ROCKFORD FOSGATE DSM 4080 & DSM 100
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/153557
    22 Hrs 27 Mins 53 Secs
    WTS
    ROCKFORD FOSGATE
    PUNCH DSM 4080 AND DSM 100
    SPECIFICATIONS
    PUNCH 4080DSM
    Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts1
    Bridged into a 4Ω Load 220 Watts x 2
    Per channel into a 2Ω Load 100 Watts x 4
    Per channel into a 4Ω Load 60 Watts x 4
    Continuous Power Rating (IASCA Standard)
    RMS continuous power per channel, all channels 40 Watts
    driven into a 4Ω load from 20 to 20,000 Hz, with less ( @ 13.8
    than 0.05% Total Harmonic Distortion (THD) battery volts) battery volts)
    RMS continuous power per channel, all channels 80 Wattls
    driven into a 2Ω load from 20 to 20,000 Hz, with less ( @ 12.6 ( @ 13.8
    than 0.1% Total Harmonic Distortion (THD) battery volts) battery volts)
    RMS continuous power bridged into a 4Ω load from160 Watts
    20 to 20,000 Hz, with less than 0.1% Total Harmonic ( @ 12.6 ( @ 13.8
    Signal-to-Noise Ratio Over 100dB A-weighted
    Factory Default Crossover Point 100 Hz - Selectable with optional Module Cards
    Crossover Alignment Butterworth
    Dimensions
    9-5/8" (24.4cm) W
    13-5/8" (34.6cm) L
    2-5/8" ( 6.6cm) H
    Bandwidth 15Hz to 100kHz
    Damping Factor @ 4Ω At output connector - Over 150
    Frequency Response 20Hz to 20kHz 1dB / 10Hz to 100kHz -3dB
    Crossover 12dB/octave with selectable high pass, low pass and full range
    via interchangeable Module Cards
    Slew Factor Over 5
    IM Distortion (IHF) Less than 0.05%
    Input Gain Variable from 40dB to 14dB (200mV - 2 Volt)
    The above figures are factory preset and are correct
    for 500 mV rated source units.
    Protection Internal analog-computer output protection circuitry limits power in case of
    overload. Thermal switch shuts down the amplifier in case of overheating.
    B+ Fuse Size 30 Amps 50 Amps
    (External to Amplifier)
    Fuse Type ATC AGU
    Equalization Bass: +18dB Maximum at 45Hz
    Treble: +12dB Maximum at 20kHz
    Input Impedance 20k ohms
    DSM 100
    Specifications:
    Measured at 12.6 battery volts
    50 Watts RMS per channel into 4 ohms
    100 Watts RMS per channel into 2 ohms
    200 Watts RMS mono into 4 ohms
    Less than .05% total Harmonic Distortion from 20-20,000 Hz
    Specifications:
    Measured at 14.4 battery volts
    110 Watts RMS per channel into 4 ohms
    200 Watts RMS per channel into 2 ohms
    420 Watts RMS mono into 4 ohms
    Less than .05% total Harmonic Distortion into 4 ohms and less than .10% into 2 ohms from 20-20,000 Hz
    08161998078
    UP............................
    up.........................
    Surabaya,087851209420
    1 Hr 10 Mins 29 Secs
    berapa nih bos dijual?
    surabaya - jakarta... always..
    in heroes town
    5 Hrs 48 Mins 17 Secs
    baranG "LAHAM" niee
    up..............................
    Rockford DSM 4080-nya kena brp yah nett-nya?
    -Thanx-
GT Radial Venom 300x250
  1. Replies: 4
    Last Post: 27th March 2011, 23:05
  2. ROCKFORD FOSGATE DSM 4080 & DSM 200IX
    By Ismail Y in forum Power Amplifier
    Last Post: 24th July 2010, 23:25
  3. ROCKFORD FOSGATE DSM 4080 & DSM 200IX
    Last Post: 10th January 2010, 12:25
  4. ROCKFORD FOSGATE DSM 4080 & DSM 200IX
    Last Post: 7th January 2010, 10:41
