ScanSpeak D2904/7100-02 wide surround, silver Face Plate (sold,thanks modcom....)
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/155712
    Cool ScanSpeak D2904/7100-02 wide surround, silver Face Plate (sold,thanks modcom....)
    ScanSpeak D2904/7100-02 wide surround, silver Face Plate segel nexindo.........sold
    new price $570.00
    The Scan-speak D2904/7100-02 tweeter is a 1" soft dome with wide surround, using the same chambering as the Ring Radiator.
    The carefully designed dome and surround result in a linear response and an exceptionally good off axis response. Note the smooth roll off on the low end, making this tweeter a good choice for simple slopes
    A specially designed venting system uses a needle to cut down on turbulence in the air cavity. Better dynamics are achieved by not using ferrofluid, voice coil cooling is performed by the venting system and conduction through copper rings. The new SD-2 neodymium magnet system improves transient response.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 94.5dB
    Free air resonance Fs 520 Hz
    DC resistance 3.0 ohm
    V.C. inductance 0.01 mH
    Power 12dB@Hz 160W@2.5K
    Effective cone area 7 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion ±0.2 / ±1.6mm
    Force factor BL Product 2.8 Tm
    Moving mass incl. air 0.35 g
    Net weight 0.42 kg
    Outside diameter: 104mm
    Cut out: 70mm
    Depth: 30.9mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    klaten
    manteb boss.....bantu up aja
    barang cakep nih
    mau dijual berapa bos chris..
    thanks yach bos danny...
    harganya 2,6jt bos afi.....
    4 Days 22 Hrs 57 Mins 5 Secs
    Om, berapa harganya nih ? Sekalian up
    Kelapa Gading
    2 Wks 5 Days 23 Hrs 21 Mins 57 Secs
    bantu up bos chriss.... sama kaya yg saya dpt dr mobil dagangan yg kmaren sy sempet tanya2 nih..... panjang jg neh tweeter... skitar 5cm kan??
    harganya 2,65jt komandan jas.........
    maksudnya tebel tweeternya bukan bos...?
    up................
  1. Replies: 11
    Last Post: 9th October 2012, 10:32
  2. WTS : Scanspeak D2904/600000 Tweeter
    By sinar_jaya in forum Speaker - SubWoofer
    Last Post: 11th March 2012, 21:24
  3. JUAL : Scanspeak 7100
    By dave8 in forum Speaker - SubWoofer
    Last Post: 25th November 2009, 14:42
  4. [WTS] Eclipse CD-7100 --> Sold! Thanks Modcom
    By panda_cute in forum Head Unit & Processor
    Last Post: 30th September 2009, 17:39
