EC-302 units can be used to allow the head unit's front/rear fader to control the bass-midrange drivers and tweeters while the subwoofer operates in constant bass mode. A multiplier switch permits the low-mid crossover frequency to be selected from the 10Hz to 310Hz range in 10Hz increments or the 100Hz to 3.1kHz range in 100Hz increments. The mid-high crossover frequency can be adjusted from 500Hz to 15.5 kHz in 500Hz increments.
    call
    0813885757888
  2. clickbet88.com
    Ini ya chris yg lo bilang buat maen 3 way?
    Blm pernah pake crossover gini euy..
    PM harga chris
    pm sent bos rinal.thanks ya nal.............
    pak itu 3ways isinya high, mid , low trus ada untuk subwoffer ga?????
    pm nett +ongkir sby ya
    Jakarta Raya
    1 Day 5 Hrs 48 Mins 6 Secs
    Chris mo d jual brp? kl masuk budget lgs meluncur ke MGK nih
    buat bos anthony,kalau ec-302 digunakan untuk sub juga,maka untuk di dpnnya hanya bisa untuk 2 way bos atau bisa digunakan untuk 3 way di dpn,tapi tidak bisa lagi digunakan untuk subwoofer bos,thanks.....
    pm sent bos,thanks...........
    up.....................
    lah kalau untuk mengontrol tweeter, mid rang, midbasss,subwofer pake apa ya pak?ato pake nakamichi ec 302 digabungin ec 202? Maap nanya terus, masih newbee nich... Bingung mau milih active crossover yang bagus... Oiya harga e ec 302 tolong dibisikin pa... Trims
    iya bos,paling pakai ec 204 1pc lagi bos....
    harga ec 302 nett nya 1,1jt bos,kalau ec 204 harga nett nya 800rb bos,thanks...
  1. Replies: 4
    Last Post: 4th March 2010, 17:27
  2. Replies: 2
    Last Post: 4th March 2010, 07:14
  3. NAKAMICHI CD-350 kondisi muluus................(solld,thanks modcom...)
    Last Post: 24th October 2009, 07:34
  4. Replies: 20
    Last Post: 18th June 2009, 07:08
