Berapa harga yg pantas untuk Estilo Full Drag??
Results 1 to 10 of 22
  • Short URL:  http://modifika.si/155436
    3 Days 11 Hrs 47 Mins 57 Secs
    Smile Berapa harga yg pantas untuk Estilo Full Drag??
    Bos2 modcom..mau tanya berapa ya harga yg pantas untuk Estilo full drag dgn spec sbb:
    Chassis & Wheels :
    Estilo + one Piece bonet + full acrylic + full lightweight
    6 pcs M/T ET Drag 24,5/9/13 ( 2 pcs New Tyre )
    2 pcs M/T ET Drag 26/10/15 ( L4 compound )
    2 pcs spinewerkes drag wheels 13 x 10
    2 pcs Circle drag wheels 15 x 7,5
    2 pcs Bogart rear drag wheels 15 x 4,5 (include M/H tyre)
    1 set Cusco zero 2R adjustable suspension
    1 set Custom traction bar
    1 set 6 point rollbar
    Engine & drivetrain : (B series)
    ERL superdeck 2 block
    2.2 ltr stroker kit (CP custom piston + custom conrod + Crank)
    1 pcs Cylinder head with square port + Supertech Oversize Valve)
    1 pcs Cylinder head with square port + Type R valve
    2 set Skunk2 pro series valve spring
    2 set Skunk2 pro series titanium retainer
    2 set Toda Cam gear
    1 set Webcam Custom cam
    1 set Skunk2 pro series cam
    1 pcs Edelbrock Victor X intake manifold + edelbrock fuel rail + edelbrock fuel regulator
    1 pcs Edelbrock Fuel pump
    1 pcs 76mm throttle body
    1 set 550cc RC injector
    1 set 310cc custom injector
    1 pcs Fluidamper crank pulley
    1 pcs Original RMF header + 1 pcs Copy RMF header special spec
    1 set NGK power cable
    1 pcs Mugen Valve cover
    1 set Type R gearbox w/ 1,3,4,5 ATS close ratio + evolution Spool
    1 set 4.4 type R final gear + Type R LSD + 4.0 final gear
    1 set Haltech PS 500
    1 set Webber DCOE 50 + stang +Holley fuel pump + intake + Holley fuel regulator
    1 pcs ECU P30 with FEEL'S Chip
    1 pcs JAZZ 10 ltr Fuel tank
    1 pcs Billion racing Fan
    1 set MSD 6AL + MSD launch control + MSD engine rev limit
    1 set B&M line lock kit
    1 set Carbonetic carbon clutch complete with Flywheel
    Interior :
    1 pcs Buddy Club racing bucket seat
    1 set SIMPSON safety belt
    1 pcs Autometer Pro comp w/ memory + Shift point gear
    1 set Autometer phantom series (Temp,Oil press,Fuel press,Voltage)
    1 set Type R shifter linkage
    Kalo ada yg berminat bs hub 081536677773 (serious buyer only) no SMS & PM....TIDAK DIJUAL TERPISAH
    Thanks a lot
    BJAmodified Bandung
    6 Days 18 Hrs 39 Mins 17 Secs
    Aj gile,kudu yg duitnya g berseri nih....mantaf bos
    4 Mins 18 Secs
    maren di sentul waktunya brp gan?
    di aTAp yang tinggi
    11 Hrs 30 Mins 36 Secs
    wah ini sih udah ga bisa ngomng apa2 gw....ini mah beli part2 nya gratis mobilnya itungannya...hehehe.....nice and fast car u got there bro
    JDM lagee?? gpp dech...
    Suerabaja City
    2 Hrs 40 Mins 37 Secs
    mantaaaabbbb gan...
    spek mbilna...
    beli mbil gratis part racing niey...
    1 Wk 6 Days 22 Hrs 45 Mins 46 Secs
    Quote Originally Posted by speedfreakk View Post
    juragan pawangnya ga turun...
    kemaren haviedz yg turun, missed gear 2 x 13.5sec..
    oh ya, alasan mbl ini TEST HARGA JUAL, krn :
    Vtec_Team bangun mobil Evo IV Prototype Project Vtec Team - Polomas - ORD @ Polomas Workshop
    hasilnya Vtec_Team kelimpungan nge-gas 2 mobil dalam waktu yang sangat berdekatan.... line up kelas 12 sec lanjut kelas FFA, jadinya harus ada satu mobil yang dikorbankan dan di alihkan ke joki cadangan "SUPERNOVA"...
    so... ribet punya 2 mobil, nge-gas aja ga akan sempet...
    this car was best clocked 12.4 sec (Total Time) Not ET....
    Making the BIGGEST HORSEPOWER in SOUTH EAST ASIA 366hp
    (Even Blanche Racing KUPS thailand 10.2 sec cuma 310hp)
    Dan target ORD Engineering - Vtec Team buat benchmark dengan malaysia fastest All Motor (Ali Mamak, Mohd Maziz Ali) pun sudah tunai.
    Ternyata mobil2 all motor di asia tenggara yang Race di Circuit Track (Not Drag Strip) dengan REAL CHRISTMAST Tree yang baru 2 event di pakai di sepang hanya clocking best Total Time 12.8sec (Ali Mamak ET : 12.1sec, RT : 0.7sec, so Their total time was 12.8sec, dan angka 12.8sec Total Time telah kami bukukan dari tahun 2006)
    Remember, Sentul and Sepang was a Circuit Track, not drag strip (No burnout box, no Laid Rubber, etc)
    SO, Cita2 kami sudah TUNAI pada dunia All MOTOR.... and back to Test Price Topic now...
    ok, gw bantu gambaran singkat harganya.... (patokan harga 2nd -+ 75% dari harga baru)
    Quote Originally Posted by vtec_team View Post
    Chassis & Wheels :
    Estilo + one Piece bonet + full acrylic + full lightweight (Maybe arround -+ 30jt)
    6 pcs M/T ET Drag 24,5/9/13 ( 2 pcs New Tyre ) ( -+ 4jt x 6pcs)
    2 pcs M/T ET Drag 26/10/15 ( L4 compound ) ( -+ 6jt x 2)
    2 pcs spinewerkes drag wheels 13 x 10 ( -+ 10jt)
    2 pcs Circle drag wheels 15 x 7,5 (
    2 pcs Bogart rear drag wheels 15 x 4,5 (include M/H tyre) ( -+ 8jt)
    1 set Cusco zero 2R adjustable suspension ( -+ 15jt)
    1 set Custom traction bar ( -+ 1jt)
    1 set 6 point rollbar ( -+ 2jt)
    ERL superdeck 2 block ( -+ 30jt)
    2.2 ltr stroker kit (CP custom piston + custom conrod + Crank) ( -+ 25jt)
    1 pcs Cylinder head with square port + Supertech Oversize Valve) ( -+ 5jt)
    1 pcs Cylinder head with square port + Type R valve ( -+ 3jt)
    2 set Skunk2 pro series valve spring ( -+ 2jt)
    2 set Skunk2 pro series titanium retainer ( -+ 2jt)
    2 set Toda Cam gear ( -+ 2jt)
    1 set Webcam Custom cam ( -+ 8jt)
    1 set Skunk2 pro series cam ( -+ 7jt)
    1 pcs Edelbrock Victor X intake manifold + edelbrock fuel rail + edelbrock fuel regulator ( -+ 8jt)
    1 pcs Edelbrock Fuel pump ( -+ 1jt)
    1 pcs 76mm throttle body ( -+ 2jt)
    1 set 550cc RC injector ( -+ 3jt)
    1 set 310cc custom injector ( -+ 3jt)
    1 pcs Fluidamper crank pulley ( -+ 3jt)
    1 pcs Original RMF header + 1 pcs Copy RMF header special spec ( -+ 10jt) (RMF Custom Race Version barunya 13jt)
    1 set NGK power cable ( -+ 1jt)
    1 pcs Mugen Valve cover ( -+ 1jt)
    1 set Type R gearbox w/ 1,3,4,5 ATS close ratio + evolution Spool ( -+ 15jt)
    1 set 4.4 type R final gear + Type R LSD + 4.0 final gear ( -+ 5jt)
    1 set Haltech PS 500 ( -+ 8jt)
    1 set Webber DCOE 50 + stang +Holley fuel pump + intake + Holley fuel regulator ( -+ 5jt)
    1 pcs ECU P30 with FEEL'S Chip ( -+ 1.5jt)
    1 pcs JAZZ 10 ltr Fuel tank ( -+ 1jt)
    1 pcs Billion racing Fan ( -+ 1jt)
    1 set MSD 6AL + MSD launch control + MSD engine rev limit ( -+ 3jt)
    1 set B&M line lock kit ( -+ 1jt)
    1 set Carbonetic carbon clutch complete with Flywheel ( -+ 7jt)
    Interior :
    1 pcs Buddy Club racing bucket seat ( -+ 3jt)
    1 set SIMPSON safety belt ( -+ 1jt)
    1 pcs Autometer Pro comp w/ memory + Shift point gear ( -+ 1jt)
    1 set Autometer phantom series (Temp,Oil press,Fuel press,Voltage) ( -+ 2jt)
    1 set Type R shifter linkage ( -+ 1jt)
    Thanks a lot
    iseng2 ngitung udah ketmu angka 269.5jt....
    itupun dengan asumsi harga di atas asal2an ngitung dengan harga jauhhhhhhhhhhh dibawah harga aslinya (bisa cek ndiri di internet untuk race equipment diatas)
    so, kalo ni mobil di jual dibawah itu berarti WORTHED BANGETTTT..!!!
    sale sale sale...
    up up...
    new year sale..
    1 Day 19 Hrs 38 Mins 25 Secs
    wah ngeri nih specnya..
    bogor
    2 Wks 2 Days 17 Hrs 5 Mins 39 Secs
    ck ck ck ck ck ck ....
Venom 300x250 MBtech
  1. Replies: 93
    Last Post: 29th December 2013, 19:20
  2. Replies: 34
    Last Post: 7th June 2010, 22:19
  3. berapa harga yg pantas utk Toyota MRS Thn 2000 ?
    By B 355 NS in forum Merk Lainnya
    Last Post: 3rd March 2010, 22:42
  4. WTA: harga pantas untuk C200/C 230 th 2000-2001
    By narisqa in forum Merk Lainnya
    Last Post: 31st March 2008, 07:19
  5. harga packing2 head full set berapa?
    By Visto Jakarta in forum Diskusi Mesin
    Last Post: 13th November 2005, 23:35
