Velgvelg Rajawali Autogallery
RS Speed
ACM 242x90 CK & DRD Banner Available 242x90
Results 1 to 15 of 175
    All About Chevrolet Trooper
    The Isuzu Trooper was a mid-size SUV produced by the Japanese automaker Isuzu between 1981 and 2005. It was exported worldwide as the Isuzu Bighorn, Isuzu Trooper, Isuzu Trooper II , Isuzu Caribe 442, Acura SLX, Chevrolet Trooper, Subaru Bighorn, Honda Horizon, Opel/Vauxhall Monterey, Holden Jackaroo, and Holden Monterey.
    There were two generations of Trooper, 1981-1991 and 1992-2005, after which Isuzu ceased exporting the model. It began production as a rather basic and somewhat underpowered on- and off-road vehicle, offered only with 4 cylinder motor, 5 speed manual transmission, and part-time four-wheel drive. The first generation evolved to add both amenities and luxuries, including optional air-conditioning, power windows, and a more powerful V6 engine. The second generation was more refined yet, available in two-wheel drive as well as four.
    The first generation Trooper was available as a 2 or 4 door, with a solid 4.555:1 rear axle and an independent front suspension. Early engines included 2.0 L 1.9 L and a 2.2 L diesel, lightly powered even by early 1980s standards for the vehicle's 3,700 lb (1,678.3 kg) empty weight. The four-wheel drive system was engaged by operating a three-position shifter adjacent to the transmission shifter. Both Aisin manual-locking and Isuzu's own auto-locking hubs were employed. In 1986, Isuzu introduced a 112 PS (82 kW; 110 hp) 2.3 L engine, regarded as an improvement over the previous engines.
    In 1987 Isuzu introduced a 2.6 L (4ZE1) V-tech fuel-injected engine. An optional General Motors 2.8 L pushrod V6) borrowed from the Chevrolet S-10 pickup was also available. Manual transmission equipped models had a gear driven transfer case with a 2.28:1 low range ratio; models equipped with the 2.6 L four-cylinder engine and automatic transmission had a 2.66:1 low range transfer case. Later first-generation models offered an optional four-speed automatic transmission. . Models from 1988-1991 were equipped live rear axles and 4-wheel disc brakes. Also new in 1987 were rectangular headlights.
    Overseas model engines not released in the United States included the Isuzu C223 (2.23 litre), C223T (turbocharged 2.23 litre) and in the late 80's turbocharged 4JB1-T engine (2.8 L diesel straight-4 engines.
    In 1989 only, a short wheelbase (90") Isuzu Trooper was imported to the US market as the Trooper. All of these short wheelbase Troopers were equipped with 2.6 L fuel injected 4-cyl engines, 4.77:1 differential gears and 31"x10.5 tires mounted on 15"x7" aluminium alloy "snowflake" pattern wheels. Automatic and manual transmissions were offered.
    In Central America Troopers were offered with removable roofs and a higher wheel clearance. Powertrain options included the Isuzu 2.8 L turbo diesel.
    (http://en.wikipedia.org/wiki/Isuzu_Trooper)
    Bro and Sis semua yang punya Chevrolet Trooper sharing di sini semua tentang Chevy Tooper yach...
    Mobil ini emang enak dipake...ga rewel, kaki-kakinya kuat dan nyaman lagi.....
    Ni ada daftar bengkel yang diambil dari forum sebelah....siapa tau bermanfaat.....
    DAFTAR BENGKEL REKOMENDASI KHUSUS DIESEL :
    Spesialist Pemasangan dan Rekondisi Turbo
    HPSI Performance : Tlp (021)08569926233
    Diesel Engine Swap Specialist
    POTENSI JL Pesanggrahan no 27 (021)5841408-5841409
    ALAM INDOMESIN UTAMA
    Jl Pekapuran Raya No.64 Cimanggis, Depok, Jawa Barat Indonesia, 16953
    Telepon: +62 21 87743487
    Fax : +62 21 87744914
    www.indomesin.com
    BERKAH MOTOR
    JL Raya Ps Minggu Km 40 sebelum Volvo 021-7996732-7993259-08161699411
    Diesel Engine Service & Performance
    BERKAH MOTOR
    JL Raya Ps Minggu Km 40 sebelum Volvo (021)7996732-7993259-08161699411
    CIPTA ABADI DIESEL (GIOK CAN)
    Jl. Daan Mogot Raya, Jakarta (samping rel kereta Pesing, dr arah Grogol stlh studio Indosiar) 021-9204862
    CIPUTAT DIESEL
    Jl. Ciputat Raya 021-7420869
    ABADI DIESEL
    Jl. Pemuda no.9, Rawamangun, Jakarta Timur 021-4890911 .
    Jl. Gatot Subroto Km 2.2 no.10 - Cimone, Tangerang, Jawa Barat 021-5524380, 5525392
    BETAWI DIESEL
    Jl. Cilincing no 25 depan pintu 1 - 2 Bogasari samping Honda
    Tanjung Priok Jaktim 021-4351854, 70768117, 08129209146
    NEO DIESEL
    Jl. Cipinang Muara I no 37B Cipinang Jaktim 021-8501434
    Tempat Jual Engine Ex Spore
    Dua Sekawan Motor
    Jl. Raya Joglo, No.27, Jakarta Barat
    Phone : 021-5858601 / 5868287 / 70702324
    Spare Part (kopas dari www.duniabengkel.com)
    Atrium Senen
    Abadi Jaya Motor Blok B /nomer25 No Telpon : 3523763
    Atlas Motor Isuzu Blok B /nomer36 No Telpon : 3846665
    Berkat Motor Blok C /nomer102-103 No Telpon : 3867861
    Garuda Motor Blok C /nomer46-47 No Telpon : 3846264
    Golden Star Blok C /nomer59-60 No Telpon : 3847019
    Kramat Motor Isuzu Blok C /nomer17 No Telpon : 3862774
    Kurnia Motor Blok B /nomer11 No Telpon : 3847576
    Mandala Motor Blok D /nomer16 No Telpon : 3514472
    Mulia Agung Motor Blok A /nomer65 No Telpon : 3516183
    Ramayana Motor Blok A /nomer16 No Telpon : 3516182
    Rezeki Motor Blok B /nomer56 No Telpon : 3516457
    Senen Jaya Isuzu Blok A /nomer35 No Telpon : 3847950
    Serimpi Motor Blok C /nomer72 No Telpon : 3516453
    Sumber Cahaya Blok C /nomer83 No Telpon : 3523741
    Dutamas Fatmawati
    Fajar Timur Motor Blok S 26 Telp. 72793687
    Inti Motor Blok T 2 Telp. 72793726
    Inti Motor Blok T 2 Telp. 72793736
    Wijaya Blok T 18 Telp. 72793671
    Cempaka Mas
    Hendi Motor BlokA 24 Telp. 42881927
    Jakarta Motor Blok I 20 Telp. 42880584
    Karya Abadi Blok D 16 Telp. .
    Kusuma Cempaka Mas Blok H 12 Telp. 42881918
    Menara Motor Blok I 5 Telp. 42881939
    Mitra Motor Blok I 28-29 Telp. 42880578
    Mulia Motor Blok I 19 Telp. 42880585
    Palapa Sakti Motor Blok K 11 Telp. 4260220
    President Motor Blok A 22 Telp. 42881919
    Sakura Motor Blok E 18 Telp. 42881906
    Sinar Safari Blok G 21-22 Telp. 42881956
    Tri Jaya Abadi Blok H 14-15 Telp. 42880607
    http://www.sparepartsmobil.com/main_...spareparts.php
    Private First Class
    Absen dulu bro Chevrolet Trooper '90 Silver
    Private First Class
    gan ijin numpang nongkrong yach
    baru punya trooper culun nih.....
    Buat yang lagi butuh karet pintu dan jendela
    Toko Sumber Motor
    Atrium Senen lt.5
    021-3523740
    Permasalahan seputar chevy trooper diesel :
    1. Start berat --------------------------------> dinamo stater sudah tua atau groundnya sudah jelek
    2. Bunyi duk-duk-duk------------------------> kaki-kaki, karet body waktunya ganti, bisa juga dari
    engine mounting yang sudah waktunya ganti
    3. Aki sering tekor----------------------------> bisa dari aki, dinamo atau regulator (cut out/ketot) udah
    waktunya di periksa
    4. Panel instrumen suka nyala sendiri------> wah kalo ini ga tau, udah coba nyari tapi belum ketemu2
    sekian dulu, lain kali di update
    Tips buat yang mau engine swap:
    Mesin c223 memang pas sekali engine mountingnya dengan mesin 4jb1 atau 4jb1-tc yang dipake sama isuzu elf. tapi para troper mania ada juga yang make 4jg2t. Agar nantinya setelah swap engine ga susah cari part ada baiknya coba dulu dilihat tipe isuzu apa aja yang resmi ada di Indonesia:
    1. ELF NKB5SC --------> 4JB1 2.8L (Naturally Aspirated/Non Turbo)
    2. ELF NKC5SF --------> 4JB1-TC 2.8L (Turbo)
    Keduanya Plug n Play dengan Mounting trooper dan yang beredar di Indonesia adalah yang timing gear bukan timing belt.soalnya ada juga mesin 4jb1/t impor yang pake timing belt, takutnya susah cari spare part timing beltnya....
    selain itu ada juga mesin-mesin berikut tapi ga tau plug and play apa plug and pray?
    1.ELH NKB5WC-------------> 4BE1 3.6L
    2.ELF NKC5SF------------------> 4HF1 4.2L
    3.ELF NKC5WF ----------------> 4HG1-T
    mohon koreksi kalau ada yang salah
    Permisi om momod,
    gw baru dapet Trooper '87 kondisi standar n adapun yg ingin gw tanyain, yakni :
    > Beda jarak (wheelbase) Trooper Tipe short dgn Long yg 3 pintu..?? coz punya gw 3 pintu, klo diliat agak panjang jarak wheelbasenya.. tapi di STNK tertulis keterangan JEEP S.C.HDTP
    > mohon rekomendasi bengkel per / kaki2 diseputaran Jakarta Timur yang bisa bangun / ninggiin..??
    Salam modifikasi...
    Wisnu
    Quote Originally Posted by cincangkelink View Post
    Permisi om momod,
    Salam modifikasi...
    Wisnu
    bro secara pasti gw ga tau berapa cm tepatnya
    cm mungkin punya bro kayanya yang long...
    kalo di foto di atas trooper putih tuh short
    mungkin ada teman2 lain yang tau?
    bengkel kaki-kaki kayanya ada yang rekomen di daerah pondok bambu
    tapi itu berdasarkan browsing aja di forum sebelah bukan pengalaman pribadi
    coba aja browse di forum kaki-kaki
    Quote Originally Posted by stompbox View Post
    setelah melalui pengamatan & penyelidikan, Trooper milik saya positif tipe Long 3 pintu, perbandingan dgn tipe short saya ukur kaca smping blkng (kaca geser) :
    > tipe long : lebar kurang lebih 1.5 meter
    > tipe short : lebar kurang lebih 1 meter.
    thnks bro stompbox atas tanggapannya..
    oke bro
    udah jadi benerin kaki-kaki blom?
    katanya di bengkel fiddoh bagus tuh....
    di modcom trooper mania nya dikit ya....sepi bgt ni...
  12. #11
    @ stompbox: bengkel Fiddoh daerah mana ya..?? maklum nubie.. he3x.. sampe skrng sih belum diapa2in tuh kaki2nya.. pinginnya sih dibangun versi ALTO biar gak terlalu cupu.. soalnya klo langsung versi OFFROAD gak kuat beli ban MT_nya... he.3x.. iya dsini sepi banget... perlu kerja keras buat ngomporin rekan2 modcom lainnya..;p
  13. #12
    Alamatnya lupa tapi di daerah jaksel coba hub
    Mas Fiddoh di Pro Hobbies di 021 75909672 atau 081380322527
    versi ALTO tuh gimana yah bro?
    kemaren sih di bengkel Fiddoh katanya ada yg pernah ngrubah kaki standar trooper 88 kebawah (single wishbone) ke kaki standar trooper 88 ke atas (double wishbone) katanya sih lebih kuat...
    Foto trooper nya dipajang di sini donk om....
  14. #13
    absen om.. trooper long 92
  15. #14
    nubie absen....trooper '84 L 3 pintu...
    btw
    minta rekomendasi dung ane mau repair n restore body tapi gak tau bengkel yang bisa spesialis nangani body trooper, coz udah agak parah di talang air, titik2 dudukan body, n sepatbor beakang mulai berkarat dimakan usia...hehe.
    thanx ya
  16. #15
    versi ALTO yg gw maksud cuma sebatas pake ban ukuran antara 30 - 31 All Terrain/ kembangan halus plus sdikit tambahan accesoris kaya roof rack. Klo misalkan kudu pake ban uk. 32 keatas plus kembangan kasar... manteb duitnya... he.3x...
    kira2 budgetnya brapa tuh om buat nge_upgrade kaki standar trooper 87..??
    klo upload foto trooper di forum.?? waduh ga pd om... nti pada hoek smua...:p
Tritala Rajawali Autogallery Clean N Tidy
  1. Chevrolet Trooper 93
    By Delivery Boy in forum Chevrolet
    Last Post: 5th March 2013, 18:35
  2. Replies: 2
    Last Post: 7th May 2011, 20:32
  3. Chevrolet Trooper 1996
    By Vodkaman in forum Chevrolet
    Last Post: 4th January 2011, 21:48
  4. WTB : OEM Rims for Chevrolet Trooper '93-'95
    By Lucky Luke in forum Ragam Ukuran
    Last Post: 8th February 2010, 08:33
  5. [WTS] : chevrolet trooper '94 M/T standart
    By bonenex in forum Chevrolet
    Last Post: 24th December 2008, 15:23
Silikon Motorsport
Tirta Motor Sport
