-H.P- Blitz Dual SBC Boost Controller
Rgotogel Gelap.net 36Goal.com
Page 1 of 13 12345 ... LastLast
Results 1 to 10 of 129
  • Short URL:  http://modifika.si/153135
    Phone: 08179845168 - Klender Jakarta
    4 Days 23 Hrs 46 Mins 8 Secs
    BLITZ Electronic Boost Controller
    DUAL SBC - Type S
    1. Accurate boost control is accomplished by high performance solenoid valve.
    2. Highly visible green LCD. (Turns red under WARNING)
    3. Boost control has 4 ch.
    4. Loaded with functions: Digital boost meter, Peak Hold, Scramble, Warning, Limiter, Gain adjustment.
    5. Manual boost control is also available. Boost is adjustable even when driving.
    6. Easier control with large switches.
    7. Φ6-3waypipe and Φ4-Φ6 straight joint is newly included for wide variety of vehicle models.
    8. Heat resistant silicone hoses are used.
    9. The control unit also displays live boost pressure.
    10. The control unit also displays live boost pressure.
    11. Scramble and gain settings are programmeable.
    12. There is a boost warning mode, which can be pre set to visually and audibly alert the driver to an overboost situation.
    13. The unit can also be programmed to reduce the solenoid duty cycle in an overboost situation.
    14. It is suitable for both internal and external wastegate applications.
    The Spec S is recommended up to 1.3bar, and is supplied complete with fitting kit.
    Tertarik???
    Kondisi 100% baru...
    Silakan reply di thread atau contact ke 021-94549590..
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
  2. SbcAgent
    Padang
    1 Wk 1 Day 11 Hrs 7 Mins 36 Secs
    bos ini baru ya? hrgnya brp bos? thanks.
    Quote Originally Posted by fikri_evo1 View Post
    Betuuulll, kondisi baru 100%...
    Harga di sent by PM yaaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Padang
    Quote Originally Posted by Hydra Performance View Post
    Thanks,
    mks bos.....
    mks bos.....
    No problem bos...
    Sudah jadi tugas saya kok... hehehehehe
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Suerabaja City
    2 Hrs 40 Mins 37 Secs
    Bozz...
    Pm nettnya brp yach...
    Trims...
    Jember
    8 Hrs 53 Mins 5 Secs
    Bos netnya brp ? Tq .. Baru atau bekas ?
    Quote Originally Posted by CityZ_Keparat View Post
    Bozz...
    Trims...
    PM sent yaaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    Quote Originally Posted by wielly View Post
    Barang kondisi baru 100% bos..
    Harga di kirimkan via PM yaaa...
    Thanks,
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
    dorong dulu yaaa... sambil makan siang....
    HYDRAPerformance
    HP: 08179845168
    BB Pin: 26A64B67
  1. FS Blitz Boost controller dual selenoid
    By kura_kura_ngebut in forum Jual Beli Mesin Lainnya
    Last Post: 6th June 2012, 08:51
  2. WTS : BLITZ Boost Controller
    By rou.b in forum Jual Beli Mesin Lainnya
    Last Post: 13th January 2012, 05:52
  3. WTS boost controller blitz spec s
    By wiwi in forum Jual Beli Mesin Lainnya
    Last Post: 2nd August 2011, 00:18
  4. S$eLL Blitz dual SBC Spec - S boost controller 99,9999%
    By Matrix in forum Jual Beli Mesin Lainnya
    Last Post: 16th September 2010, 11:05
  5. DIGITAL BOOST CONTROLLER BLITZ DUAL-SBC specS
    By bp05 in forum Jual Beli Mesin Lainnya
    Last Post: 26th May 2009, 19:51
