M6+ - CDT Audio 6.5" 240 Watt Mid-Bass/Sub-Bass Drivers (sold,thanks modcom....)
Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
  • Short URL:  http://modifika.si/157264
    Cool M6+ - CDT Audio 6.5" 240 Watt Mid-Bass/Sub-Bass Drivers (sold,thanks modcom....)
    M6+ - CDT Audio 6.5" 240 Watt Mid-Bass/Sub-Bass Drivers (hi-end sub 6,5 inch for sq).....sold
    retail price $499.99
    Description:
    The M6+ (cast alloy red frame) has a more massive voice coil than typical bass/midrange and leans toward the bass in the sound compared to the standard high-end mid drivers. The upper midrange is somewhat mellower than standard high-end mids which creates a very very smooth and balanced non-fatiguing sound with an extension in the bass region never heard of before from a 6.5 mid driver.
    Features:
    * Diameter: 6.5"
    * Sensitivity: 83.8dB
    * Maximum Power Handling: 240 Watts Peak
    * Nominal Power Handling: 120 Watts RMS
    * Frequency Response: 10~4000 Hz
    * Nominal Impedance: 4 Ohms
    * Voice Coil Diameter: 1.5"
    * Peak Xmax: 12mm
    * Magnet Weight: 30 OZ
    * Surround Material: Rubber
    * Frame Type: Cast Alloy
    * Cone Material: Fiberglass
    * Mounting Depth: 3.37" (top mount)
    * Cutout Diameter: 5.812"
    * Overall Outer Diameter 6.81"
    M-6+ - CDT Audio 6.5" 240 Watt Mid-Bass/Sub-Bass Drivers M 6 + M-6+
    call
    081388575788
    klaten
    Wuihh..ada lagi nih...kalo gak salah, dulu pernah jual persis ini kan boss...??
    CMIIW
    iya bos danny,dulu yang orange,ini yang merahnya bos...
    up.....................
    Honoured Member
    Smile
    Yang ini berapaan Bro? Lagi cari midbass nich....
    17 Hrs 26 Mins 3 Secs
    up.......kayanya maut neh mid bass
    2 Wks 4 Days 6 Hrs 1 Min 45 Secs
    Seremmmmmm
    sorry bos wendo,udah dibooked bos.....
    thanks ya bos eddy....
    bos nakamichi,gimana keadaan di negeri echi kimochi sana bos....??
    booked status has cancelled for phass at 28 evo,now the status is back to available......
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 45 Mins 39 Secs
    ini bukan jualan cdt kris ?
  1. Replies: 12
    Last Post: 8th June 2011, 19:14
  2. SOLD OUT: Mid Bass 6" Sierra SRP-62 (Terima kasih ModCom)
    By tiara in forum Speaker - SubWoofer
    Last Post: 1st December 2009, 12:42
