High end SCANSPEAK R7000 ring radiator kondisi muluus...(sold,thanks modcom....)
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/153251
    Cool High end SCANSPEAK R7000 ring radiator kondisi muluus...(sold,thanks modcom....)
    High end SCANSPEAK R7000 ring radiator kondisi muluus.........sold
    The Scan-speak R2904/7000 tweeter is the new flagship tweeter in the Scan-speak line. This tweeter incorporates many innovative design concepts.
    The first notable difference is the use of a phase plug. The dome is attached to the phase plug, so the radiating area is now concentrated around the voice coil. This offers more control and reduces distortion and loss that occur at the center of the dome on dome tweeters. The phase plug also acts as a wave guide, reducing high frequency cancellations. A specially designed venting system uses a needle to cut down on turbulence in the air cavity. Better dynamics are achieved by not using ferrofluid, voice coil cooling is performed by the venting system and conduction through copper rings. The new SD-2 neodymium magnet system improves transient response.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 94.5dB
    Free air resonance Fs 520 Hz
    DC resistance 3.0 ohm
    V.C. inductance 0.01 mH
    Power 12dB@Hz 150W@2.7K
    Effective cone area 5.6 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion 0.2 / 1.6mm
    Force factor BL Product 2.8 Tm
    Moving mass incl. air 0.3 g
    Net weight 0.42 kg
    Outside diameter: 104mm
    Cut out: 70mm
    Depth: 30.9mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
  2. Bandargua
    klaten
    Up buat tweeter sakti..
    1 Day 16 Hrs 53 Mins 28 Secs
    bantu up ah..
    2 Hrs 35 Mins 54 Secs
    Bro pm harga
    trims
    jogjah ajah...
    2 Days 6 Hrs 42 Mins 34 Secs
    bantu up sesama ring...hehhee
    thanks ya bos danny,bos 1501vt n bos thomas....
    pm sent bos chaos,thanks.........
    Bekasi
    1 Day 20 Hrs 36 Mins 44 Secs
    bantu up aaah,,
    skalian PM Price gan,, lg nyari" tweeter doom juga saya,,
    Mantaff chris, harga berapaan neh?
    suara normal kan bos?? pm nett bos....
    pm sent to bos adhi,bos rinal n bos hendrik...
    suara normal koq bos,sudah di test sebelumnya di audioworks bos..
Venom 300x250 Mitsubishi
  1. WTS: Scanspeak 15W, Ring Radiator R7000, Sub woofer 23W
    By Sham Jul in forum Speaker - SubWoofer
    Last Post: 5th October 2011, 23:40
  2. wts tweeter scanspeak ring radiator r7000
    By usual_terry in forum Speaker - SubWoofer
    Last Post: 11th August 2011, 01:43
  3. Replies: 13
    Last Post: 10th August 2009, 19:13
  4. WTS MURAH SEKALI!!!TWEETER SCANSPEAK RING RADIATOR R7000-GARANSI NEXINDO
    By ric_signature in forum Speaker - SubWoofer
    Last Post: 4th August 2009, 18:34
  5. hi-end scanspeak R2904/7000 ring radiator (sold,thanks modcom....)
    Last Post: 14th July 2009, 06:09
