"Top Of The Line" SEAS Exotic T35 X3-06 & SEAS Exotic W8 X2-08 (sold,thanks modcom..)
Results 1 to 10 of 31
  • Short URL:  http://modifika.si/157287
    Cool "Top Of The Line" SEAS Exotic T35 X3-06 & SEAS Exotic W8 X2-08 (sold,thanks modcom..)
    "Top Of The Line" SEAS Exotic T35 X3-06 & SEAS Exotic W8 X2-08 ex demo..... sold
    SEAS Exotic T35 X3-06, Tweeter with Alnico Magnet
    $426.00 for each
    10+ $383.40
    The Exotic T35 is a classic dome midrange tweeter with high sensitivity and a smooth, extended frequency response.
    A coated fabric dome with integral surround manufactured by Dr. K. Müller in Germany ensures excellent performance and consistency. This supplier was among the fi rst in the world to offer fabric dome diaphragms, and did produce the diaphragm for the famous 1.5” Dome Tweeter H087, developed by Seas in 1968.
    A high effi ciency Alnico V ring magnet in a carefully designed system contributes to high sensitivity and low distortion. A large and well damped cavity in the pole ensures a low resonance frequency and smooth response.
    A generously underhung 35mm voice coil wound from copper-clad aluminum wire further enhances the sensitivity. Flexible lead-out wires and venting holes in the aluminum coil former help reduce noise to a minimum.
    A large diameter 7mm thick precision machined aluminum front plate with moderate horn loading ensures linear frequency response and represents an extremely stable platform for the magnet system and the moving parts.
    SEAS Exotic W8 X2-08, 8" Woofer - Alnico Magnet
    $765.00 for each
    10+ $688.50
    The Exotic W8 is an 8 inch woofer-midrange driver designed for smooth, wide frequency response, high sensitivity and low distortion.
    The special paper cone is embedded with papyrus fi bres to optimize stiffness and damping.
    A special foam rubber surround reduces mass by 40% compared to conventional rubber surrounds, resulting in higher sensitivity and excellent damping properties. Unlike most plastic foam materials, this material is stable and will offer decades of trouble-free operation.
    A new and proprietary spider design dramatically improves the performance of this critical suspension part.
    By combining an extremely open weave with a new resin formulation, all noises normally generated by the friction of the threads rubbing together are virtually eliminated. Additionally, the open weave is highly acoustically transparent, minimizing the refl ections and resonances associated with conventional spider designs.
    A high temperature copper voice coil is wound on a rigid, non-conductive glass fiber former.
    High quality H2 lead-out wires eliminate noise due to roping and resonances.
    The magnet system uses an Alnico V ring magnet for high sensitivity and excellent stability.
    Massive copper rings above and below the magnet gap lower distortion due to eddy currents and flux modulation. A hand-turned phase plug made from ash offers optimal radiation conditions for the critical mid frequency band.
    A stiff and stable injection moulded zinc basket keeps the critical components in perfect alignment. Generous windows both above and below the spider reduce sound refl ection, air fl ow noise and cavity resonances to a minimum.
    call
    081388575788
    Ya ampun chris barang lo..
    Bantu up ajahhh..
    klaten
    Quote Originally Posted by rigiyu View Post
    Bantu up ajahhh..
    Yak ampunnn...uda pernah liat "barangnya" boss Chris yah...??
    wkwkkwkwwk...emang mangstabbbbbbb
    he..he..he.....,bisa aja nich bos rinal n bos danny.....
    thanks ya bos......
    Mantap Christ,
    Cocok buat DIY untuk power tabung...
    PM net price...
    Thank a lot
    pm siap dikirim ko reddy....
    Honoured Member
    Smile
    PM Harganya Bro....thx
    PangkaL Paha
    2 Wks 5 Days 2 Hrs 40 Mins 54 Secs
    sadis abit nih
    Grand Central West Side
    6 Days 23 Hrs 47 Secs
    Quote Originally Posted by b2okane View Post
    sadis abit nih
    tweeternya boleh u embat ni ken
    Jantzentm - Audiencetm - Furutechtm - Gronebergtm - etc.
    PangkaL Paha
    gue yg ngembat, lu yg jawab yak kalo kegep
Mega Glodok Kemayoran
  1. Replies: 46
    Last Post: 22nd February 2010, 07:38
  2. Replies: 15
    Last Post: 21st February 2010, 18:39
  3. SEAS P12 RCY 4" driver........(sold,thanks modcom...)
    Last Post: 30th January 2010, 12:55
