pengaruh throtle body n injector buat performa
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/15722
    3 jhr
    2 Hrs 14 Mins 47 Secs
    ada yg bisa nerangin g apa pengaruh throtle body n injector buat performa mesin ?
    simple rs
    4 Days 5 Hrs 49 Mins 24 Secs
    maksudnya apa ya bos??
    3 jhr
    throtle body katanya ada yg jual buat step 1 sampe 3, ini buat meningkatkan perfoma mesin ..tapi gw kurang ngerti ...
    trus injector yg lebih besar cc nya bisa juga meningkatkan performa tapi apa semua yg lebih besar pasti bikin kenceng
    NMS
    Indiana, USA
    2 Mins 20 Secs
    ngk selalu :smt003 [/quote]
    I need that SPEED!!! TORQUE!!! AND POWER!!!
    Throttle body (TB) kan kaya regulator yang ngatur berapa banyak udara yang masuk. Jadi kalo kita nginjek pedal gas, sebenernya kita ngebuka throttle body. Makin dalem nginjek pedalnya makin gede juga terbukanya, makin banyak udara yg masuk.
    Well, that's the theory, but the question that you want to ask is 'when do we need to upgrade our TB?'
    Usually people upgrade their TB when they need more air. When do we need more air?
    When we turbocharged our car, we definitely need more air thus installing a bigger diameter TB is needed. But upgrading the TB will affect the amount of air that flow to the cylinder. The extra air inside the cylinder needs extra fuel, thus we have to adjust the amount of fuel that we spray into the cylinders by adjusting the fuel map in the ECU. Otherwise we will run 'lean' and more prone to detonation. Again, your motor doesn't like detonation..
    Same with the TBs, we want to upgrade our injectors when we need more fuel.
    Bigger injectors spray more fuel. But we couldn't just slapped in a bigger injectors to increase fuel supply, as the injectors are controlled by the electrical pulses sent by ECUs as their means of communications.
    Example, with the same pulse, a 440cc injectors will spray almost twice as much fuel to your cylinders compared to the stock 240cc injector. It will cause your motor to run extremely rich, which could leads to engine stall, horrible emission, and more frequent trips to gas station.
    We need a way to tell the ECU to adjust its pulse in order for the injectors to be able to supply the right amount of fuel. It means that we need a programmable ECU.
    A piggy back computer will shorten the length of pulse from your stock ECU to 0.54 times of the original pulse, to compensate for bigger injector.
    So unless you already need more air/fuel and have a programmable ECU, upgrading TB and injectors are better left as a last mod.
    Jakarta Selatan
    3 Days 13 Hrs 41 Mins
    well said..
    Malang
    1 Wk 44 Mins 30 Secs
    hmmm
    In your dreams...
    4 Hrs 28 Mins 49 Secs
    udh jelas tuhh...
    eNZed
    8 Hrs 56 Mins 27 Secs
    Quote Originally Posted by alim ulama
    well said..
    x2
GT Radial
  1. Replies: 41
    Last Post: 18th October 2012, 00:22
  2. WTB : THROTLE BODY FOR GE8
    By mogo2 in forum Jual Beli Mesin Lainnya
    Last Post: 28th April 2012, 12:50
  3. Jual throtle body buat Yaris n Innova
    By widjaja_ys in forum Jual Beli Mesin Lainnya
    Last Post: 20th October 2010, 21:14
  4. mencari : injector copotan buat bikin extra injector turbo
    By ku8o in forum Jual Beli Mesin Lainnya
    Last Post: 11th March 2010, 22:28
