WTS:ECU Standalone 6,6jt gue turunin lagi jadi 5 jt (sold out)
Results 1 to 10 of 73
  • Short URL:  http://modifika.si/158454
    1 Wk 4 Days 18 Hrs 35 Mins 51 Secs
    gue mau jual ECU microtech Ver 1.0 nih ga jadi pake karna salah beli. bekas mesin honda d16zc
    kalo mesin yang lain Coba Diliat disini http://www.microtechefi.com/microtech-applications.php
    Microtech Applications
    Honda
    LT-8 DIST 4 cyl 4 pole MAGnetic setup
    LT-8 DIST 4 cyl 16 teeth + Coil
    LT-8 DIST 4 cyl 24 teeth + Coil
    Mitsubishi
    LT-8 Twin Can 4G63, 4G93 Std Crank angle sensor Std twin coil pack
    LT-8 4G15 Mirage Std crank sensor & coils
    LT-8 4G63 Starion set up (4 pole Magnetic Dist,single coil)
    LT-8 4G63 Cordia set up (4 pole Magnetic Dist,single coil)
    LT-8 V6 FTO engine Std crank sensor & coils
    LT-8 4G93 single cam Lancer/Mirage Std crank sensor,dual coil set up on valve cover
    LT-8 4G93 twin cam GSR Lancer Std crank sensor & coils
    LT-8 4G63 EVO 8 Std crank sensor & coils
    LT-8 4G63 EVO 4,5,6,7 Std crank sensor & coil packs
    LT-8 4G63 EVO 1,2,3,VR4,Talon & Eclipse Std crank sensor & coilpacks
    LT-8 4G63, Starion setup (4 pole MAGnetic DIST)
    LT-8 4G63, Cordia Setup (4 pole MAGnetic DIST)
    LT-8 4G 15 DIST setup
    Toyota
    LT-8 4AGE 3 wire DIST
    LT-8 4AGE 4 wire DIST
    LT-8 3SGTE DIST
    LT-8 4AGE 20 valve setup
    LT-8 Starlet DIST
    Spec :
    * Microtech Lt8s Ver 1.0 Waring lengkap Relay 2 buah Rp 5.900.000,-
    * KIT Software(CD), Dongle dan Kabel Untuk ke Laptop Rp 1.100.000,-
    (tidak di jual terpisah) di ralat jadi di jual terpisah saja biar cepet lakunya
    ambil 22 nya Harga 5jt
    Hub Rio, 08569979097
    SOLD OUT
  2. clickbet88.com
    Suerabaja City
    2 Hrs 40 Mins 37 Secs
    Quote Originally Posted by rioloan View Post
    gue mau jual ECU microtech Ver 1.0 nih ga jadi pake karna salah beli. untuk mesin Honda D15 kalo mesin yang lain gak tau deh coba browsing aja.
    Spec :
    Harga 7,5 jt
    lokasi mana niey pak bozz...
    trims..
    Quote Originally Posted by CityZ_Keparat View Post
    trims..
    Lokasi jakarta bos
    semarang
    2 Days 16 Hrs 40 Mins 25 Secs
    bos pm harga nett duonk eehhee
    Quote Originally Posted by sardimansanjaya View Post
    udah murah banget tuh bos ... paling bonus Free ongkos kirim deh
    padang - sumatera barat
    1 Wk 4 Days 8 Hrs 15 Mins 39 Secs
    Bantu up bos, buat mobil yg pengen kencang...
    maksih Om...... ayo dijual dijual .....
    UP
    UP UP
    UP UP UP
    UP UP UP UP
    UP UP
    UP UP
    UP UP
    UP UP
    UP
    UP UP
    UP UP UP
    UP UP UP UP
    UP UP
    UP UP
    UP UP
    UP UP
    UP
    UP UP
    UP UP UP
    UP UP UP UP
    UP UP
    UP UP
    UP UP
    UP UP
  1. Si Cupu Item lagi GD3 yang pura2 jadi GE8
    By wongcakep in forum Honda
    Last Post: 5th July 2014, 16:47
  2. New Vios, jadi taksi lagi nga ya?
    By Koeman in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 15th June 2013, 11:25
  3. WTS: Soundstream A3.0 Class A Turunin Harga!! Sold!!
    By vortechvr6 in forum Power Amplifier
    Last Post: 23rd March 2010, 19:16
  4. MODCOM Koq jadi LEMOTTTTTT......( lagi )????
    By budi_sus in forum Saran Kritik & Pertanyaan
    Last Post: 29th March 2009, 22:25
  5. WTS LAGI: ACHILLES 123 [WAS BOOKED TP GA JADI]
    By ninotorious in forum Bursa Kaki Lainnya
    Last Post: 23rd July 2008, 16:51
