******FS GIRBOK LANGKA TOYOTA 7MGTE R154 MANUAL******
Page 1 of 39 12345 ... LastLast
Results 1 to 10 of 384
  • Short URL:  http://modifika.si/153273
    Banten
    Sesuai judul
    bisa langsung Plug n Play di mesin 7MGE - 7MGTE
    bisa juga tuk 1JZ - 2JZ/1UZ cuma modif lubang baut dgn biaya 500rb
    lebih murah dari harga girbok R154 1JZ neh...
    ini dia gbr nya, biar dia yg berbicara aja yah
    peminatserius lsg telp 0254-9101666/021-93586661
    SOLD OUT
    for 7M Series
    The Gear Boxes
    1. The Spilt-Case alloy 5 speed. 28kgs, excellent for anything up to 1600cc's. Found behind any 2T or 3T toyota engine. Strong and light but not up to really high power 4 cylinders. Great behind crossflow escorts and anglias, datsuns and MG's etc
    Gear ratios: 1st 3.58:1, 2nd 2.02:1, 3rd 1.38:1. 4th 1:1 and 5th 0.86:1
    2. The Steel Case Celica box. Very strong but heavy 45kgs. Can handle anything up to around 250hp. Found behind all 2 litre Celicas and old Crowns, Cressidas and Coronas.
    First gear ratios vary: 3.28, 3.52 common. 3.62 and 3.00 very rare.
    All have the same 0.85:1 5th.
    3. Alloy Case Supra box. Very strong and light also, 35kgs. Found in most later model RWD Toyotas. Can handle upto and beyond 300hp. Four different sorts: W55, W57, W58 and W59.. pretty much in that order of rarity.
    Ratios: W55: 1st 3.57:1, 2nd 2.06:1, 3rd 1.38:1, 5th 0.85:1
    W57: 1st 3.28:1, 2nd 1.89:1, 3rd 1.27:1, 5th 0.85:1 W58 is the same except a taller 5th 0.78:1.
    W59: 1st 3.95:1, 2nd 2.14:1, 3rd 1.27:1, 4th 1:1 5th 0.85:1
    4. R154 Very, very strong box. About 45kgs. Found in late model turbocharged Supras (7M-GTE). Much larger than the W* series boxes. Known to be able of withstanding up to 1000hp.
    Ratios: 1st 3.25:1, 2nd 1.95:1, 3rd 1.31:1, 4th 1:1 5th 0.75:1
    1st 3.30:1, 2nd 1.95:1, 3rd 1.34:1, 4th 1:1, 5th 0.75:1
    Question: Dpt apa aja Pak
    Answer : Dpt girbok spt yg di Gbr dan Yoke dan Shift stick kecuali mobilnya yah.. huhuhuhu
    Q : Kondisi mulus gak???
    A : Spt yg di foto aja pak... tidak ada rekayasa fotoshop
    Q : Harganya pak???
    A : Telp aja pak... lebih enak sambil ngobrol di telp trus tawar menawar...
    Q : Bisa liat barang??
    A : Bisa banget tp harus serius loh... kan capek kalo udah bawa brg trus cuma liat doang... Huhuhuhuhuhuhu
    Q : Kalo kirim luar kota bisa??? caranya???
    A : Kirim luar kota bisa banget pak??? kalo bapak punya kurir langganan tinggal bilang saja dimana alamatnya, tar saya yg dtgin tuh kurir langganan bpk... kalo gak ada kurir langganan berarti pake kurir langganan kita pak.... tp harga di luar ongkir yah....
    PEMBAYARAN
    BCA..no rek 245 199 3030 an. M. ANSORULLOH
    PENGIRIMAN MEMAKAI JASA KURIR
    CONTACT PERSON
    HP: 0254-9101666/021-93586661 ATAU
    https://www.facebook.com/pages/AutohousE/159630070747727
    Banten
    Suzuki G13B + Wiring + ECU + Girbok + TD04
    3SGTE, 7AFE, 1NZFE, 4EFTE, F20B, K20, D17,R18, K24 dll
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupupupupupupupupupup
    upupupupupupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    call 0254-9101666/021-93586661
    kasih komen dan cendolnya yah
    http://www.modifikasi.com/showthread.php?t=115929
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    3SGTE, 7AFE, 1NZFE, 4EFTE, F20B, K20, K24 dll
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
    Banten
    up
    upupup
    upupupupup
    upupupupupupup
    upupupupupupupupup
    upupup
    upupup
    upupup
    upupup
    upupup
Venom 300x250 MBtech
  1. <WTS> GEARBOX TOYOTA R154 FOR 1JZ & 2JZ
    By Sasuke in forum Jual Beli Mesin Lainnya
    Last Post: 6th June 2012, 00:30
  2. Replies: 10
    Last Post: 14th February 2012, 20:13
  3. wtb: gearbox R154 supra manual
    By herman in forum Jual Beli Mesin Lainnya
    Last Post: 16th December 2010, 09:07
  4. ******FS GIRBOK MANUAL 1JZGTE R154 5 SPEED JUAL CEPAT****** (SOLD)
    By theansoracing in forum Jual Beli Mesin Lainnya
    Last Post: 5th December 2009, 01:19
  5. WTB : transmisi manual 1 jz (R154) + oil pan/ calter 1 jz
    By RB20DET in forum Jual Beli Mesin Lainnya
    Last Post: 18th June 2009, 23:08
